71 Cuda p/s pump
#2335189
07/11/17 09:59 AM
07/11/17 09:59 AM
Posts: 322 MERRILLVILLE, INDIANA
sunroof446
I'm converting my 71 cuda 340 from manual to power steering. car is 340 4-speed with a 3.55 gear. what is the correct p/s pump saginaw or chrysler federal? I'm sure it is suppose to have a cooler also with the gear ratio. Thanks.
Re: 71 Cuda p/s pump
[Re: Alaskan_TA]
#2336180
07/12/17 10:02 PM
07/12/17 10:02 PM
Posts: 636 SE PA
cudaize
SE PA
I've found that 71 340 E-bodies with T/A gears typically have federal pumps with solid pulleys. The earlier cars with the standard ratio I have seen Saginaw pumps more than not.
Below is a picture of the pulley from my 340 71 cuda with 3/31 SPD
[Re: Alaskan_TA]
#2336737
07/14/17 12:25 AM
07/14/17 12:25 AM
Posts: 636 SE PA
cudaize
SE PA
What rear differential ratio? The federal pump with the T/A gear is a 3.23 Open
[Re: JRepucci]
#2386699
10/13/17 08:30 AM
10/13/17 08:30 AM
sunroof446
Any recommendations for a correct looking power steering hose? 340 w/Federal pump. I ended up buying an nos one of ebay. I have not seen any reproductions that even come near correct. I checked ebay everyday until one came up.
