Page 4 of 9 < 1 2 3 4 5 6 7 8 9 >
#23394 - 09/08/06 01:00 PM Re: Weird MoPar interchangability.....
The rubber tips used on rear package trays of hatchback Omni's, Shadows, etc. are the same as the tips used on 60s/70s mopar sunvisors.
#23395 - 09/08/06 01:47 PM Re: Weird MoPar interchangability.....
Reggie Offline
Loc: Upper Marlboro, MD
From member RV2. I don't know how this ever worked out, but I just saw one of these truck mounts in a yard the other day..
LA SB to slant 6 K-frame using a truck/van mount
#23396 - 09/08/06 01:58 PM Re: Weird MoPar interchangability..... [Re: dustergirl340]
The air in the tires of a 71 Fury is the same exact type that was used in a 71 Hemi Cuda convertible.
Maybe I should bottle up some genuine "Detroit Air" and sell it on Ebay for the numbers matching paint dab resto guys. Almost as good as NOS air!
My dad has a 80gal compressor in his garage, that last ran in 1970. It still has lots of air in it. You paint daub guys here this??
#23397 - 09/08/06 04:10 PM Re: Weird MoPar interchangability..... [Re: 65Frank]
70Cuda383 Offline
Loc: Marysville, O-H-I-O
Turn signal switch and canceling cam from up to 1976 Dodge Vans will work in a 65' Coronet Steering column.
With no modification? Do you know the Part number? Would like to try that at a dealer.
Dealer? just go to autozone and pick one up in the aisle with all the "HELP!" parts in it. My dad's picked up 2 or 3 of them for his 74 Dodge van a few times. they're like $3 a piece.
He also picked up a package of the wiper arm pivot bushings brand new in the same isle I believe the package was marked "Wiper arm pivot bushings. Chrysler 1974-Present" or something to that effect.
**Photobucket sucks**
#23398 - 09/08/06 11:18 PM Re: Weird MoPar interchangability..... [Re: 70Cuda383]
davidcwhitney Offline
Loc: Rancho Cordova, Calif.
'90s Imperial window motors work perfectly in '64-'66 Imperials. The later motor is in a bunch of other Mopars that I forget. Late '80s trucks, I think.
The 1972-1978 400 or 440 cubed motor in any Dodge truck has a pair of manifolds that fit the 1961-1966 Imperials (tip courtesy Rodger & Gabby in Colo. Springs)
1977 Executive Diplomat II
#23399 - 09/09/06 12:05 AM Re: Weird MoPar interchangability..... [Re: davidcwhitney]
MrFoFody Offline
Loc: Califor-ni-A!
This extremly rare roll of duct tape I found and used in my Dodge Daytona also worked on my old Mopars as well....
P.S. it's not for sale
Edited by MrFoFody (09/09/06 12:06 AM)
#23400 - 09/09/06 02:21 AM Re: Weird MoPar interchangability..... [Re: MrFoFody]
polaraholic Offline
Loc: IN
I have found that lots of money can go into any Mopar.
#23401 - 09/09/06 10:15 PM Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY]
Magnumguy Offline
Loc: S.E.Ohio
Small bolt pattern Rallyes will fit any newer front wheel drive Mopar w/14" tires. 15's are the same for the 4.5" bolt pattern.
I have SBP Rallyes on my 98 Grand Caravan
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
#23402 - 12/03/09 11:39 AM Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY]
6T6Cuda Offline
Loc: Cincinnati, OH
to keep the thread from dieing...
#23403 - 12/03/09 01:23 PM Re: Weird MoPar interchangability..... [Re: 57Plymouth]
Scott Carl Offline
Loc: Omaha, Nebraska
The glove box lock on a 72 to 80 truck will fit the console of an E-body.
Good to know. Thanx!!
Also (I think it was coverd already, but) dome lens from my 74 b100 also fits (at least) 74 e bodies
*Improvise, Adapt and Overcome!!*
"...the reason for living was to get ready to stay dead a long time." **
**(William Faulkner)
#23404 - 12/03/09 01:40 PM Re: Weird MoPar interchangability..... [Re: Scott Carl]
The 8 3/4 rearend housing out of an E-body will bolt into a 63 Dodge 880 with no modification!
My neighbor was trying to get the drums off the axles and I convinced him it was easier/cheaper to put in the E-body housing.
Radio's were interchangeable for years and years. My buddy had a later model (caravan?) radio in his '75 Dodge shortbed and dad had an AM/FM out of a '79 TC3 in his '75 Dodge pickup.
'71 E-body console button/lock is the same as a '63 Dodge 330 glove box door button/lock.
5 on 4 1/2 boltpattern wheels will interchange with Buick, Toyota trucks, some Nissans.. Dad ran 14x6 ralleye's off of my Duster on his Toyota pickup for years.
#23405 - 12/03/09 01:51 PM Re: Weird MoPar interchangability..... [Re: Scott Carl]
NicksGarage Offline
Loc: San Diego
Fun old topic.
I didn't see this one...
'65 C-body big block left motor mount and bracket are the same as '67-9 A-body big block.
NicksGarage.com - 300F.com - PantherPink.com - HallGTC.com
#23406 - 12/03/09 02:13 PM Re: Weird MoPar interchangability..... [Re: Barnabas_Kriss]
NachoRT74 Offline
Loc: Caracas, Venezuela, SouthAmeri...
71-74 B or E-body mirror heads are the same as those used on 75-79 Cordoba/Aspen/Volare/etc. (The bases are different.)
same CUP shape but won't fit... the recesed area on cup to fit the pedestal won't meet the shape. Laters are squared shape
#23407 - 12/03/09 02:15 PM Re: Weird MoPar interchangability..... [Re: NicksGarage]
donbarnes Offline
Not THAT Don Barnes!!
Loc: Wilmington, NC
I've had GM bullet mirrors on my A-body for about 4 years now and no one has ever noticed the difference. They are dirt cheap, used on about all of the 70's GM stuff, and you can get replacement parts for them...
#23408 - 12/03/09 02:15 PM Re: Weird MoPar interchangability..... [Re: Junky]
NachoRT74 Offline
Me three!
what about the hazzard button, being on column since 70 ?
I can't recall really where is on Vans/trucks
#23409 - 12/03/09 02:18 PM Re: Weird MoPar interchangability.....
NachoRT74 Offline
and Mercedes
#23410 - 12/03/09 03:08 PM Re: Weird MoPar interchangability..... [Re: dustergirl340]
Intense RT Dan Offline
Loc: Mooresville, NC
Nice! A lot cheaper than a '70.
#23411 - 12/03/09 03:26 PM Re: Weird MoPar interchangability..... [Re: Intense RT Dan]
DaytonaTurbo Offline
Loc: Manitoba, Canada
Voltage regulator off a carbed 80's fwd mopar will fit my 74 satellite perfect. Grabbed a good chrome one off a 84 shelby charger I parted.
V-belt alternators will swap from the early 80's fwd's, but they're not terribly high output IIRC.
#23412 - 12/03/09 05:21 PM Re: Weird MoPar interchangability.....
68KillerBee Offline
Loc: Missouri
wanna say it was a 93ish conversion van... its arm rests were damn near spot on to the ones in mine and my dads car
Families rides: 68 Super Bee, 68 GTX 'vert, 73 Charger, (2) 2010 Challenger r/t's. All 3 pedal equipped. 70 AAR. 71 b'cuda
#23413 - 12/03/09 06:55 PM Re: Weird MoPar interchangability..... [Re: GoodysGotaCuda]
mopars_1 Offline
Loc: Ridgeland Wi
convertible top mechanisms and windshield/ windshield moldings are the same on 66-70 B body verts.
B body 8 3/4's will pratically bolt in an A body
front clips from pratically any A body will bolt on to any A body
2 speed wiper motors are pretty much all the same
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
02/19/19 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
02/19/19 12:03 PM
EMISSIONS CODE P0440
by moparsquid
02/19/19 11:30 AM
Brake calipers
by scottyb1955
02/19/19 11:17 AM
