Re: Reminder: Don't put your carb away "wet"...
[Re: BradH]
#2333313
07/07/17 09:57 PM
07/07/17 09:57 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
This is a very worthwhile reminder. I had good luck with Sta-bil + running it with the fuel pump shut off until it stalled + a little marine fogging oil at the end. Sat for 4 years, ran the fuel pump and it fired right up. I've had the bowls off a few times since, am thankful to not have found any creeping crud in there.
Rich H.
Esse Quam Videri
[Re: Thumperdart]
#2461167
03/04/18 09:59 PM
03/04/18 09:59 PM
BradH
Got a suggestion for something better to loosen that check needle?
[Re: BradH]
#2461205
03/04/18 11:07 PM
03/04/18 11:07 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Got a suggestion for something better to loosen that check needle? PB Blaster is pretty aggressive. Or some kind of mild acid, like the stuff you clean nasty aluminum with to weld it. Blow gun from the metering block side of the carb body. Just be careful where it's aimed or cover the top with a towel.
[Re: BradH]
#2461216
03/04/18 11:40 PM
03/04/18 11:40 PM
Posts: 10,200 Someplace you aren't
SomeCarGuy
So you didn’t even try to dump an 8 dollar bottle of stabilizer in to at least see if it would save you any grief?
I want my fair share
[Re: SomeCarGuy]
#2461243
03/05/18 12:15 AM
03/05/18 12:15 AM
BradH
So you didn’t even try to dump an 8 dollar bottle of stabilizer in to at least see if it would save you any grief? Engine went from dyno back to stand. Carb was drained of 50/50 pump 93 E10 / leaded race fuel and put on shelf. Residual fuel in accel pump circuit corroded. Not sure where the bottle of stabilizer was supposed to used in this situation.
[Re: AndyF]
#2461314
03/05/18 02:18 AM
03/05/18 02:18 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Let me see if I got this straight. Ride them hard and put them away dry
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: BradH]
#2461331
03/05/18 03:50 AM
03/05/18 03:50 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Got a suggestion for something better to loosen that check needle? I put a dab of oil in the passage and use a steel pointed poker and pry in the slotted area and rock it back n forth with and then use compressed air on the inlet side on the main body face if needed........Rubber hammer to knock it loose if that doesn't work..........
[Re: BradH]
#2461334
03/05/18 04:02 AM
03/05/18 04:02 AM
SomeCarGuy
So you didn’t even try to dump an 8 dollar bottle of stabilizer in to at least see if it would save you any grief? Engine went from dyno back to stand. Carb was drained of 50/50 pump 93 E10 / leaded race fuel and put on shelf. Residual fuel in accel pump circuit corroded. Not sure where the bottle of stabilizer was supposed to used in this situation. Dyno fuel cell...
[Re: SomeCarGuy]
#2461374
03/05/18 10:10 AM
03/05/18 10:10 AM
BradH
So you didn’t even try to dump an 8 dollar bottle of stabilizer in to at least see if it would save you any grief? Engine went from dyno back to stand. Carb was drained of 50/50 pump 93 E10 / leaded race fuel and put on shelf. Residual fuel in accel pump circuit corroded. Not sure where the bottle of stabilizer was supposed to used in this situation. Dyno fuel cell... Not my dyno. Guess I r an an idjit.
[Re: BradH]
#2461471
03/05/18 02:07 PM
03/05/18 02:07 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Got an 87 ford box van I bought new, 48,000 original miles, I use for my work. 460 ci. Might sit 4-6 months or longer at a time, starts right up and runs fine (holly carb) but all this talk has got me worried a little. If it ain't broke I ain't touching it. Always used whatever was at the pump, leaded reg at first, now 10% corn.
[Re: cudaman1969]
#2461472
03/05/18 02:15 PM
03/05/18 02:15 PM
BradH
Responses in no particular order... Andy -> My garage leads directly into my basement / psuedo shop; carbs are stored there where it's climate controlled Dominic -> If the PB Blaster soak doesn't free it up, mebbe I'll ship it to Hesperia for you to on it RTS -> Nope, no ultrasonic cleaner access of which I'm aware WHITEDART -> Ummm... yeah, pretty much; the more crap I'm seeing in my carbs, the I less want to leave it to chance they'll be good the next time I want to run 'em
