Page 1 of 2 1 2 >
#2329588 - 07/01/17 09:17 AM Race Cars For Sale - 3rd Quarter
moparts Offline
#2329860 - 07/01/17 04:51 PM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
joez Offline
Loc: PA
1972 Dodge Challenger race car roller. SFI 25.5 mild steel chassis with stock front and rear frame rails. Fiberglass front end and deck lid. Has factory 1970 grill, headlights and tail lights for street appearance. Steel doors with working glass. Cowl hood with carbon pro stock style scoop.
Custom tubular k-member with flaming river mustang II rack and spindles. AVO double adjustable front coilovers, Qa1 adjustable rear coil overs, S&W ladder bars, diagonal link and splined anti roll. Chassis engineering wheelie bars. Wilwood disc brakes front and rear. Dana 60 with moser 35 spline spool and axles. Dewco pro-fin 3.73 pro gear. 15x11 holeshot rear wheels, Weld magnum front wheels.
Motor plate for BB Mopar. 2 3/8” custom headers with collector mufflers. ATI powerglide adapter midplate, flywheel.
Fiberglass stock appearing dash with autometer gauges, Stock door panels, Kirkey seat, firefox fire system, stroud chute, jaz 3 gallon fuel cell, dual nitrous bottle mount, laptop mount, quarter stick shifter MSD digital 7 programmable, hvc2 coil, strange low mounted master cylinder, afco radiator,
Last run with 528 B1MC low deck nitrous. Best ¼ mile 1.308/5.34@135.88mph/8.21@171.29mph. Best 1/8 mile 1.19/5.29@132.7mph @ 3,050lb Joe – nitrojoez@yahoo.com – 570-401-2596 $18,000 obo or trade for srt8 challenger.
#2331115 - 07/03/17 10:54 PM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
indcontrols Offline
Loc: South Florida
Dodge Dakota Tube Chassis Drag car.
I have owned this for years, I also have another drag car, I've decided to let this one go.
This is a 1995 Dakota Extra cab pickup, motor is moved back a foot, driver's seat is actually in the extra cab window - tons of room unlike an S-10... It is a complete double-tube mild steel chassis with a mustang II front end. The truck has a few dings, but no rust at all and is very clean. Good looking, draws a crowd...
Last weekend I got stuck behind a bunch of imports in the staging lanes, overheated the motor and blew a head gasket. I have since pulled the motor, and the photos tell the story..
The truck is a 4-link (chassis engineering) with coil overs, and has the following:
-Wilwood Dynalite disc brakes rear
-Complete Moser braced 9" (new 2015) with 35 spline axles, strange nodular section and spool, 4.56 pro gears
- Custom made Carolina driveshaft
- JW built powerglide with factory case but no factory internals, 1.80 straight cuts chromoly, billet turbo shaft, etc (built 2015)
- TCI Gerotor pump
- JW Ultrabell mopar to glide, JW wheel flexplate
- Quarterstick shifter (with pistolgrip, of course)
- 8" PTC 4500 converter (JW built 2015)
- Chassis engineering mid and front plate
- Competition Engineering column kit
- RCI seat
- Separate fuel systems for motor and nitrous
- Full Autometer gauges
- Complete MSD system, 7AL-2, start/nitrous retard, dial chips, MSD coil, pro billet distributor, etc.
- Line lock, all new wiring 2015. Easy to use, one button, switch to "burnout" and use the shifter button for linelock, switch to "launch" and use the same button to get on the Pro Brake
- 15 x 14 Welds in back with good goodyear 31x14 slicks, imitqtion welds up front with good M/T front runners.
- 4 wing nuts and one plug, nose comes off... bed cover lifts up for easy fueling. Two hand nuts and the entire beds tilts up (see photos)
- Truck weighs 2670 with Megablock wedge
- Custom headers with removable front tubes
- Engine Diaper
MOTOR - Motor is apart (see above mishap)
- Block is a Mopar megablock (early), was once hurt below #4, was sleeved and patched (see photos) a dozen years ago by Dvorak. Current bore is 4.520, I think it will clean up at 4.530 (Ross has an off the shelf piston for this).
- Crank is gorgeous, it is a 4340 forging (unknown manufacturer from 15 years ago), chamferred, 6 & 8 bolt pattern, etc.
- Rods are custom Manley aluminum 6.920", in excellent shape
- Pistons are ROSS custom, some scuffing, otherwise nice
- Keith Black BILLET oil pump and Milodon 7 qt. pan, external single line (12 an) with remote mount filter.
- Mopar aluminum water pump housing with Summit billet pump
- Indy timing cover, ATI balancer, Cloyes double chain
- Comp 892 roller lifters with front side closed off (brass) for pushrod oiling - offset for 440-1 heads.
- COMP roller cam #23-000-9 (only 40 passes) .621/.621 on 108
- JESEL 1.7:1 Roller rockers for INDY 440-1 heads (these also fit 572-13 heads) - perfect shape
- Powermaster 3.5hp starter, ARP studded block, pan, etc.
- INDY intake - full ported with like new NOS fogger system with all pills, instructions, complete from activation switch to bottle and a spare bottle.
- INDY 440-1 Heads - Here's where the problem lies, the heads have been repaired and cut so many times that they are down to 58cc, had been oringed in the past (Dvorak), and have a dozen weld repairs each - In my opinion, the heads are done. The valves, springs, etc. are excellent and have low passes on them. IT NEEDS HEADS - period...
Will sell as a roller. Will accept some partial trades, nice car for my daughter maybe. Hotrods, diesel truck, who knows.
Edited by moparts (07/20/17 06:01 PM)
#2331919 - 07/05/17 12:15 PM Re: Race Cars For Sale - 3rd Quarter [Re: indcontrols]
SSHemi364 Offline
Loc: OHIO
For Sale 1968 Dodge Dart SS/AH HUSTLIN" HEMI -O- runs on fresh
Specialty Motorwerkes power, .030", Bullet cam, rollerized bearings, Isky
lifters, Barton heads and intake, Barton rockers, Holt stainless headers,
Pro Trans w/brake, ATI 8" converter, PPR shifter, Advanced Control Devices,
Current NHRA certified 8:50 moly cage, Dana 60 w/ Strange spool and 40
spline axles, 5:57 pro gear, sway bar, Strange brakes w/double caliper rear,
Strange double adjustable shocks, 125 lb. rear springs, extra 150 lb. set,
3 gallon fuel tank, Magna Flow fuel pump, twin Turbo Start batteries (fresh)
American Racing Wheels, extra 15x14 Billet Specialities wheels (drilled for screws )
Asking $73,000.00 Call Bob at 859-263-2486 8-6 p.m. E.S.T. (can leave a message) Or Email JosephDepillo@gmail.com for photos
Will sell as roller. Car call for price. Engine 35k
Edited by SSHemi364 (07/20/17 12:34 PM)
#2333425 - 07/07/17 11:55 PM Re: Race Cars For Sale - 3rd Quarter [Re: joez]
65 Hemi Offline
Loc: North Texas
1967 Coronet has a RMS coil over/ rack and pinion front end with wilwood brakes, Dana 60 with split leaf with cal tracs, 500" world block with Indy -1 heads. Makes 730hp and is street friendly with a 618 overdrive trans. It has zero rust and is straight as an arrow with black paint and great stock interior. Over $75k invested in car! $31,500 obo. Trade for 65 Coronet post car or light race car Mopar or GM or Ford. No dealer consignment please.
Doug
940;300,55six3
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet 605" KB Alum Stage V Hemi, Pro Trans 727
1965 Dodge Coronet 493" World Alum block Indy -1 Heads, 4L80E trans
1964 Dodge Polara 582" Indy alum Block 426-1RA heads, T400
1967 Dodge Coronet 500" World Block 440-1, A618 trans
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
1955 Chevy post 283, T350 (soon 434" SBC pump gas)
Old cars are never done. They are ongoing projects!
#2333995 - 07/09/17 09:26 AM 69 Dart Swinger pro street [Re: moparts]
Bigcube Offline
Loc: Upstate NY
My Dart is still available. Asking $35k turn key or $20k as a roller. It drives straight, hooks hard and has been in the 8's on motor with race gas. The current pump gas combo is about 50 HP shy of the race fuel combo. Best ET is in my signature. Description below:
Chassis
- Clean title and has vin tag, currently registered and plated
- Chassis professionally built by "Pro Start Race Cars" in NJ
- Full chrome moly round tube frame, will certify to 8.50, currently expired
- 4-link rear suspension, has 17x33 tire on a 15x14 rim
- Wishbone locator
- Dana 60 rear, Strange 4.10 race gears, Strange race 35 spline, Strange spool
- Wilwood brakes all the way around
- Strange double adjustable rear shocks, Koni front shocks
- Rear A-R bar
- Wheelie bars, chute
- Dual batteries, custom large aluminum fuel cell
- A-arm front suspension
- Aluminum front and mid plates
- Stiletto rack & pinion
- Body is all steel except for hood and bumpers, under 50k original miles
- Real window glass that rolls up and down
- Stock dash, modified stock column, all lights work
- Weighs 3000 Lbs. race ready
Engine, 557" Big block
- Keith Black block, 4.440" bore, purchased new, never windowed
- Bryant billet crank, fully counter weighted, 4.5" stroke
- GRP aluminum rods
- Two sets of pistons, Diamond 11:1 for pump gas, Ross 15:1 for race fuel
- Hellfire rings
- Indy -1 heads, hand ported by Barton
- Jesel Rockers, Jesel belt drive
- Single Holley 1150 3-circuit dominator
- Two rollers cams, Isky "Red zone" solid rollers
- Custom aluminum oil pan
- Titan wet sump oil pump
- MSD Digital 7 ignition
- NRC offset distributor
- Moroso 4-vane vacuum pump
- 90 amp alternator
- Has a NOS Fogger nitrous system plumbed but never tried
- Spare intake (not plumbed)
- Custom stainless steel step headers, stainless 4" merge collectors
Transmission
- CRT TF-727 full race trans
- Steel drum
- Reverse manual valve body with trans brake
- All good parts, no more than 100 runs on trans
- PTC 9" nitrous converter
Miscellaneous
- Custom Ron Davis radiator, Dual Spal fans, stays under 185 deg in traffic
- Car still has factory radiator support, this is not a typical "panel" chassis car
- On board fire system
- Factory headliner, door panels Dome light (works)
- Factory Speedometer works
- Removable tunnel
- Carpeted
- Product Engineering fuel system
- Carbon fiber drive shaft
As a roller the car will not include engine, radiator, trans or ignition box.
I have lot's of pictures on-line and many more available. PM me here on the board or email bigcube"at"stny.rr.com, let's sell this thing!
Thanks for the ad! thumbs
Best 1/8 mile 1.25 60' 5.67 @ 121mph
Best 1/4 mile 8.94 @ 151mph all motor
http://www.bigcube.org/
Now pump gas and street driven. FOR SALE, PM me for details
#2334342 - 07/09/17 07:41 PM 1971 Plymouth Duster [Re: moparts]
++MAX WEDGE++ Offline
Loc: Near Columbus, Ohio
1971 Plymouth Duster H code car. Factory plum crazy (FC7). Car is blue currently. New 440 with 906 heads, Harland sharp rockers, Forged pistons, steel crank, MSD Ign., 727 Reverse A&A valve body, 8 3/4 rear, mini tubed, frame and cross members are perfect. Roll cage, Car is ready to go. Does not have 1 mile on new drive line. Clear Ohio Title. Rally dash, after market gauges. All good stuff on it. Not perfect or show car, but definitely solid and turn key ready.....
Plz send PM through Moparts
Photos
Edited by ++MAX WEDGE++ (09/06/17 07:34 AM)
#2334646 - 07/10/17 10:30 AM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
Jason B Offline
Loc: Mopar
Got an E, F, G, Stock Eliminator 73/74 Duster with all the tricks. Car is under construction. Chrome moly cage, S60 Dana with mono leaf Cal-Tracks. 512 gear set R.E.M. Finished. Car will come with wheels tires, disc brakes, Pro Trans, Parsons and Meyers 360 new with all the latest enhancements. Car needs finishing body work and assembly. Lost interest asking $25000.00 call or text Jason Buckner 936-577-1648 for pictures.
Edited by Jason B (07/10/17 01:28 PM)
1968 Cuda 440" Edelbrock Victor Head Small Block.
#2335771 - 07/12/17 08:31 AM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
julian2007 Offline
Loc: oh
2014 Dean Mcilvain 247 inch top dragster
588 b1mc best machine all aluminum mopar
peterson dry sump
aed carb
fab shop headers
belt drive
aeromotive fuel system driven off dry sump pump
race pak
msd dig 7 ign
bindo mega 600
dig dial board
weld bead locks
carbon wing
pro wiring
pro pluming
race pak dash
a&a glide
Nitrous express billet two stage plate system
all new everything , fresh and ready
49,900 turn key
937-489-9397
This is a older photo many upgrades sense then
Edited by julian2007 (07/12/17 08:34 AM)
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
#2336562 - 07/13/17 02:52 PM '72 Duster project car [Re: moparts]
AndyF Online   content
Loc: Oregon
Ad removed
Edited by AndyF (07/19/17 12:38 AM)
#2344073 - 07/27/17 01:25 AM 65 Plymouth A/FX [Re: moparts]
467hemi Offline
Loc: PA
65 Plymouth A/FX
Selling as a roller.
A100 van axle; Corvair steering box; Cage will cert to 8.50’s; Steel floor and trunk; aluminum door panels; 8 ¾ rear; 4.56 gears; Strange axles; Super Stock springs with torque boxes; glass fenders; lexan windshield; A100 seat; 60’s B&M shifter;
Comes with everything needed to run minus engine and trans; Set up for Big Block Mopar/727. Car drives absolutely perfect; Recent build - all brake and front end components are new.
Looks like a 1965 match race car.
Very nice paint and lettering.
If you are looking for an authentic nostalgia altered wheelbase racecar, you will not be disappointed.
$26K
Possible partial old car/truck trade.
No texts. Call 267- 9 8 zero – 9 8 one 3
Edited by 467hemi (07/27/17 01:40 AM)
#2356643 - 08/19/17 02:42 PM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
sst404b Offline
UP FOR SALE IS A E/F/G 73-74 DUSTER WITH ALL THE TRICKS UNDER CONSTRUCTION. CHROMOLY CAGE, S60 DANA REAR WITH MONO LEAF CAL-TRACS, 512 R.E.M FINISHED GEAR, WILWOOD DISC BRAKES, PRO TRANS 904, COMPLETE FRESH OFF THE DYNO PARSON AND MEYERS 360 WITH ALL THE NEWEST ENHANCMENTS. COMES WITH WHEELS AND TIRES AND ALUMINUM FEATHER DUSTER HOOD. DAD JUST LOST INTREST IN THE PROJECT CAR NEEDS TO BE ASSEMBLED AND BODY WORK COMPLETED. NOTE- THIS IS AN ON GOING PROJECT SO WE ARE STILL WORKING ON THE CAR.
ASKING 25000.00
CALL OR TEXT RAY BUCKNER 936-662-5454 OR JASON BUCKNER 936-577-1648 FOR MORE PICTURES. THIS WILL BE ONE BAD A** CAR WHEN COMPLETED.
#2356828 - 08/19/17 08:03 PM Re: Race Cars For Sale - 3rd Quarter [Re: sst404b]
82ramIndy493 Offline
Loc: crisfield, maryland 21817
I have for sale my 1982 Dodge short bed Pro Street/Race truck. It has a 493 Indy head stroker engine that is 12 to 1 compression. The engine consist of an Eagle crank, Manley rods and JE pistons that was assembled and balanced by Hensley Performance. The block is a 69 that was machined by a local shop that is very reputable and does most of the local track work. The cam is a speced cam by Dwayne Porter through Comp. The intake is a Victor that was ported by Hensley and the carb is a 1050 Dominator built by Biggs Performance. The ignition is MSD. The tranny is a 727 with a bolt in Sprague and has a Trans Go kit installed and a Dynamic 4500 flash stall converter. The rear is a brand new built Dana 60 which has never seen track time yet. It is completely new through out including the brakes. It is a 4.30 ratio. The cage has just been updated to 9.00's. It has 2 race seats installed and has a rear fuel cell and 2 batteries in the rear. The truck is a thrill to run and goes extremely straight from take off to finish and has been a best of 10.80 but is capable of more. I don't really have the time to fool with it now as I am caregiver to my father who is 88 and between my business and him and upkeep of the property I have no time for it anymore. If interested you can PM me here or contact me at samson1156@verizon.net or telephone at 1-410-968-2010. I can give you more info then and send any or all pictures you need. Feel free to contact at any time. Thanks and have a great day. Clinton. ( My asking price for this truck is 15,000 or Best reasonable answer. I have a very nice trailer and a set of slicks and street slicks mounted on similar rimes that I will give with the truck if the price offered for the truck is within reason.)
Edited by 82ramIndy493 (08/28/17 10:46 PM)
#2358110 - 08/22/17 12:17 PM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
Dave Hall Offline
Loc: Cotati, CA
Posting for a good friend Marcus Wessels '68 Charger
#2358296 - 08/22/17 06:53 PM Re: Race Cars For Sale - 3rd Quarter [Re: Dave Hall]
four40cuda Offline
Loc: Illinois
Selling my 1968 Plymouth Road Runner SST car. Top notch NHRA race car that is only 2700lbs. Has glass fenders,bumpers,doors, hood and deck lid by Glasstek. Back half ladder bar car with QA! coil overs on all four corners. Dana 60 Strange rear end,Strange brakes. Currently has big block mopar engine and 2 speed pg trans with shield,pro brake,5k stall, straight cut gears in trans. Selling this car less engine everything else goes with it from the transmission back. Over 30k invested in this car. Just way to many good name brand parts to list. $18k less engine OBO. Clear Illinois title.
Edited by four40cuda (08/22/17 06:54 PM)
#2358746 - 08/23/17 06:39 PM 62 Dodge Dart [Re: four40cuda]
rbj Offline
Loc: mi
1962 Dodge Dart post car, all steel except hood. selling as roller or also have 512 Kieth black all aluminum b1 original headed motor.
Nhra 8.50 cert cage DOM tube
Dana 60 with mark Williams 40 splined axels , summers brothers titanium coned spool,strange 4.30 pro gear, mark Williams rear disc brakes .
Afco double adjustable rear coilovers, ladder bar suspension
Champion sfi wheels 12" back with 31 10.5w 15, 3"fronts 28" tall fronts
Car has full interior all new , custom fit carpet, backseat, headliner door pads and quarter glass panels, fiberglass front seats with covers, window net ,original smoothed dash, with auto meter gauges( all black interior)
Tubular a arms, qa1 single adjustable front shocks,willwood front brakes
Msd 7al2 ,2step,magna fuel 500 pump, 8 gallon cell
Glass front and back windows, lexan side glass, door glass does go down. Much more I'm sure , car ran 9.2s with 512 and glide any questions just call 248-219-2073 $19,500.00 roller
Trying to add pic but it says it to big , can text some it is profile pic
#2361382 - 08/28/17 07:55 PM Re: Race Cars For Sale - 3rd Quarter [Re: moparts]
71blackdemon Offline
Loc: Kentucky
im selling or trading my 71 h code plymouth duster. It has a 422 cubic inch w5 headed engine with a scat rotating assembly. with a 760 comp roller cam that made serious hp if your serious ill show dyno sheets. the trans is a roller 727 with a 8 inch ptc converter and transbrake. it has an 83/4 with 513 gears and moser axles and mark williams caps and gears.it still has all stock interior with a cage. also it has a hippy paint job from the seventies. im asking $22,000 or trade for something cool or something faster.you can contact me at 502-262-4708 .
#2365829 - 09/05/17 01:16 PM Re: Race Cars For Sale - 3rd Quarter [Re: 71blackdemon]
Eric Offline
Loc: Pittsburgh PA
80 Arrow JanCen 499" low deck Mopar fresh approx 50 passes. Round tube mild steel with chromoly funny car cage 8.50 cert
Molnar crank and rods
JE pistons
Indy CNC 295 SR heads
Harland Sharp rockers
Trend pushrods
ATI balancer
AED 1000cfm 4150
Coated 2" headers
Indy intake
Meziere water pump
Afco radiator
UCC 8" converter
Abuzzi glide with Reid case and roller tailshaft
DOM .083 driveshaft 1350 Spicer both ends Moser slip yoke
Dana with Strange axles 4.56 gear Perfect launch cover
Wilwood disc on all four corners
4 link with anti roll
Hoosiers front and rear approx 50 passes
Digital delay Elite 95 and Biondo throttle stop
ARC switch panel
Stroud chute and Comp Eng wheelie bars
Car is mostly run in S/R S/G 9.90 @ 148 has been 5.53 @ 125 in the 1/8th. Tons of new parts. Asking 21K t/k If you know what it costs to build a 8 second car you know this is a fraction of the cost. PM me here if interested.
5.53 @ 125 1/8th on the launch control..more left in her!
#2369838 - 09/12/17 11:24 PM Re: Race Cars For Sale - 3rd Quarter [Re: Eric]
Hemi_Ram Offline
Loc: Grand Forks, ND
SOLD SOLD SOLD
Edited by Hemi_Ram (09/14/17 06:36 PM)
www.picturetrail.com/hemi_ram
#2370056 - 09/13/17 12:02 PM 1993 Dodge Daytona tube chassis drag car [Re: moparts]
JC Childress Offline
Loc: Big Island ,VA
This car belongs to my buddy and hes a car collector. He hasn't been in a car since he drove a 12 second car back in the early 1980's. Got in this car and went straight down the track and ran 5.52 in the 1/8 ! This car drives like a dream. Complete round tube, mild steel car. Never been wrecked. With a nitrous big block, it has run as fast as 4.70's. The car was built professionally by David Underwood. 2300lbs w/o driver. 9" rear, Strange center section, 40 spline Moser axles, Strange brakes all way around. Brand new Strange struts, brand new Mickey Thompson tires all around. Brand new Magnafuel fuel system. Engine is 505ci big block Mopar and FRESH. Has Mopar Mega block, brand new Scat crank, Scat rods, JE pistons, Total Seal ringset, Comp Cams custom roller cam and lifters, Indy cyl heads, Milodon oiling system, Jesel valvetrain,Edelbrock super Victor intake,Holley Dominator carb,MSD 7AL3 ignition, Fresh PG trans. Car will certify . Excellent car and drives like a dream. Located in Virginia. $32,500. Call or text me for more info or with any questions. (may trade for really nice muscle car )
J.C. Childress (434) 665-9541
Page 1 of 2 1 2 >
24,901 Registered Members
184,323 Topics
What Rim is this??
by EV2 340
10/22/17 04:15 PM
Small block connecting rods
by 10sec.dart
10/22/17 03:53 PM
Auto Daylight Headlights 2005 LESABRE
by Rug_Trucker
10/22/17 03:15 PM
Question on tractors and larger lawn equipment
by Dixie
10/22/17 02:26 PM
