Page 1 of 2 1 2 >
#2329597 - 07/01/17 09:22 AM Mopar Differential For Sale - 3rd Quarter
moparts Offline
#2329608 - 07/01/17 09:28 AM 1970 A-body 8 3/4" rear with SBP axles & a 3.23 Sure-Grip [Re: moparts]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Still moving in.
Sold!
Edited by Alaskan_TA (07/10/17 12:41 PM)
Edit Reason: Sold
#2329617 - 07/01/17 09:31 AM 1969 B-body 8 3/4" rear end with axles & an empty 742 case [Re: moparts]
Alaskan_TA Offline
Fluffy Balladeer
Pre-Carlisle Sale! I will be listing other parts.
1969 B-body 8 3/4" rear end with axles & an empty 742 case with matching caps & adjusters. 11" rear backing plates & drums included.
$300.00 - I will hold for Carlisle pickup for $100.00 down via Paypal & the rest due in cash at time of pickup.
Emails only - sixpak340(insert at symbol here)att.net
#2332942 - 07/07/17 07:08 AM Dana 60 trac lok [Re: Alaskan_TA]
stevet340 Offline
Loc: western PA
I have a rebuilt 30 spline Dana 60 trac lok for sale. I bought it rebuilt but never installed it. $300 plus I'll split the shipping or I can deliver it to the Mopar Nationals in August. Pm me for pictures or email me at fastcar340@aol.com. Thanks Moparts wave
#2337252 - 07/15/17 07:25 AM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
for sale new richman 410 r&p for #742 case 83/4" has been on shelve and has some light surface rust but steel wool will take care of that SUMMIT PRICE $250 with tax buy this one for $160 plus shipping thats big saving if you can use it reason for selling going to drive my car on street and cant get a very tall tire on going to 3.55 thanks
#2338316 - 07/17/17 10:45 AM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
Jason B Offline
Loc: Mopar
1- complete axle to axle stock eliminator trick of the week B/E body 8 3/4 35 spline rifle drilled Mark Williams axles, spool, Ford housing ends, 1350 yoke machined for drive shaft collar, 4.86 lighted PRO Gear set. $2500.00
1- 742 - 8 3/4 housing with both Mark Williams caps. $250.00
1- 489 Nodular case. $200.00
1- Mark Williams light weight steel spool. $150.00
1- 486 Ring and tapered pinion set that has been REM finished and Cryo. 100.00
Call or text for pictures 936-577-1648 Thanks Jason Buckner
1968 Cuda 440" Edelbrock Victor Head Small Block.
#2341106 - 07/21/17 05:24 PM Re 410 Ring & Pinion [Re: moparts]
72 RR DUDE Offline
Loc: Hamburg, Pa.
410 Ring and pinion from a 489 case. It has about 700 miles on them. They are still in the car till i change to a more reasonable ratio. I,m putting in 3:55 for better highway driving.Looking to get $150.00 for them. Can get pictures when there out.Checking to see if there is any interest or if I just get a hole other unit put together!!
Edited by 72 RR DUDE (07/21/17 08:28 PM)
#2342340 - 07/24/17 09:20 AM Re: Re 410 Ring & Pinion [Re: moparts]
shooter Offline
Loc: massachusetts
Complete 1965 B body 8.75 rearend drum to drum with springs and front spring brackets 741 chuck 2.94 gear ratio $750 must pick up only!
#2343233 - 07/25/17 05:28 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
JudyLuvsBees Offline
Loc: New York
For sale.... Dana 60 4:10 ring and pinion gear set from Richmond. $100 plus the ride send me a PM
#2343322 - 07/25/17 08:18 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
for sale 741 case 8 3/4 with a 276 gear and cone sure grip, small yoke, came in parts car I bought, nice and tight and sure grip pin in good shape, hole not egged out, $275 plus shipping from 55975. PM on board.
Edited by gtsdude (08/02/17 01:18 PM)
#2343931 - 07/26/17 07:55 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
budman1965 Offline
Loc: Edison, NJ 08817
8 3/4" open center section-489 case with 3.23 gears and small yoke (7260 U-joint). Was sitting in the garage for 15 years. Has some surface rust on gears. For rebuilding or use as is. Asking $100. Contact Bud 732-287-0982 or Kramden426@aol.com. Will be at MOPARS at Englishtown august 26 and 27
#2345091 - 07/28/17 11:29 PM Mopar 8.75 rear end "Posi" differential. #741 case 3.73 Sur [Re: moparts]
63SS/A Offline
Loc: Mid West
Just 100% completely rebuilt @ Perfection Driveline for nearly $700.
This unit is ALL FRESH with ZERO wear or damage.
Only selling due to changing to 4.10 for my application but this is a perfect street/strip set up.
#741 case with #7290 large u joint and 29 spline pinion and 3.73 gears.
Mopar Performance Sure grip with all new parts
All new seals and bearings.
Set up. Ready to bolt in and go!!!
Also included is a Mancini racing adjustable pinion snubber
$950 Cash money.
Located West of Louisville, KY. in south central Indiana.
812
631
7868
Edited by 63SS/A (07/28/17 11:31 PM)
#2346425 - 07/31/17 08:49 PM Re: '66/'67 - '68/'69 B body Dana 60 [Re: machphil]
machphil Offline
Loc: Illinois
NO EBAY LINKS! READ THE POSTING RULES!
Edited by tboomer (08/03/17 05:24 PM)
Edit Reason: no ebay links
#2347981 - 08/03/17 02:27 PM Re: '66/'67 - '68/'69 B body Dana 60 [Re: moparts]
70440+6bbl Offline
Loc: NY
SOLD 1969 B-body 4.10 Dana backing plates are there. No drums or snubber. $1800.00
BOM# 602957-6 SOLD
SOLD 1968 B-body 3.54 Dana (has 4.10 now). No backing plates or snubber. $1600.00
BOM# 602957-2. Assembly date on this one: 4/12/68. Very clean tubes. SOLD
Can deliver to the Mopar Nats for free.
PM With questions
Edited by 70440+6bbl (08/13/17 07:41 AM)
#2348202 - 08/03/17 09:24 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: Joesixpack]
1969ronnie Offline
Loc: massachusetts U.S.A.
hi joe how did you protect the "little disc"at the top of the vent valve that melts at 200% and powdercoat is 350 % . r
#2348956 - 08/05/17 12:01 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
Tim8979 Online   content
Loc: Indiana
EXTREMELY NICE/ ALMOST NEW 489 case center section. Powder coated Black outside, 3.91 gears, 35 spline mini spool, Less than 20 passes. Very Fresh unit ready to bolt in and go. Cant upload pics on here for some reason but can send them via phone or regular email. Can be delivered to MoPar Nats if paid in full. $500.00 Text is best as I work swing shift in a extremely loud work place. I will return call asap. 317-717-8979 Tim Thanks for the ad MoParts!!!
#2351294 - 08/09/17 10:59 AM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
Mopar1970440 Offline
Loc: usa
741 case with 3.91s. This is Not a sure grip. Currently in my daily driver truck, nice and quiet gear set. $250 plus shipping
8.25 Rear axle from an 86 dodge d150 2wd.No brake parts besides drums, but its a good solid quite rear axle with 2.73 -3.00 gear ratio in it.
Located in central Texas, pickup is welcome, possible deliver in Texas can be worked out.
Edited by Mopar1970440 (08/24/17 05:21 PM)
#2351929 - 08/10/17 01:44 PM 4.30 Ring and Pinion [Re: moparts]
Kid-Dart Offline
Loc: Michigan
Selling new 4.30 Ring and Pinion (Richmond). For 489 Case,
new in box Need it gone.
reason for selling, have wrong Case.
Will post pictures this evening.
$200 or best offer Buyer pays shipping.
Thanks Moparts
Edited by Kid-Dart (08/30/17 09:38 AM)
74 Dart Sport Best to Date 10.82 in the 1/4
#2352500 - 08/11/17 04:02 PM 4.56 Ring and Pinion 742 case [Re: moparts]
Kid-Dart Offline
Loc: Michigan
Have a like new set of 4.56 gears (Richmond) for a 742 case. maybe 20-1/4 mile runs and maybe 300 street miles. I am switching to a 4.30. Need it gone asking $150 OBO
Buyer pays shipping or picks it up.
Thank you for the add Moparts.
Edited by Kid-Dart (08/30/17 09:39 AM)
#2356612 - 08/19/17 01:27 PM Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 B-body 4.10 Dana 60, fresh setup, new front seal $2500.00 (708)288-2879 Scott
Page 1 of 2 1 2 >
24,897 Registered Members
184,176 Topics
Cast crank question
by ozymaxwedge
10/18/17 01:29 AM
Battery Cap Color
by 340wedge
10/17/17 11:13 PM
Arrington Performance
by Michael
10/17/17 10:24 PM
some mighty expensive rust
by flypaper
10/17/17 10:05 PM
