Page 6 of 9 < 1 2 3 4 5 6 7 8 9 >
#23434 - 12/05/09 09:53 AM Re: Weird MoPar interchangability..... [Re: Pacnorthcuda]
Reggie Offline
Loc: Upper Marlboro, MD
When I had my 1934 Dodge, 60s-up Mopar steel wheels fit perfectly. A 1965 B-body rear also fit nicely inside the fenders with just a perch move.
#23435 - 12/05/09 10:11 AM Re: Weird MoPar interchangability..... [Re: Pacnorthcuda]
NachoRT74 Offline
Loc: Caracas, Venezuela, SouthAmeri...
The speed-warning device in the passenger seat of a 70 'Cuda telling the driver to slow down can be installed in other cars with the exact same functionality.
didn't know about that option exist
#23436 - 12/05/09 10:31 AM Re: Weird MoPar interchangability..... [Re: NachoRT74]
Commando1 Offline
Loc: South-Central (Sebring), FL
You're obviously not married....
#23437 - 12/05/09 10:46 AM Re: Weird MoPar interchangability..... [Re: GoodysGotaCuda]
dbailey43 Offline
Loc: bc canada
don't know if this is common knowledge,but '67 4 piston calibers,are used on mustang 2's up here and a whole lot cheaper than my mopar parts guy!
#23438 - 12/05/09 11:43 AM Re: Weird MoPar interchangability..... [Re: Commando1]
NachoRT74 Offline
LOL... not, and not even living in USA. beside that E bodies weren't assemblied down here. How is coded on tag/buildsheet ?
#23439 - 12/05/09 03:59 PM Re: Weird MoPar interchangability..... [Re: NachoRT74]
FM3_1970 Offline
Loc: South Carolina
That would be MRS. For export to Latin America, SRA.
#23440 - 12/05/09 08:20 PM Re: Weird MoPar interchangability..... [Re: FM3_1970]
swifter Offline
Loc: wisconsin
Here is a good one and when you think about it someone knew we were going to do this--A 70 A833 with smallblock bell housing will bolt right up to a 2006 5.7 Hemi and will go right in to a 70 Duster--Just finished this & It still freaks me out that this was a NO-SWEAT install--Swifter
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
#23441 - 12/05/09 08:45 PM Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY]
474218 Offline
Loc: Hiram, Georgia
The latch hardware for 68-70 B-body coupe popout rear windows is the same as that used on the 70-75 A-bodies with popout rear windows.
#23442 - 12/05/09 10:18 PM Re: Weird MoPar interchangability..... [Re: Greg55_99]
Mopar1 Offline
Loc: Newfoundland Canada
Ummm.... Bellhousing from 96-00 2.5L Dakota fits Chevrolet LS4....
Ok, I'm done...
Greg
I'm not suprised considering GM has manufactured a lot of transmissions for Chrysler.
#23443 - 12/06/09 03:59 AM Re: Weird MoPar interchangability..... [Re: swifter]
ixelerate Offline
Loc: NE Ohio
good tech to know! did I miss a thread about the install?
[img][/img][img]http://i277.photobucket.com/albums/kk45/ixelerate/random/falcon.gif[/img]
#23444 - 12/06/09 06:56 AM Re: Weird MoPar interchangability..... [Re: GoodysGotaCuda]
dennismopar73 Offline
Loc: ill
front end off my 70 dart will bolt
on my 75 duster perfect fit
so does the pass and drivers doors
now i can have wing windows on my duster??
#23445 - 12/06/09 07:28 AM Re: Weird MoPar interchangability..... [Re: dennismopar73]
buildanother Offline
Loc: chicagoland,usa
I think the doors will not match the dusters pillars....
#23446 - 12/06/09 05:21 PM Re: Weird MoPar interchangability..... [Re: buildanother]
Loc: ill
yes they do
perfectly as a matter of fact!!!
just gives you a wing window!!
#23447 - 12/06/09 05:24 PM Re: Weird MoPar interchangability..... [Re: ixelerate]
Loc: ill
75 ford ltd trunk lock
will work in a 67 dodge coronet trunk lock
#23448 - 12/06/09 05:26 PM Re: Weird MoPar interchangability..... [Re: dennismopar73]
Rug_Trucker Offline
Loc: Not2farfromNashville, TN
yes they do
I looked at them and thought the windshield was at a different angle.
#23449 - 12/06/09 05:51 PM Re: Weird MoPar interchangability..... [Re: Rug_Trucker]
Not sure how it will be in the water leak department.....
#23450 - 12/06/09 06:17 PM Re: Weird MoPar interchangability..... [Re: buildanother]
JonC Offline
Loc: Millinocket, Maine
.040 over 360 file fit piston rings are the same as standard 340 rings only a LOT cheaper.
#23451 - 12/06/09 06:35 PM Re: Weird MoPar interchangability..... [Re: JonC]
Rug_Trucker Offline
I have non file fit 350 Chevy rings in my .040 360.
#23452 - 12/06/09 06:52 PM Re: Weird MoPar interchangability..... [Re: Rug_Trucker]
Dr Lebaron Offline
Loc: Frozen Wastelands, Ontario, Ca...
When I need rear drums on a FMJ, I order 89 Crown Vics.
They are nicer than the Chrysler replacements.
#23453 - 12/06/09 07:01 PM Re: Weird MoPar interchangability..... [Re: Mopar1]
440newport Offline
Loc: St. John's Newfoundland
Such as?
I figure it's the other way around... New Process(Chrysler) made transfer cases for all the big 3 and then some, there was also a version of the OD 833 in Chevies known as the MY6.
'73 Chrysler New Yorker
'80 Dodge Mirada
'90 Dodge W-150
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
Today at 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
Today at 12:03 PM
EMISSIONS CODE P0440
by moparsquid
Today at 11:30 AM
Brake calipers
by scottyb1955
Today at 11:17 AM
