Page 2 of 3 < 1 2 3 >
#2345814 - 07/30/17 04:20 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
Tooldude Offline
Loc: So Cal
Need a hi beam and a lo beam head lite buckets for a Dodge Challenger
Need a hood sticker. Bolts to the hood right by the safety latch, and it's for the same 70 challenger. Cell 818.425.3957 or tooldude6464@sbcglobal.net thx
#2346132 - 07/31/17 09:28 AM Wanted: Power Window Relay [Re: moparts]
Icarus38376 Offline
Loc: South East, PA
******FOUND IT....THANKS MOPARTS******
ISO a Power Window Relay part number 2932834.
Thanks,
Pete
717-490-4879
Edited by Icarus38376 (08/03/17 03:35 PM)
#2346324 - 07/31/17 04:38 PM looking for a right rear wheel lip molding [Re: moparts]
340swing Offline
Loc: Ct, Oxford
Looking for a a right rear wheel opening molding for a 1970 cuda. Looking for an OE part scratches ok going to send it out to be polished. Will buy a pair if needed. Please pm or text to 2032064967 Brian
#2346567 - 08/01/17 06:21 AM Re: looking for a right rear wheel lip molding [Re: 340swing]
convertcuda Offline
Loc: Wausau Wi
I'm looking for a super clean 71 Thermoquad 4972s carb for a 71 car. If you have one and you want to sell please let me know.
Also looking for a master cylinder with 3461187 casting. Fits 71 Cuda with disk brakes.
Also looking for a mint rally dash light bar for a 70 cuda
Ken 715-432-5080 text or call or convertcuda@gmail.com
Edited by convertcuda (08/03/17 12:50 PM)
#2347824 - 08/03/17 10:56 AM Re: E Body - Parts Wanted - Dash pad with AC [Re: tx9cuda]
glenngomango Offline
Loc: Maryland
71-74 version, challenger or barracuda with ac vents. Must be mint original factory pad.pm or call 301-602-2465 thanks
#2350479 - 08/07/17 11:46 PM Wanted - shaker baseplate adapter ring [Re: moparts]
SSAHfan Offline
Loc: B.C.
Looking for a steel shaker baseplate adapter ring...... doesn't need to be perfect.
Best to PM me here.
#2350843 - 08/08/17 03:26 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: SSAHfan]
B5Cuda440-6 Offline
Loc: Indianapolis, IN
Looking for an original driver's side tail lamp ground wire for a 70 Cuda. See the engineering print below for reference of the wire I'm trying to find. All 70 Cuda's were equipped with this and the part number is stamped in the wire casing - 2983866.
Please PM or e-mail at robert.traina@roche.com if you have a good, usable wire that is not frayed, broken, damaged, etc.
Thank you.
#2352405 - 08/11/17 12:39 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
Triggerfish Offline
Loc: Blairsden, CA
Need parts for 70 Challenger Convertible (prefer show quality):
Passenger side outer A pillar trim including upper corner piece
Passenger side inside A pillar trim upper corner
show quality hood front trim moulding
show quality hood REAR trim moulding (super hard to find)
front grille long lower valence OR complete grille assy
rear pass side tail light bucket
rear back up light complete assy incl lense (show quality)
PM me for contact info & thanks in advance.
#2352410 - 08/11/17 12:51 PM Wanted Holley R4734A [Re: moparts]
BS27ROB Offline
Loc: PA
Looking for a Holley R4734.
#2353330 - 08/13/17 05:46 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
VCODE Offline
Loc: New York
Looking for a 70 Cuda Tube type Jack assembly. Hoping for date code 0A Jan 1970 /0B Feb 1970 /0C Mar 1970
Pm or cell 914-843-9617
Bob
Edited by VCODE (08/13/17 06:11 PM)
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17 (Robert what is a 440 Six-Pack)
#2353349 - 08/13/17 06:55 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
76orangewagon Offline
Loc: Akron, ohio
I am looking for a good used set of OEM 70-74 E body front frame rails either. I do not need full rails, cut off just forward of the firewall is ok. I am looking for both sides. I am also looking for a rear driver side frame rail section from behind the wheel well arch to the back cross member. I know they make these aftermarket but would like to find some good rust free factory metal before going the aftermarket route. Please PM me.
Thank you,
Ross
#2355810 - 08/17/17 10:23 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
biggE Offline
Loc: California
Wanted: I'm looking for a Thermoquad carburetor #4973 core or even the base with throttle shafts that are not frozen up or pitted. If you have something PM me or eric0890@att.net. Thanks
#2356778 - 08/19/17 06:41 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
1964hemi Offline
Wanted 1970 1971 original Inflate a spare blue bottle bracket and and wing nut.
jandlwalters@sbcglobal.net
#2357850 - 08/21/17 08:47 PM Re: E Body - Parts Wanted - 3rd Quarter [Re: moparts]
ah1s Offline
Looking for an original mint 71-74 ebody dash pad in black. No ac single speaker thanks.
#2358584 - 08/23/17 12:30 PM WANTED: Drivers weatherstrip molding for E body Convertible [Re: moparts]
isettakurt Offline
Loc: Metro Detroit,Michigan
WANTED: 70-71 e body CONVERTIBLE Drivers Side A piller weatherstrip molding.
THanks,Kurt
isettakurt@gmail.com
#2358680 - 08/23/17 03:59 PM Re: WANTED: Drivers weatherstrip molding for E body Convertible [Re: moparts]
MONC Offline
Loc: The Historic Hudson Valley
WANTED :
CONSOLE MOUNTED CASSETTE PLAYER WITH PEDESTAL , HOUSING and MOUNTING BRACKET
THanks for the ad Tom.
Mopar
Or
No
Car
#2359130 - 08/24/17 11:55 AM Wanted: Seat Hinge Shoulder Bolts and washers [Re: moparts]
mike mike mike Offline
Loc: New Hampshire
*** Found Them! Thanks! *****
Dug up an old thread here and contacted Byron Fettig and 69440 who were noted as possibly having these but no luck so far. Looking for 2 shoulder bolts, 2 washers with the 4 indents around the center and 2 inner soft washers for a 71 e body bucket seat hinge / pivot.
Also looking for the strike plate and screw for the lower portion of the bucket seat. Its where the spring from the upper rests and looks like a plated washer with a beveled center hole.
If you have these items please email me at michael.emond@me.com
thanks!
Mike
Edited by mike mike mike (08/28/17 03:14 PM)
#2359830 - 08/25/17 05:18 PM WTB: Fan clutch 2863260 for 70 Challenger [Re: biggE]
tyretr Offline
Loc: Beeper Bay, Wisconsin
I am looking for a good used or NOS Chrysler fan clutch. Part number 2863260. The fan clutch is for a 70 Challenger with 440, auto and A/C. If you can help PM me here. Thanks Moparts!
70 V code EK2 Hardtop Road Runner 70 N code B5 Convertible Road Runner 68 4 speed QQ1 Convertible GTX
#2360737 - 08/27/17 05:36 PM WANTED - 1970 E-body 3-speed reverse lockout rod [Re: moparts]
Alaskan_TA Online   content
Fluffy Balladeer
Loc: Still moving in.
WANTED - Does anyone have one or two of these that they would like to sell?
It is a 1970 E-body reverse lockout rod for a three speed manual transmission that goes from the R/L shift arm on the transmission up to the column arm.
If you have one or more to sell, please email me at sixpak340(insert at symbol here)att.net with a photo & price?
#2361068 - 08/28/17 09:34 AM Re: WANTED - Lug Wrench/Tire Iron [Re: Alaskan_TA]
Erik Offline
Loc: Stroudsburg, PA
I need a lug wrench/tire iron for my '70 Challenger R/T. Anyone have an extra they are willing to sell?
PM me here.
Thanks!
1970 Challenger R/T SE 383 Auto
1968 Barracuda Convertible - 416 4-spd
Contrary to the opinions of some, I am not dumber than I look.
24,899 Registered Members
184,275 Topics
Carburetor spacers for heat
by RAY1969CARS
10/20/17 10:35 PM
Question about SVO rear brakes, Dana S60, Dr. Diff/Strange
by TomsCharger70
10/20/17 10:27 PM
Stamped number on car
by toplescuda
10/20/17 10:12 PM
how to remove accelerator cable from the floor
by moparpro
10/20/17 08:04 PM
