Page 3 of 3 1 2 3
Re: Proper 2017 Oil for flat tappet classic mopar cams [Re: Prochargedmopar] #2324911
06/21/17 09:01 PM
06/21/17 09:01 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
As others have stated, the cam/springs combo is important. But, if you're just looking for VERY accurate data concerning the ZDDP of common oils, this thread is a good place to start. The data is about 3 or 4 years old, but I doubt that the concentrations have changed much.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Proper 2017 Oil for flat tappet classic mopar cams [Re: Prochargedmopar] #2324947
06/21/17 10:20 PM
06/21/17 10:20 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I have factory pattern 383 HP and I just use whatever, usually Super Tech 15w-40. Sometimes I try straight 30, 10w30, 10w-40, it doesn't seem to matter that much. However, the original valve train is nothing extreme.
If I had the current aftermarket steep cam and high spring pressure, I would be a lot more cautious.
68 Roadrunner. 383 4-spd. Beat up.
Re: Proper 2017 Oil for flat tappet classic mopar cams [Re: Prochargedmopar] #2325086
06/22/17 04:39 AM
06/22/17 04:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Myself I have used Valvoline oil since I started working on cars in the early 70's. When the VR1 racing oil came out I started using it and have used it for years. I have never built a roller cam eng for myself as all my engines have been and still are flat tappets. And knock on wood I have never had a cam wipe a lobe. Course I do make sure everything is working right like making sure all the lifters are rotating and so on. Right now I am running the non synthetic Valvoline VR1 20W-50 racing oil which I usually run in all my engines. I have always had great results with the Valvoline oil so stick with it since it has worked great for me all these years. Ron
Re: Proper 2017 Oil for flat tappet classic mopar cams [Re: Prochargedmopar] #2327884
06/28/17 02:49 AM
06/28/17 02:49 AM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
Good info.
Thanks folks.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Page 3 of 3 1 2 3
