Page 4 of 5 < 1 2 3 4 5 >
#2360821 - 08/27/17 07:47 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
JRepucci Offline
Loc: Sacramento,California
Carter Competition Series 625 CFM carb w/electric choke $125
#2360831 - 08/27/17 07:58 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
Eggman Offline
Loc: Georgetown de usa
Brand new in the box,Hughes whiplash 318 hydraulic roller camshaft. $250 shipped.
#2361407 - 08/28/17 08:40 PM Re: W2 & W5 Harland Sharp Roller Rocker Arm Kit-New [Re: vinnyd76]
Shaker223 Offline
Loc: Motor City
Mis post.
Edited by Shaker223 (08/28/17 08:48 PM)
11.02 @ 120 mph - Slant 6 & Turbo http://www.youtube.com/watch?v=EAxRmoDgsdY Chassis Dyno http://www.youtube.com/watch?v=wd6hFGzLJMc
#2361828 - 08/29/17 04:07 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
CFB Offline
Loc: Michigan
Brand New K & N Filter for Six Pak. New in the box and sealed in the plastic.
Asking $60.00
#2362020 - 08/29/17 08:47 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
mopar_muscle Offline
Loc: Idaho, USA
Holley carbs for sale. All need to be rebuilt but operate free. $50 each.
Holly # r4237, r1328, r2762, r3745, r3760, r3752, r1672
I cannot understand how to post pics here but can send to your email.
Contact me at mopar_muscle76@yahoo.com up
#2362239 - 08/30/17 09:35 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
walleyebum Offline
Loc: chicago,il
EDELBROCK-LD340-ALUMINUM-INTAKE-MANIFOLD-MOPAR-DODGE-CHRYSLER-318-360
WITH MOPAR PART #S 300.00 PLUS SHIPPING
Edited by walleyebum (08/30/17 09:39 AM)
#2362526 - 08/30/17 07:04 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
for sale 1968 340 small block SHORT BLOCK motor been cleaned at machine shop std bore std std steel crank, rods checked with new arp bolts,new rods and main bearing .new brass freeze plugs,new cam bearing . stock 10.5-1 pistons ,new rings ,new blue head gaskets. good used hp comp timing chain and gears , front timing cover ,and balancer ,new fuel pump,used water pump.$1750. also have a new set of std speed pro power forged pistons CR 11-1 to 12.5 to 1 depending on cc of heads extra $250. everything $2000.pick up ohio if interested send me a email at moparraceman@aol.com will send more pictures thanks
Edited by junkyardmaxie (08/30/17 07:05 PM)
#2363076 - 08/31/17 08:05 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: blewbyu]
mattsmopars Offline
Loc: tennessee,usa
318 poly 2x4 intake. Part number is 1822004. it has some wooden spacers on it that I took off for one pictures. Nice original intake manifold. the oil splash shield on the bottom needs a little straighten up from being set around while off. Other wise I don't see any issues. Asking $400.00 plus the shipping cost. I have several pictures that I can email interested parties just PM me here.
Thank you, Matt
Edited by mattsmopars (08/31/17 08:07 PM)
#2363248 - 09/01/17 02:02 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
MaddoxMopar Offline
Loc: Centennial Colorado
Wtb 360 LA, located in Colorado. Let me know what you have! Thanks. Pm on here or at jmaddoxyota@gmail.com
#2363352 - 09/01/17 09:17 AM 2 running 1967 273 2bbl engines [Re: davesmopars]
440PURSUIT Offline
Loc: DC, MD Suburbs
Both in 67 Barracuda's.
Start and run. $350 or offer.
Also have working 904 trans attached
1966 Hemi Belvedere II,
1968 Hemi Road Runner,
1969 Hemi Charger R/T,
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
#2364626 - 09/03/17 01:11 PM Small Block Fluidampr - New [Re: schmitty]
Rocket Offline
Loc: CT
I have a new small block fluidampr part # 712420 that I purchased but will not be using. I purchased this a number of years ago and has been boxed and on the shelf.
Price is $375 shipped to the lower 48 states.
Contact me at procketrichard@hotmail.com for more information.
Edited by Rocket (09/03/17 01:14 PM)
#2364627 - 09/03/17 01:13 PM 360 small block 4 bolt main cap kit - new [Re: Rocket]
Rocket Offline
Loc: CT
I have a new 4 bolt main cap kit Mopar Performance part # P5249675 for 360 engines. These are the same main caps used for Mopar R series race blocks. They are ductile iron. They are a superior material to stock caps and use more material for strength. You can use these on a stock 360 block without using the outer bolt holes. Some builders cut off the outer 2 bolts for ease of installation. A great upgrade for stroker engine builds. Kit comes with 4 caps and bolts.
I have attached an example of what they look like when installed with the outer 2 bolts machined off. I used a similar 340 main kit (middle 3 caps only and sI did not have the first cap) on a 340 stroker I built.
This 360 main cap kit lists for $180 on summit. I will sell it for $140 shipped in the lower 48 states.
#2365064 - 09/04/17 09:09 AM Mopar 426” sb 651hp street/strip motor [Re: moparts]
WadeMetzinger Offline
Loc: Tulsa, Ok
Mopar 426” small block
340 X block with splayed billet main caps and ARP fasteners, bushed lifters, decked/squared to 9.585, align honed, stroker clearanced (machine work performed by DRAM Dan Costello at Performance Only in Florida)
360-1 Indy heads ported by Dwayne Porter, with Harland Sharp rockers
K1 4.125 stroke crank with Chevy rod journals
Callies Compstar H-beam rods 6.200”
Diamond Custom forged pistons 4.060 bore, 1.308 comp height, Valve relief volume -6.7
Indy 360-1 Intake also ported by Dwayne Porter
Also includes a Mopar M-1 single plane intake modified to fit for street hood clearance
Hughes Engines custom street/strip billet roller cam and solid roller lifer designed specifically for this build by Dave Hughes
Made 651 hp and 585 torque on the Dyno with 91 octane pump gas, will make 700+ with race fuel and more timing.
All parts new except Heads, which only have about 200 passes on them and they they were freshened for this build.
text or email for pictures 918-809-0987
$18,500 less carb (no trades)
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.70@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
#2365203 - 09/04/17 12:38 PM 340 w/727 External balance flex plate [Re: WadeMetzinger]
racerx20 Offline
Loc: Houston, Texas
Cope Racing 340 external balance flex plate for use with external balance 340 and neutral balance torque converter. Light use, no racing. $80 shipped to the lower 48.
Cope Racing
1969 Dart 408 W2
533 HP
540 ft lbs
1979 Lil Red Express
born the same month and year as me!
#2366520 - 09/06/17 04:02 PM 1965 273 long block for sale [Re: moparts]
Hollywood Offline
Loc: Springboro, Ohio
I just pulled a running 273 out of a 1965 Barracuda automatic with AC. It was rebuilt by Jasper 17 years ago. Was still running with no noises. The reason for replacement is it had 55% leakage past the rings Mechanical valve train. Unknown bore size. Best offer. Located in Dayton, Ohio. Local pickup only.
[img:center]https://flic.kr/p/YgnkDa[/img]
Edited by Hollywood (09/06/17 04:07 PM)
#2366771 - 09/06/17 11:40 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
82ramIndy493 Offline
Loc: crisfield, maryland 21817
For sale is a Carter carb # 9636 which I believe is a replacement carb for the 340 and 383 engines but I am sure with fine tuning it could be used on a variety of applications. I bought this for a project but the project has been sold so I no longer need the carb. I have removed the top to show you how clean the carb is and that all the linkages and shafts and also the air fuel screws work great. Asking price for the carb is 130 dollars shipped within the 48 states. PM me here or message me at "samson1156@verizon.net" with questions or purchase info. Thanks and have a great day.
Edited by 82ramIndy493 (09/06/17 11:41 PM)
#2368342 - 09/10/17 01:09 PM Indy 360-1 bare heads. *NEW* [Re: moparts]
CompWedgeEngines Offline
Loc: Syracuse,NY
I have one set of Indy 360-1 bare heads, untouched, unported, brand new.They have the extra bolt holes for R3 type blocks.
I bought these for my own project years ago, and simply dont have time to get to them, or my project for that matter. My loss, your gain.
$1200 for the pair, bare, new. No valves, no parts.Indy racer price is $1785 a pair. Plus shipping. I ship Fed Ex.
I cannot do any work to these, so if you want head work done, you'll need to have your own shop do the work. I am just slammed right now and full for the Winter.
DO NOT reply to this post or PM me. Please use my email: compwedgeracing ( at) aol.com Make sure to put INDY360-1 in title, or it may not get read.
Cash or money order only. No credit cards.
Thank you.
RIP Monte Smith
#2368349 - 09/10/17 01:23 PM Indy RHS LAX/MAX cylinder heads * NEW* [Re: moparts]
Loc: Syracuse,NY
I have two sets of Indy RHS cast iron heads.
1) MAX, Magnum style rocker set up, new untouched, no work done Indy racer price, $880, take these for $650 plus shipping. ( they are heavy)
2) LAX stock shaft rocker style, with cleaned up bowls, flow around 275 cfm, valve guide cut for 11/32 valves, Indy racer price $880, take this set for $750 plus shipping.
These are really good heads, only down side is the weight, but they are nice thick robust casting, and they work very well.
cash or money order only. No credit cards.
DO NOT contact me here, please use my email: compwedgeracing ( at ) aol.com. Please put either INDY LAX or MAX HEADS in title, or it may not get read.
Thank You
RIP Monte Smith
#2368812 - 09/11/17 12:10 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: walleyebum]
don miller Offline
Loc: langley b.c. canada
Contact the seller via pm or e-mail. This is not a discussion forum!
Edited by tboomer (09/11/17 06:31 PM)
Edit Reason: not a discussion forum
#2368883 - 09/11/17 02:09 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
autoglasspro Offline
Loc: p.a.
New competition cams 20-601-5 solid camshaft for small block mopar $120.00 New solid lifters sbm $40.00 .Small block oil filter adapters,$ 75 each. 1971 Plymouth 340 duster factory air cleaner $350.00. Early70's thick wall 360 complete block minus oil pan $350.00. 3 Small block mopar bellhousings,$150.00 each. Prices are all best offer,thanks moparts. wlucki@ptd.net
Parts are in bethlehem PA
Edited by autoglasspro (09/22/17 10:28 PM)
24,895 Registered Members
184,140 Topics
66-70 B Body Trunk Dividers
by 71TA
Today at 12:48 AM
Advice on business idea
by SeaninSD
Today at 12:31 AM
64 Dodge Pick Up - Leaning Tower of Power
by 65pacecar
Today at 12:12 AM
67 Belvedere I
by 65pacecar
Today at 12:11 AM
