Re: E-Body Radio Bracket(s)?
[Re: MoreParts]
#1418367
04/11/13 06:13 PM
04/11/13 06:13 PM
Posts: 401 California, USA
filmsurgeon
California, USA
My 70 AM 8 Track uses the second one.
The top one looks like the bracket that supports the wiring up the steering column.
What an idiot I am!! Of couse; it's the bracket for mounting the steering column to the underside of the dash (which also supports the column's wiring). I guess because the photo shows it sideways, I didn't recognize it. Looking at it now that I know what it is, it's quite obvious. Thanks for the clarification.
[Re: BigMoneyLewis]
#2327919
06/28/17 08:49 AM
06/28/17 08:49 AM
Posts: 282 Ashland City, Tennessee
Aar1064
The E body radio mounting bracket for AM, AM FM, and AM 8-Track is the same. As mentioned before, the other thing is for mounting the steering column <img src="/ubbthreads/images/graemlins/laugh2.gif" alt="" />
Greg Is the arm bracket the only thing that holds radio in place? When testing radio while dash was out of my car the radio would move while inserting a tape and I was thinking that radio should be mounted at some other point as well. 8 track is being repaired by Barry's and I'd like to be ready to install once it arrives. Thanks
[Re: Aar1064]
#2327960
06/28/17 10:39 AM
06/28/17 10:39 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The bracket supports the body of the radio. There are two 3/8 head hex bolts that hold the front of the radio to the dash frame. If you have your trim installed, there are cutouts in the trim to clear the bolts. When installing, make sure you get the speaker and power wires connected while it is close but not bolted down yet. You will have to drop it again and wire it if you do not. There is not a lot of slack in the harness wiring. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2327969
06/28/17 10:50 AM
06/28/17 10:50 AM
Aar1064
The bracket supports the body of the radio. There are two 3/8 head hex bolts that hold the front of the radio to the dash frame. If you have your trim installed, there are cutouts in the trim to clear the bolts. When installing, make sure you get the speaker and power wires connected while it is close but not bolted down yet. You will have to drop it again and wire it if you do not. There is not a lot of slack in the harness wiring. Craig Awesome! Thanks for taking the time to help. Can't wait to get it installed and playing. It's been one of the "Can't wait to get that done" items ever since the beginning.
