DRIVER'S SIDE SPARK PLUG REMOVAL #2328434
06/29/17 02:34 AM
06/29/17 02:34 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
400 bigblock, 78 Magnum, got all the passenger side removed easy-peasy, and #1 on driver's side. Is there an easy way to remove #3, #5 and #7 plugs?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: Magnumguy] #2328446
06/29/17 03:39 AM
06/29/17 03:39 AM
Tacoma, Washington USA
Adam71Charger Offline
i owned a late 70's Cordoba 400 auto, and I think I may have went from underneath and I may have removed a heat shield and bracket to clear the way. Dont know how similar magnums are though..
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: Magnumguy] #2328488
06/29/17 10:33 AM
06/29/17 10:33 AM
S.E.Ohio
S.E.Ohio
Same car basically, different front clip, and bumpers.
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: Magnumguy] #2328513
06/29/17 11:40 AM
06/29/17 11:40 AM
moparx Offline
moparx  Offline
having owned several 74-76 big chryslers, they suffer from the same difficulties removing those same plugs. my only solution was several modified sockets and extensions, plus using a swivel head ratchet. not a fun job for sure. wish i could be of more help.
beer
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: Magnumguy] #2328521
06/29/17 11:54 AM
06/29/17 11:54 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Used to have a 440 in my Challenger, never a fun job!
Used to love the car magazines suggesting "change them when you get to the track" Ha!
I'm sure I used a couple of different box and open end wrenches.
I think since I had to lift the car anyway I would remove as many as I could from underneath.
Manual steering gives you more room, I don't recall whether I had to loosen the headers on that side or not, definitely try it since you won't lose any coolant.
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: geo.] #2328541
06/29/17 12:43 PM
06/29/17 12:43 PM
that's what I was thinking
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: Magnumguy] #2328833
06/29/17 09:49 PM
06/29/17 09:49 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I've got headers on all my cars. I like these. http://newperformanceproducts.com/view-release.php?id=38&show=all
Re: DRIVER'S SIDE SPARK PLUG REMOVAL [Re: forphorty] #2328841
06/29/17 10:14 PM
06/29/17 10:14 PM
IN
ahy Offline
ahy  Offline
IN
I have a 400 (core engine) in a '70 Challenger with headers and PS. Plug change requires some adaptation... but not too bad after figured out. Key tools are a short "wobble socket extension", short regular extension and a box wrench that fits the hex on my spark plug socket. On several holes, I fit the socket to plug and use the box wrench to tighten or loosen.
Hardest for me is getting the tight ones started back in. Often by feel with a short socket extension in my fingers.
