Re: fiberglass hood warping
[Re: gregcharger72]
#2325762
06/23/17 03:07 PM
06/23/17 03:07 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Welcome to the wonderful world of fiberglass. The factory painted these with black Organasol because they tended to look crappy with changing weather conditions. It's always going to do a little something. Get it the best you can and walk away. BTW Car looks great!
[Re: gregcharger72]
#2325961
06/23/17 11:55 PM
06/23/17 11:55 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I bought my fiberglass hood back in 1975, it sagged right from the day I put it on. To fix it at the time I fiberglass a U shaped piece of 1/2" electrical conduit to the underside. No sag after almost 40 years.
[Re: J_BODY]
#2326567
06/25/17 07:27 PM
06/25/17 07:27 PM
Posts: 111 pa
gregcharger72
pa
[Re: gregcharger72]
#2326806
06/26/17 09:29 AM
06/26/17 09:29 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
So many folks complain about glass hoods being junk. From poor fitment to not taking paint...
How did corvette make entire car bodies from it for so many years? Are they still using glass or is it urethane now?
**Photobucket sucks**
[Re: 70Cuda383]
#2328820
06/29/17 09:06 PM
06/29/17 09:06 PM
Posts: 111 pa
gregcharger72
pa
I don't think the hood is junk, I'm quited pleased with how it looks and functions just did not expect the movement with the temperature.Now that the car is in garage the hood is back to the orginal position.
[Re: 70Cuda383]
#2329080
06/30/17 11:20 AM
06/30/17 11:20 AM
DaytonaTurbo
Manitoba, Canada
I wonder if they were just much, much thicker? Thick enough that there's no weight savings over steel....
[Re: DaytonaTurbo]
#2329493
07/01/17 03:35 AM
07/01/17 03:35 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I wonder if they were just much, much thicker? Thick enough that there's no weight savings over steel.... I know many glass hoods are thicker then mine at the edges. We used to call them street or race hoods as mine is to thin near the edges to mount it on the hinges so it has to be a lift off unless a good glass worker made it thicker. But the hood itself seems thinner then the stock type that came on 6 pack cars. So I would be pretty sure the Corvette had thicker figerglass on most of the car. My back two corners only sit up mayne about 1/8 to 1/4" when cold but when I drive it and the eng warms up they end up dipping about 1/4". Just catch me when the eng is about 160 and the hood fits perfect. Ron
[Re: Dave Hall]
#2330386
07/02/17 10:10 PM
07/02/17 10:10 PM
Posts: 111 pa
gregcharger72
pa
gregcharger72 we need more pictures of that car! From what I can see it looks bitchen!!! thanks! recent picture before i put the fiberglass hood on.engine picture with scoop seal i made.
[Re: Dave Hall]
#2331617
07/04/17 10:47 PM
07/04/17 10:47 PM
Posts: 111 pa
gregcharger72
pa
Nice! I see you are running that Mancini tall throttle bracket. My Dart has that one as well. I went ahead and painted it black. Are those elastomeric bumpers or painted? I'm a blackwall out kinda person as well. Makes your rims look sharper! Nice car Greg! Thanks the bumpers are painted, much cheaper than re chroming . I'm a, less is more, kind of guy. needed the tall bracket when i put a one inch spacer under the carb . the hood and scoop with the spacer dropped my et almost 4 tenths and increased the mph 3.5 mph
