3-speed wiper motor conversion #2328497
06/29/17 10:54 AM
06/29/17 10:54 AM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
I am finally replacing the original 2-speed wiper motor on my 69 Road Runner with a refurbished 3-speed motor from "Passion 4 Mopars". I unbolted and removed the original and replaced it with the new 3-speed unit. My question is with regard to the positioning of the under-dash arms that attach to the wiper motor. Does anyone have a diagram or installation manual for this swap? I have the replacement 3-speed switch, but it is not installed yet. Tom
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328608
06/29/17 02:49 PM
06/29/17 02:49 PM
Liberty, NC
djenkins83 Offline
djenkins83  Offline
Liberty, NC
I did the swap on my 69 Roadrunner also. If you don't already have it you have to get a 3 speed crank arm and bushing for a 69 B body for the linkages to line up properly. At one point there was someone making the crank arms because I found original ones hard to come by. You could check with Kim at Passion and see if she has any also. I can try and find some pictures of my setup but it would be tomorrow before I can post them
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328610
06/29/17 02:53 PM
06/29/17 02:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ditto on the arm and bushing !!
Re: 3-speed wiper motor conversion [Re: Stanton] #2328654
06/29/17 03:41 PM
06/29/17 03:41 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Jules had them done so check with Stephon at S.F. restorations
NS1AAR
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328713
06/29/17 04:51 PM
06/29/17 04:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll need two things a 3 speed switch and the correct arm. The 2 speed arm WILL NOT work with the 3 speed. Do NOT use it or you will burn up the 3 speed motor quick.
Coming soon!!!!
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328717
06/29/17 04:55 PM
06/29/17 04:55 PM
Tommy D Offline OP
Tommy D  Offline OP
Thanks for the responses. I have the arm and switch. Looking for orientation of the arm to the motor drive shaft. The drive shaft has flat sides on it. It seems to me that the XXXXXX273 arm and bushing rotate on the end of the under dash arm system. I am wondering what the installed orientation of the arm and bushing are while the wiper motor is in the parked position. Tom
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328718
06/29/17 04:56 PM
06/29/17 04:56 PM
Tommy D Offline OP
Tommy D  Offline OP
Re: 3-speed wiper motor conversion [Re: Tommy D] #2328811
06/29/17 08:30 PM
06/29/17 08:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Can only go on one way ...two sides are flat BUT one end is round and the other is flat.
Re: 3-speed wiper motor conversion [Re: Tommy D] #2329049
06/30/17 09:07 AM
06/30/17 09:07 AM
Tommy D Offline OP
Tommy D  Offline OP
Thank you.
Re: 3-speed wiper motor conversion [Re: Tommy D] #2330297
07/02/17 06:57 PM
07/02/17 06:57 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
