Page 1 of 5 1 2 3 4 5 >
#2329599 - 07/01/17 09:23 AM Mopar Transmission For Sale - 3rd Quarter
moparts Offline
#2329602 - 07/01/17 09:25 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
64dodge572 Offline
Loc: Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts specialists.
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
www.brewersperformance.com
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars from $240.55
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $279.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $329.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 ea
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 ea
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $59.95
Clutch pedal over center spings $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 ea
Shifter linkage rod sets for A B & E body cars $124.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $49.95-$56.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 68-9 4-speeds $10.95 ea
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $8.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $99.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $218.03, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $89.95, wiring harnesses from $29.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1099.95
Polyurethane transmission mounts from $59.95
Speedometer cables from $39.95, speedometer pinion gears from $19.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce and McLeod clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
#2329705 - 07/01/17 11:54 AM Small Block QuickTime Bellhousing - New [Re: 64dodge572]
Rocket Offline
Loc: CT
For sale is a new QuickTime SFI approved bellhousing to mate small blocks to the new process 3 speed or 4 speed (A833) transmissions. Part number is RM-6072. The bellhousing includes the block plate, hardware and adapter ring to allow use of the 4.35” bearing retainer to the 4.8” hole in the bellhousing. If your transmission has the 4.8” bearing retainer then no adapter ring needs to be used.
Some information for the Summitracing site
SFI-Approved: Yes
Safety Rating: SFI 6.1
Bellhousing Depth (in): 7.400 in.
Bellhousing Material: Steel
Bellhousing Finish: Black
Notes: Uses 130-tooth flywheel and no larger than 10.5 in.clutch. Transmission bore is universal 4.807”
QuickTime bellhousings are designed for Circle Track, strip, and street applications. Built from high-grade steel, the cone is spun, not rolled or stamped, allowing these bellhousings to be the most dimensionally stable and accurate for today's high performance vehicles. They offer proven performance and are built right here in the USA. Choose the size and specs needed for fitment on your particular vehicle, then bridge your transmission and engine with a QuickTime bellhousing.
Summits price is $692. I am selling this new bellhousing for $580 shipped in the lower 48 states.
#2329799 - 07/01/17 02:34 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
#2329800 - 07/01/17 02:35 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
#2329803 - 07/01/17 02:37 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping and handling charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
#2329804 - 07/01/17 02:38 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
#2329811 - 07/01/17 02:48 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is black oxide coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each for the strut, and $28.00 each for the anchor and includes shipping anywhere in the USA.
Email mrrandyj@aol.com
#2329893 - 07/01/17 05:52 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
A-body big block 4-speed parts: Included are a 4-speed bell housing #2468372, bell housing inspection cover, big block clutch fork, big block A-body z-bar, new big block A-body z-bar bell housing and frame ball pivots, new ball stud seal, 2 new clutch linkage washers and a new throw-out bearing as shown in the picture. I have had the bell housing, inspection cover and clutch fork media blasted. The bell housing and clutch fork are primed. The inspection cover has been painted gloss black. I have also blasted and primed the z-bar since the photo was taken. $750 for everything. Selling only as a package. I would prefer not to ship but can deliver to the Mopar Nats with a $100 non-refundable deposit. gt340 at yahoo.com
#2329946 - 07/01/17 07:48 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
65 big block 727 torqueflite,the one with the rear slip spline.It was rebuilt about 5 years ago and has not been used since then.New solid bands,clutches,all seals and paper are new,also has the later model input splines for the converter.IT wouldn't hurt to freshin the bands and clutchs in some tranny fluid before use.Also has a stock 65 valvebody with the correct rooster comb.I can supply a different VB if that wont work in your car.$700 and local pick-up only.Bill at wmemore@aol.com or PM,Thanks for the free ads Moparts.
Edited by Goat330 (08/08/17 09:19 AM)
#2329947 - 07/01/17 07:50 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Goat330 Offline
1992 A-518 O/D tranny.Was rebuilt many years ago for a forgotten project and put on shelf and never used.It has new solid bands,raybestos clutches,new seals. It should be pulled apart and re-lubed inside before it's used and it is a lock-up trans.,local pick-up only.Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!SOLD
Edited by Goat330 (07/10/17 03:22 AM)
#2329948 - 07/01/17 07:51 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Goat330 Offline
I have several slant 6 904s from early 70s darts laying around $20 each.Also have a couple of small block 727s for cores $30 each.Local pick-up only,Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!
#2330251 - 07/02/17 03:28 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
T2R9 Offline
Loc: Conway, SC
67 valve body with TF2 shift kit. Excellent working condition. I removed it from my 72 Charger for the correct one. $75 delivered to Carlisle.
Moroso 42080 Tig welded aluminum deep pan. Excellent condition with all hardware. These are $221 on Summit. $125 delivered to Carlisle. PM is fine.
1973 Charger SE 400 HP
1978 Power Wagon 440 club cab, skylite
1995 Dakota Sport 5.2 5-speed
2016 Challenger R/T Shaker Plum Crazy
#2330695 - 07/03/17 12:14 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Slap Shot Offline
Loc: Dover,Pa
A body 23 spline 4 speed transmission $500 717 577-0270
#2331381 - 07/04/17 12:31 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
slantzilla Offline
Loc: Park Forest, IL
8" PTC race converter for 904. Stalled 3400 behind my 240" junk on the footbrake. Few passes, no street miles. Can text pics on request. $500 OBO plus the ride. slantzilla@excite.com or PM here.
Thanks for the ad Tom!
#2331497 - 07/04/17 04:18 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
chooch Offline
Loc: pa
rebuilt 23 spline trans with all new parts from brewers 65 case with 70 up B & E body tail housing $1000 bo + shg
64-65 bell housing 10.5" 2468370 very clean in great shape with no cracks or messed up threads $350 +shg
can deliver to Carlisle with deposit will trade for max wedge parts
Edited by chooch (07/04/17 04:19 PM)
1974 pinto
1978 pacer
1987 yugo
#2331684 - 07/04/17 10:33 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: chooch]
Azzkikrcuda Offline
Loc: North Dakota
Turbo Action 10" converter for 727 Small and Bigblock. PN# 17805S Medium. Was in a 70 Challenger 496cid with 4.10 gear, around 10,000 street miles on it. Worked good, changed combo. $375+shipping PM me here if interested
Specs and info http://www.turboaction.com/s800.html
The only Carbs I care about are under the hood!
#2332377 - 07/06/17 08:18 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Azzkikrcuda]
MI Mopar Works Online   content
Loc: MI
This is a 10 inch torque converter for mopars with 727 Torqueflite transmissions. This is a custom built piece from Ultimate Converter. It has very little use. 5 passes and some light street time. It is in excellent functioning condition, just too tight for my combo. It flashes between 3200-3500 RPMs. Original cost was almost $1000. My loss is your gain. Asking $450 OBO. Call Dave (734)624-2212 or pm me here.
MI Mopar Works
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
#2334022 - 07/09/17 10:03 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
moparjoe360.4 Offline
Loc: Ohio
64-65 Hemi STEEL bellhousing, casting #2463236, all treads look good, we don't have the inspection cover. I'm listing for my dad, pm me here for his contact info or with questions. Asking $1000 OBO but he's negoable
#2334246 - 07/09/17 04:21 PM B & M #10238 offset weighted Flex plate [Re: moparts]
jlatessa Offline
Loc: Ohio
This is the plate, (currently not available) needed for a RB with the big rods.
It is the mate for the offset weighted harmonic balancer on those engines.
It allows you to use any converter and not have to weld compensating weights
for the rods as MOPAR did.
Used, but in very good condition.
$40 plus shipping, (about $15 via USPS Priority Mail Box).
Joe
Four Four Zero- 376-Zero Nine Seven Eight
Or PM me, Thanks
#2334437 - 07/09/17 10:18 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
904 Small Block Street/Strip trans fresh rebuild new T/A RMVB w/CRT special spring to boost line pressure, Special spring in front drum to stop it from unwinding on top end,5-thin RR clutches/kolene steel's front drum,4-RR clutches/kolene steel's rear drum,New CRT 1.6 W flex RR H.D. reinforced KD band,new CRT RR rear band H.D. band strut,4.2 lever,New billet rear servo,stock front servo/W-2 springs,acc.blocked,low gear set W/4-pinon steel front/rear planetary,new deep pan,case modified vent moved to rear, external reg adj., converter access, modified oiling system,with lightened internals and new stock oil pump gear. Call or text for pics. Can deliver sat at Carlisle if half paid before event. 724-208-4570. $1,350
#2335386 - 07/11/17 02:12 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
Mopar stock low gear set with 4-pinion steel planets front/rear for 904 trans. $175 have 2-set up Transgo TF-2 shift kit for 727/904 just rebuilt $150. Call or text for pics can deliver to Carlisle. 724-208-4570.
#2335390 - 07/11/17 02:20 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
Mopar stock rebuilt 727 small/big block transmission and stock 904 small block trans $500ea.Call or text for pics details. 724-208-4570. Can take to Carlisle if half paid.Other trans and parts available.
#2336777 - 07/14/17 12:22 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
ehbody Offline
Loc: Toronto, ON
For sale. SOLD for $350
Two 4speed transmissions 23 spline and One transmission case
All are short tail. Probably for A-body or B-body.
One is disassembled, and probably missing small parts.
One empty case.
Also Small block bellhousing for 72-73 for 318 or 340 for ABE body. All threads are good and clean.
Could be for Roadrunner, Duster, Dart, Cuda or Barracuda.
Local Pickup Only in Toronto. :-)
Edited by ehbody (09/08/17 10:29 PM)
Shawn 70 AAR
#2337271 - 07/15/17 08:48 AM Sold [Re: moparts]
Robbins Offline
Loc: Joplin, MO USA
Thanks Moparts.
#2338291 - 07/17/17 10:01 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
cdp Offline
Loc: MO
New MP 727 deep chrome pan. Complete, less box. Correct extender, bolts, gasket, filter.
SOLD. Thanks Moparts.
Chrispy1971gtx@yahoo.com
816 726 4512
Edited by cdp (09/15/17 01:11 AM)
#2338323 - 07/17/17 10:55 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Jason B Offline
Loc: Mopar
1- Complete 904 Transbrake transmission with A&A Transbrake and Aluminum front drum. Transmission is complete and in the car running now has 8 passes since fresh rebuild no issues. $2000.00 OBO - SOLD
Contact Jason Buckner 936-577-1648
ALSO FOR SALE:
1- ATI- Transbrake convertor fresh 8 passes flashes at 5600 RPM. $750.00
1- Turbo action 8" trans brake converter 5800 flash neck has a crack needs to go back for service. 250.00 - SOLD
1- turbo action air shifter reverse pattern 300.00
1- turbo action shifter reverse pattern 150.00- SOLD
1- turbo action shifter console 25.00
Edited by Jason B (07/24/17 10:07 PM)
1968 Cuda 440" Edelbrock Victor Head Small Block.
#2338513 - 07/17/17 04:24 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
DudleyPerformanc Offline
Loc: North Carolina, USA
After Market Linkage Set Up out off a 71 Road Runner Drag Car.
Fits Hurst Shifter. Will Have to modify the tunnel.
$180
Located in Walkertown NC
(Near Winston Salem)
PM here or
Contact Mark
Shop 336-595-2000
cell 336-399-7262
[img:center]http://[/img]
Edited by DudleyPerformanc (08/30/17 08:49 AM)
Mark Dudley Performance and Parts
Walkertown, NC 27051
(336) 399-7262
We offer a complete line of High Performance
Parts, Engines, Transmission and Body needs for
1960-1970's Mopar's from Street to Strip.
#2338517 - 07/17/17 04:32 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mr Gasket Vertigate
4 Speed A833
$450
(near Winston Salem)
PM here or
Contact Mark
shop 336-595-2000
cell 336-399-7262
(336) 399-7262
#2339093 - 07/18/17 12:08 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: DudleyPerformanc]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
made in the usa 1969-1989 904/727 neutral safety switchs with seals DODGE,PLYMOUTH,CHRYSLER$24 each mailed
cowgerwilliam035@gmail.com
Edited by Joesixpack (07/19/17 09:56 AM)
#2341712 - 07/22/17 08:44 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Rapid340]
Rapid340 Offline
Loc: oberlin, Ohio
Hearst vertigate shifer, new
$395 plus shipping
jeffpatterson@copper.net
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2342185 - 07/23/17 09:13 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Rapid340]
kyle340 Offline
Loc: Louisville, Ky
1965-68 neutral safety switch for a 727, nos part #3004087 brand new still in the box, $65 email rtsalvage@att.net
#2343047 - 07/25/17 11:56 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: kyle340]
Joesixpack Offline
rebuilt v8 904 68 trans, cheetah RMVB,deep pan,mancini hp rebuild kit was used,was my spare.pick up in AZ$450
#2343051 - 07/25/17 12:01 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Joesixpack]
Joesixpack Offline
used 2.74/1.55 904 low gear set. complete $100 plus ups
#2343056 - 07/25/17 12:06 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Joesixpack]
Joesixpack Offline
Fits: A904
Chrysler 2.250 in. Depth; Incl. Magnetic Drain Plug
Transmission Pan Material: Aluminum
Transmission Pan Finish: Natural
Transmission Pan Style: Deep
Drain Plug Included: Yes
Filter Extension Included: Yes
Filter Included: No
Gaskets Included: No
Bolts/Studs Included: Yes
Temperature Sender Bung Included: No
Quantity: Sold individually.
Notes: Fully fabricated from lightweight aluminum and features a one-piece billet rail.
Moroso has turned its attention to the design and manufacturing of premium-quality transmission pans. Moroso transmission pans are fabricated entirely from lightweight aluminum and feature a one-piece billet rail to ensure leak-free sealing. Precise CNC manufacturing and TIG welding prevent distortion for a perfect fit every time. Pans with extended depths reduce temperature and improve oil control during acceleration and braking. They include filter spacers on extended-depth versions where needed. All Moroso transmission pans include dual fittings (except MOR-42050) with magnetic drain plugs and pan
new in the box $200
#2343328 - 07/25/17 08:23 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
SOLD For sale A833 aluminum case OD 4 speed and small block bell housing, has cast iron tail shaft with dual shifter mounts,23 spline, came in parts car I bought, had oil in it and turns over by hand in gear. $250 would rather not ship, pick up in Spring Valley MN 55975. PM on board. SOLD
Edited by gtsdude (08/22/17 05:10 PM)
#2343701 - 07/26/17 12:30 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: 6PAX]
granny53 Offline
Loc: new jersey, usa
PP833 TRANS CASE WITH REVERSE GEAR & LEVER & BACK UP SWITCH DATE CODE 3406 - 11-24 $250. CLIFTON NEW JERSEY 07011 201-618-2758 E-MAIL PTRTESTER@YAHOO.COM SMALL BRG 833 CHRYSLER 4 SPEED BRASS FORKS $60.
#2344107 - 07/27/17 07:18 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
ric3xrt Offline
Loc: Sellersville Pa
Pair of Big block 727 4x4 truck trans no Transfer cases.
Both pulled 10 years ago, one's a 78 the others a 77.
$400 the pair.
ric3xrt@yahoo.com 267 347 2826.
PM me here , I try and check in here once a week your better off emailing me.
I'll take whatever photos you want just let me know.
Truth has no agenda, but those with an agenda don't always acknowledge truth
1975 D-code D100
1975 D-code Ramcharger
1977 D-code Warlock
1977 D-Code D100
1978 D-code Mid Nite Express
1978 Lil Red
1979 Lil Red
2004 Rumble Bee
2005 Ram GTX
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building
2014 1500 tradesman(shhhh, it's hiding a 6.4 short block under those eagle heads.
#2344171 - 07/27/17 09:10 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1971 to 1974 B-body and 1970 to 1974 E-body NOS shifter boot bezel, part #2996415 $150.00 (708)288-2879 Scott
#2344175 - 07/27/17 09:15 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
426 HEMI 727 torqueflite front drum, rear drum and brand new band, all parts are in excellent condition $750.00 for everything (708)288-2879 Scott
#2344183 - 07/27/17 09:20 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1962 and 1963 Max Wedge T-85 3-speed transmission $2500.00 also have the correct aluminum bellhousing for the T-85 $650.00 (708)288-2879 Scott
#2344494 - 07/27/17 07:15 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1966 and 1867 B-body 426 HEMI bellhousing for direct drive starter, casting #2780512, excellent used condition $1150.00 (708)288-2879 Scott
#2344495 - 07/27/17 07:16 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: dsd70bee]
dsd70bee Offline
Loc: oak park, il.
1968 and 1869 B-body 426 HEMI bellhousing for direct drive starter, casting #2892259, excellent used condition $1450.00 (708)288-2879 Scott
#2345268 - 07/29/17 11:54 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
** SOLD **
1969 four speed manual transmission. Heavy duty 18 spline from a 1969 Charger R/T vin XS29L9B. Out of long term storage, appears to be in good shape.
For sale locally in New Jersey zip code 08077, can not ship this.
Price is $1,550.00 with correct 11 inch bell housing cast #2892626 or $1,100.00 for just the transmission.
Please email ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (08/14/17 08:42 AM)
#2346267 - 07/31/17 02:40 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
mrploww Offline
Loc: Marysville, OH
65 big block 727 TorqueFlite,the one with the rear slip spline.It was rebuilt last year ago and has not been used since then.New solid bands,clutches,all seals and paper are new,also has the later model input splines for the converter. Also has a stock 65 valve body with the correct rooster comb.Was rebuilt with a shift kit and told it will chirp the tires from 1st to 2nd. This transmission is date coded August 1964, which makes it for model year 1965.
$800. I can ship it. Located in central OH.
Edited by mrploww (09/05/17 01:55 PM)
'64 Plymouth Belvedere 9 passenger surf wagon
#2347109 - 08/02/17 12:30 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrploww]
dsd70bee Offline
Loc: oak park, il.
1962 to 1965 B-body original clutch fork in nice used condition $75.00 (708)288-2879 Scott
#2348637 - 08/04/17 06:28 PM A833 Hemi 4-Speed B/E-body [Re: moparts]
Rick_Ehrenberg Offline
Loc: Marlboro, NY, USA
Freshly built dual-shifter-pad Hemi 18-spline A833. Built with 100% NOS Mopar parts, no Chinese crap. New synchros, bushings, bearings, needles, thrust washers, and seals. Brass forks and best side cover / interlock setup. Big bearings throughout, 4.805" (std. Hemi, 440). Bolt in and burn rubber.
First $1,950 takes it.
Can deliver to Mopar Nats (with a deposit), or you can pick up here (about 60 miles N. of NYC), or I will build a crate for it (cost: $75) and ship it FedEx ground on your dime.
I have lots more pix if desired, including the buildup process.
Contact via email only
rehrenberg@yahoo.com
#2350909 - 08/08/17 05:29 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
CompSyn Offline
Loc: Pacific NW USA
SOLD! Thanks moparts!
Edited by CompSyn (08/14/17 07:17 PM)
Project 1969 Plymouth Road Runner 383/727/3.23 F5
#2353438 - 08/13/17 11:13 PM 3-Speed Manual Trans & Parts [Re: moparts]
C_B5 Offline
Loc: Ohio
Manual Trans Parts from a Slant 6
3-speed transmission early style w/ parking brake on tailshaft $100
Bellhousing $50
Brackets $10-$20 each
Shifter rods $20
Clutch fork $15
Z-bar $15
Slip yoke $15
Inspection cover $20
Cross Member mounting bracket $30
ALL plus shipping
Prefer Local Pick-up for the trans
Individual parts or package deal
Send PM or email c-b5@zoominternet.net
#2353442 - 08/13/17 11:23 PM SmallBlock 340 Bellhousing [Re: moparts]
C_B5 Offline
Loc: Ohio
4-Speed Bellhousing Original Factory part
10.5" Small block bellhousing
Cast #3515734
Excellent used condition
Correct for 1972-74 A-body and 1972-74 E-body models with 340 engines both 3 & 4-speeds (will also fit 70-71 A and E-body)
$225.00 plus shipping
#2355305 - 08/17/17 06:49 AM 1968 18 spline Hemi 4 speed trans [Re: C_B5]
Mopucky Offline
Loc: New York
Selling 1 good rebuildable 18 spline trans. Splines and inputshaft in good shape. $1450
1969 "626" bellhousing available for $450
Hurst shifters also available, console and non
PM me here if interested. Thank you!
#2355438 - 08/17/17 11:33 AM 1970 Mopar Hemi 4 Speed B or E Body New Fresh Pro Rebuild [Re: moparts]
challengersteve Offline
Loc: NW Arkansas
I have a freshly rebuild 1970 B or E Body Hemi 4 Speed for sale. This was a very clean, virgin unit that we completely rebuilt in our shop. The cases were all cleaned and blasted to bare cast iron and then painted in cast iron epoxy for protection. All the original gears and internal hard parts were very nice so they were just cleaned and reused. All syncros, bearings, seals, reverse light switch, tail bushing, roller bearings ect were replace with top quality components from Brewers. The input bearing retainer is a new repro from brewers as well. This is a super clean transmission with absolutely no pitting and never any damage to the case and is ready to install.
The price is 2250.00 outright (no core needed). Shipping will be extra and this will have to ship truck freight.
Please call Steve at 479-430-4886 for more info.
http://www.StevesParts.com Steve@StevesParts.com
shop 479-632-0011
cell 479-430-4886
#2356674 - 08/19/17 03:48 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
NOS in the box 1969 and up three prong neutral safety switch $60.00 (708)288-2879 Scott
#2357511 - 08/21/17 09:50 AM NOS 4 Speed Wood Grain Shifter Ball [Re: dsd70bee]
davesmopars Offline
Loc: cheshire, ct
Had 3 of them
Only One Left
500.00 plus shipping
#2357519 - 08/21/17 10:02 AM NOS B Body Hurst Super Shifter [Re: davesmopars]
davesmopars Offline
Loc: cheshire, ct
In the original Box
550.00 plus shipping
#2357522 - 08/21/17 10:06 AM BO29 or LO23 Hurst Auto Shifter [Re: davesmopars]
davesmopars Offline
Loc: cheshire, ct
BO29 or LO23 Hurst Auto Shifter with cable and harness
in real nice shape
1200.00 plus shipping
#2357527 - 08/21/17 10:13 AM 1970 B and E Body Big Block Bell Housing [Re: davesmopars]
davesmopars Offline
Loc: cheshire, ct
1970 - 71 B and E Body Big Block Bell Housing
casting number 2892513
400.00 plus shipping
#2358279 - 08/22/17 06:29 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
[SOLD]Z bar with linkage and 10.5 inch clutch fork, came off 73 B body small block car. $50 plus shipping from 55975.[SOLD]
Edited by gtsdude (08/27/17 11:09 AM)
#2358286 - 08/22/17 06:36 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
[SOLD]B body 4 speed shifter mount with screws to attach it, came off a 73 B body 4 speed, $35 shipped to lower 48 states.[SOLD]
Edited by gtsdude (08/27/17 11:06 AM)
#2358291 - 08/22/17 06:39 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
[SOLD]Shifter linkage look to be correct for the 73 B body they came off of, linkage on top looks to be bent. $60 shipped to lower 48 states.[SOLD]
#2358811 - 08/23/17 08:43 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have an original Chrysler 833 10.5 manual transmission dust shield. Part number is visible. Very good condition, no dents, could use a better paint job though. Selling for my intial investment at $65.00 plus actual postage. Best to all 260-223-zero 8 six eight up until 8pm est or schmittyjsathotmaildotcom Thanks Moparts!
pictures view at:
https://www.flickr.com/photos/153253365@N06/36766663995
Edited by schmitty (08/23/17 08:44 PM)
#2361775 - 08/29/17 01:53 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: schmitty]
hector Offline
Loc: Texas
cool 1967 or 68 Dart 4-speed Inland shifter assy. (no shift rods) in very good condition. $225.00 shipped within the 48 states
Thank you Moparts! prefer email: hrt4867@yahoo.com for more info
Description: Inland shifter assy
Edited by hector (09/16/17 12:42 AM)
#2362725 - 08/31/17 06:13 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: hector]
dsd70bee Offline
Loc: oak park, il.
1969 383, 440 and 440 SIX PACK 11 inch bellhousing, casting #2892626, not cracked, I have ran a tap down all the threaded holes and there are no stripped threads, excellent used condition $450.00 (708) 288-2879 Scott
#2362726 - 08/31/17 06:21 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: dsd70bee]
dsd70bee Offline
Loc: oak park, il.
1970 to 1974 383, 400, 426 HEMI, 440 and 440 SIX PACK 10 1/2 inch bellhousing, casting #2892513, not cracked, I have ran a tap down all the threaded holes and there are no stripped threads, excellent used condition $400.00 (708) 288-2879 Scott
#2364134 - 09/02/17 02:39 PM Small block transmission dust/gravel shield [Re: moparts]
Scotts72Rallye Offline
Loc: Third Stone from the Sun
Dodge, Plymouth A-727 318,340,360 transmission dust/gravel shield. Includes the always missing inspection hole cover.$90 shipped in the lower 48 states. PM here if interested. Thanks
Edited by Scotts72Rallye (09/02/17 02:44 PM)
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
#2364447 - 09/03/17 09:02 AM NOS Scalloped 10.95" pressure plate, original Chrysler part [Re: Scotts72Rallye]
sawdust Offline
Loc: Green Lane, PA
NOS, box fell apart, but pressure plate is new unused, bolted to flywheel but never run. Scalloped design pressure plate for 426 Hemi and 440 Mopar original Chrysler part not aftermarket. $175 shipped.
PM me here or email, info@kriebeldesigns.com
Edited by sawdust (09/09/17 08:43 AM)
1967 RO23 4 speed
1967 RO23 4 speed "Poison Ivy"
1967 RO23 4 speed "A-Town Hustler"
1967 NSS Belvedere Post 4 speed
1970 Triple red hemi cuda
2016 PCP Hellcat M6
#2365107 - 09/04/17 10:31 AM 1969 A833 SOLD Thank you Moparts [Re: moparts]
ric3xrt Offline
Trans came out of a 69 383 4 speed Charger. Date on the Tail is 2/4 /69 Side pad reads A9260795
2769 , I had this trans in a 77 D150 for about 6 years pulled it out in 2008, 1st gear syncro broke.
Tried to take a Photo of the crack but it doesn't show up.
No side cover, bearing support is broken. This is a 307 bearing trans.
The Input shaft will be removed for shipping and placed in a bag with the needle bearings and main bearing.
$150 flat rate shipping to the lower 48, no international shipping.
I'll deliver this box up to 150 Miles from 18970 for $ .50 mile
Edited by ric3xrt (09/11/17 11:26 AM)
1975 D-code D100
1977 D-code Warlock
1977 D-Code D100
1978 Lil Red
1979 Lil Red
2004 Rumble Bee
2005 Ram GTX
#2369365 - 09/12/17 11:05 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1968 and 1969 18 spline HEMI 4-speed transmission, rebuilt about 8 years ago and never installed in a car $2200.00 (708)288-2879 Scott
#2370952 - 09/14/17 08:07 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
sparcy Offline
Loc: dracut mass usa
i have a big block steel lakewood bell housing with plate 75.00 pick up only dracut mass 01826 978 771 0133
#2371848 - 09/16/17 06:06 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: dsd70bee]
BB70DUSTER Offline
Loc: SO CAL
1968 Hemi 18 Spline 4 speed transmission, was told it's in good working condition, your welcome to inspect it if your local, prefer a local sale, $1500
#2372422 - 09/17/17 08:38 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
belvedere383 Offline
Loc: Somerset, VA
Strange U1607 8.75 pinion yoke.
This yoke is brand new in the box, never installed.
This fits 10 spline pinions and is a 1350 style u-joint.
Price - $80.00 shipped in the lower 48
65' Belvedere
496'' Stroker
Indy Heads
#2373024 - 09/18/17 09:06 PM J.W. Powerglide for sale or trade [Re: moparts]
440W8 Duster Offline
Loc: San Antonio,TX
I have a JW trans Ultra Case Ultra Bell Roller tail shaft with 8in stalls at 5400 UCC converter with flywheel for a Small Block for sale or trade has Pro Brake 1.80 straight cut gears asking $3000 or
trade for a 904 or 727 with pro brake billet front drum and 8in converter with similar stall and a CSR fiber shield plus cash my way.
Edited by 440W8 Duster (09/19/17 12:08 PM)
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
#2373303 - 09/19/17 12:09 PM '66-'68 Inland Shifter Assembly [Re: 440W8 Duster]
GTX MATT Offline
Loc: CT
Non-console '66-'68 B body Inland Shifter. This is the lever with a new upper boot, correct knob, shift box, lower boot, and shift rods. It came out of my car as a good functioning assembly, including the reverse lockout. The lever needs to be re-chromed and the box and rods could use a good cleaning, but its all there. - 400 plus shipping
E body Hurst shift rods - all 3 - $100 plus shipping
#2373315 - 09/19/17 12:31 PM Fresh Rebuild by Brewers A833 4 Speed Transmission - SOLD [Re: moparts]
82firebird Offline
Loc: NE Ohio
Fresh A833 4 speed transmission. Rebuilt by Brewer's Performance. This transmission is a fresh rebuild from June, 2017. It has never been installed and is still in the plastic wrap and original shipping box. Intended for a 71 Cuda, will fit many others. I have the paperwork showing parts, what was replaced, etc. 23 spline, 2.66 1st gear. Shipping to commercial address or freight terminal pickup only. Local pickup welcome. Akron, Ohio. SOLD
Edited by 82firebird (09/29/17 02:46 PM)
#2373551 - 09/19/17 07:03 PM Re: Fresh Rebuild by Brewers A833 4 Speed Transmission - $1,400 [Re: moparts]
408Dust Offline
Loc: Florida
Brand new A-1 7 inch 904 converter no runs. 1,000.00 obo. plus shipping from 33811
#2374426 - 09/21/17 09:35 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Goat330]
PSRacing1 Offline
Loc: livonia mi.
hello , any manual trans ? / looking for overdrive stick shift for a 225 s/six , street rod project . thanks ,
#2374434 - 09/21/17 09:48 AM Re: 3-Speed Manual Trans & Parts [Re: C_B5]
PSRacing1 Offline
Loc: livonia mi.
hello , what do you know on the condition of the trans ? Fill me in - interested . Patrick . Michigan
#2374490 - 09/21/17 11:33 AM expired TCI Glide shield and flexplate shield [Re: moparts]
johnnyd Offline
Loc: Boston, MA
TCI powerglide transmission and flexplate shields. Expired SFI. Red SOLD!!!
more pics here:
https://boston.craigslist.org/sob/pts/d/tci-powerglide-transmission/6315017088.html
Edited by johnnyd (09/29/17 01:10 PM)
#2374492 - 09/21/17 11:36 AM TCI Mopar to power glide adapter plate [Re: moparts]
johnnyd Offline
Loc: Boston, MA
TCI BBM to powerglide adapter plate. Already trimmed for a dragster and glide. Small crack in between bolt holes- can be TIG'd for easy repair $100
more pics
https://boston.craigslist.org/sob/pts/d/tci-bbm-to-powerglide-adapter/6315013142.html
#2375683 - 09/23/17 07:41 PM Re: TCI Mopar to power glide adapter plate [Re: johnnyd]
Joesixpack Offline
2538608 SPEEDO CABLE ADAPTER HOUSING, WITH holddown clamp&bolt #28 GEAR $40
plus mailing cost $4
#2375699 - 09/23/17 08:11 PM Re: TCI Mopar to power glide adapter plate [Re: Joesixpack]
Joesixpack Offline
CONSOLE SHIFT PIVOT BRACKET FOR TRANSMISSION, WITH NUTS$30
Edited by Joesixpack (09/28/17 10:57 PM)
#2377124 - 09/26/17 11:09 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
904 STOCK VALVE BODY AND STEEL TRANS PAN has no rod with it which is pictured in picture FROM 71 CHALLENGER WORKED GOOD WENT TO T/A MANUAL $50. SHIPPED REPLY TO moparraceman@aol.com
#2377265 - 09/26/17 04:07 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Jason B Offline
Loc: Mopar
FOR SALE 904 ATI TRANS BRAKE CONVERTOR WITH A 5700 STALL. We SWAPPED TO A GLIDE THE CONVERTOR HAS BETWEEN 15-20 passes on it with half being 1/8 mile.
ASKING 750.00+ shipping
Thanks Jason Buckner 936 577 1648 call or text for any questions
#2377816 - 09/27/17 03:26 PM A999 Police H D Transmission wide ratio, with low 1st gear! [Re: moparts]
moparAL Offline
I looked forever for a later police A999 (A-38 police package) tranny and finally found one. This transmission has so many cool features. Low 1st gear 2:74 1:54 second 1:00 3rd (wide ratio). Heavy duty design. This RARE transmission version has 5 friction plates direct/4 friction plates rear, double wrap low and reverse bands. Hydraulic opperated, and lock up (better milage). Same trans cross member and no extra wiring. This was the Best Factory Small Block Transmission of its time! It was lighter in weight, (35 pounds lighter than a 727 transmission). It has a 2:74 low first gear which means faster acceleration & a quicker ET. I am asking only $200 (firm) and you must pick up or make arrangements with me.
#2378547 - 09/28/17 09:28 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
rbkt65 Offline
Loc: illinois
new 8" ptc conv stall 52-5500. not enough for my application. has 4 passes on it. built on 8/14 but not used until this year. 525.00 plus shipping- no checks or paypal. cash or p/m. contact info. text to 618-946-4241. dont do much pm'ing here.
#2378780 - 09/29/17 10:34 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
ejtmopar Offline
Loc: plymouth, NH
Used big block 727 transmission Pulled from a 68 Imperial Crown Coupe< I drove the car before i pulled it apart and the transmission worked fine through all the gears. It has been sitting in my garage for 3 years now so you may want to freshen it up. $550 bo
No shipping Local pick up only.
ejtmopar@hotmail.com
Rumney, NH
#2379318 - 09/30/17 12:03 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
old_racer Offline
Loc: Wi.
9 1/2 in Dynamic torque converter excellent used about 3500stall.
$300 plus shipping
email for pic's
hemimax@hotmail.com
#2379576 - 09/30/17 09:07 PM Re: A999 Police H D Transmission wide ratio, with low 1st gear! [Re: moparAL]
sskwb Offline
Loc: pa,USA
where are located?
24,901 Registered Members
184,300 Topics
Look who came over for Mopar parts today
by AndyF
10/21/17 09:16 PM
1968 hemi engine for a bee
by dynotune440
10/21/17 09:03 PM
Eastwood Tig200 Digital
by Leigh
10/21/17 08:36 PM
turbo cam
by fasteddie
10/21/17 08:27 PM
