Pedal connection for Hydratech Hydroboost #2335551
07/11/17 10:19 PM
07/11/17 10:19 PM
Lake Orion, MI
goldduster318 Offline OP
Lake Orion, MI
Hello all, I am installing a Hydratech 3074L in a 1970 Plymouth Duster. The thing that puzzles me is the pedal connection piece provided. Has anyone installed a kit like this in their Mopar and found this to be the correct one? In the photos you can see it would interfere with a good amount of the pedal without bolting down. I show the stock pushrod for reference.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Pedal connection for Hydratech Hydroboost [Re: goldduster318] #2335630
07/11/17 11:59 PM
07/11/17 11:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Can't see the pics. Photobucket is saying you account does not allow 3rd party viewing.
Just upload them directly unto Moparts.
Re: Pedal connection for Hydratech Hydroboost [Re: goldduster318] #2336093
07/12/17 07:00 PM
07/12/17 07:00 PM
Lake Orion, MI
Lake Orion, MI
Okay, sorry - will have to see what the deal is with Photobucket, but for now they are attached
Re: Pedal connection for Hydratech Hydroboost [Re: goldduster318] #2336125
07/12/17 07:49 PM
07/12/17 07:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Flip your adapter 180 then put it on the other side of the pedal assembly, you have it opposite of where the stock one connects.
Don't be the exception.
Re: Pedal connection for Hydratech Hydroboost [Re: Supercuda] #2336126
07/12/17 07:56 PM
07/12/17 07:56 PM
Lake Orion, MI
Lake Orion, MI
Huh? The adapter is symmetrical meaning that it won't touch even if I flip it over, and also i was holding it correctly on the pedal as well.
Re: Pedal connection for Hydratech Hydroboost [Re: goldduster318] #2336414
07/13/17 10:51 AM
07/13/17 10:51 AM
moparx Offline
moparx  Offline
the total thickness of the adapter looks close to the thickness of the original pushrod, so just use a spacer slightly wider than the total distance needed to keep the adapter off the pedal. unless my perspective of the pic is not up to snuff......
beer
