5.7 piston to valve clearance....
#2329104
06/30/17 12:25 PM
06/30/17 12:25 PM
Posts: 170 Wisconsin
Medlock51
Wisconsin
Any known reason why the stock pistons can't be cut for additional p2v clearance when using stock pistons?
Nothing new about this as it was being done 60 years ago..
My 5.7 will need new slug to get my needed compression but a guy on a budget using stock pistons could save some cash doing this.
Re: 5.7 piston to valve clearance....
[Re: Medlock51]
#2330085
07/02/17 08:47 AM
07/02/17 08:47 AM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Check the thickness where you want to cut reliefs. I am not sure what is the minimum you need after cutting, but I bet the factory didn't put any extra metal in those stock pistons.
[Re: Medlock51]
#2330742
07/03/17 04:13 PM
07/03/17 04:13 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
They have extremly thin pistons and the new material is very brittle I would not dare try to run one that way. Seems about .100 thick pistons (hard to get my caliper down there), if you cut even .050 you only have .050 left and now it has a stressriser in a very weak piston that you are bumping up the power on, very bad idea.
[Re: Medlock51]
#2331216
07/04/17 10:22 AM
07/04/17 10:22 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Don't do it, like Dave said the top on these stockers is very thin
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Medlock51]
#2331931
07/05/17 02:42 PM
07/05/17 02:42 PM
HotRodDave
Kalispell Mt.
still going to make a stress riser on a very thin brittle piston. .010 less valve lift is not gonna hurt as much as a busted piston.
[Re: Medlock51]
#2332429
07/06/17 12:12 PM
07/06/17 12:12 PM
ric3xrt
Trumbauersville PA
Here's a stock 05 piston cut Use your best judgement, it's as thick as some of the later BB's but these 5.7 are notorious for being fragile
