#2329596 - 07/01/17 09:21 AM Mopar Differential Wanted - 3rd Quarter
moparts Offline
#2330007 - 07/01/17 10:02 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Wanted:
Drum to drum A-body 8 3/4 rear end with or without center section or axles. Prefer to find one near southeast MI for pick up so as to avoid having to ship. Also need the shock mounts and u-bolts.
68-69 big block A-body driveshaft with the large u-joints.
gt340 @ yahoo.com
#2330246 - 07/02/17 03:14 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
440mopar Offline
Loc: USA
Wanted: Stock type Dana 60 pinion snubber.
Please email me at fourfortymopar at yahoo.com
#2330350 - 07/02/17 06:50 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
70HemiShaker Offline
Loc: Home of the Bluegrass
WTB.... B body DANA 60 axle. 68-70 preferred. TIA
Found one.
Edited by 70HemiShaker (09/21/17 07:30 AM)
"It takes a Mopar to catch a Mopar"
70 Challenger: 472 Hemi, A-855,
& a 3.54 DANA 60
69 Bee..... we will see!
#2341987 - 07/23/17 01:09 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
70440+6bbl Offline
Loc: NY
FOUND! Thanks Moparts!
Need parts for Power Loc, to put 23 spline Dana 60 axles back in.
Edited by 70440+6bbl (07/26/17 09:47 AM)
#2343143 - 07/25/17 02:45 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: machphil]
MoparKansas Offline
Loc: KS
Wanted 8 3/4 Center section with sure grip and 3.73 gears. Prefer 742 case will consider 489. Prefer clutch style sure grip will consider cone type. Thanks!
#2347050 - 08/01/17 10:27 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
DoctorDiff Offline
Loc: Polson, MT
Wanted 10" x 2 1/2" Mopar rear brake cores:
All I need are the drum brake backing plates, parking brake levers, strut-rods, push-rods and diamond shaped keepers.
Donors include any '65-'89 Mopar car/truck rearend equipped with 10" brakes and 5 x 4.5" bolt pattern.
I will buy all you can find for $50 pair.
(406)883-4772 doctordiff@gmail.com
Contact info
#2357271 - 08/20/17 06:49 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
1mean340 Offline
Loc: Suffolk County, New York
WANTED: CSR small block trans shield. Sticker date doesn't matter, just has to be in good functional shape. Will pay good money!
B5 '70 Challenger. 340/727A. In the works- '70 LA block, hughes stud girdle, factory forged crank, Eagle H beam rods, Speed Pro forged pistons, ported W2 econos, D1SC Procharger, front mount intercooler, Aeromotive A1000 fuel system, E85 fed via FITech 1200 fuel injection.
#2370614 - 09/14/17 09:45 AM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
rick4106 Offline
Loc: la.,usa
Wanted: Dana 60 girdle style rear cover
#2372364 - 09/17/17 06:24 PM Re: Mopar Differential Wanted - 3rd Quarter [Re: moparts]
RV2 Offline
Loc: Covington Georgia
WANTED: Dana 60 ring gear spacer
Pm me with what you have
#2378752 - 09/29/17 09:58 AM Re: Mopar Differential Wanted - 3rd Quarter [Re: RV2]
daron Offline
Loc: LEBANON;PA
wanted 4.30 gears for a 742 case
24,903 Registered Members
184,386 Topics
Advise on setting cedar posts
by StrokerPost
Today at 01:21 AM
Ok, so who all is going to Fall Fling??
by dart4forte
Today at 12:33 AM
Dome light glows when map light is off
by 3XBlack6packGTX
Today at 12:32 AM
Converting rims to bead locks, who does that?
by Cab_Burge
Today at 12:14 AM
