Re: Pertronix Problems - How Common? - Update
[Re: markz528]
#2386975
10/13/17 05:43 PM
10/13/17 05:43 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Well gotta give them thumbs up for customer service. Sent it back and got it back in a reasonable amount of time. Finally got it installed. Its much better! Started right up and did not have to move the oil pump drive a tooth to set the timing (from the points distributor location)! Right now they have earned my respect back. We will see how it performs at the track today.
[Re: markz528]
#2387082
10/13/17 09:51 PM
10/13/17 09:51 PM
RapidRobert
Well gotta give them thumbs up for customer service. Sent it back and got it back in a reasonable amount of time. Right now they have earned my respect back. That's good to hear. 440 source sent me a new dist for free after I broke a piece off in mine & I just asked them the availability/price of the new (miniscule) part and Rock Auto sent me a new set of head gaskets ASAP when they were damaged intransit & they didn't request any pics or anything.
[Re: Paul_Fancsali]
#2387259
10/14/17 11:12 AM
10/14/17 11:12 AM
markz528
Morrow, OH
Agree with the point install that said never had a issue with pertronix can't say that about the coils. If points work why not use them other then they are getting harder to find locally Well I don't know about dual points but on this stockish 383 the single points distributor started to break up a little around 4800 rpm - but not too bad. At the track the motor was dead by 5300 rpm. Last night with the Pertronix it pulled smooth and hard to 5500 rpm+ (that's where I shifted). Was at least 0.3 seconds faster with the Pertronix than the stock single points distributor. Maybe just this distributor, but it no work too good.
[Re: markz528]
#2387731
10/15/17 01:46 PM
10/15/17 01:46 PM
Posts: 16,117 Mesa, Arizona
dart4forte
Mesa, Arizona
I went with the Firecore Ready to Run and never looked back. Great tech support.
Abe Lincoln
[Re: markz528]
#2387765
10/15/17 03:47 PM
10/15/17 03:47 PM
Challenger 1
Cincinnati, Ohio
Glad to hear it ran well Markz. I have ran pertronix in quite a few vehicles over the years with no problems. They were used in work vehicles that got a lot of use everyday. Was better than points. Yup I said points! In the early eighties I was still working on gasoline fueled V8 engines in international tanker trucks. I adjusted/replaced points dozens and dozens of times on 4-5 trucks, then pertronix was a dream come true. Set it one time and forget it. No more dwell changes that happens with points. The only time I had trouble was on a lift/fork truck. I left the key on by accident without it running and it burns up the modgel. Found out about that the hard way. Other than that it has been a reliable ignition for me.
