Re: 1960 Desoto
[Re: wannadrag]
#2328749
06/29/17 06:14 PM
06/29/17 06:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
All FMJ's had the same sized disc brakes, only the drums varied and it's NA for this thread.
You can add the larger 11.75" discs if you want.
It'll handle the weight just fine.
Re: 1960 Desoto
[Re: wannadrag]
#2328817
06/29/17 08:44 PM
06/29/17 08:44 PM
Posts: 16,452 Canada
CrAzYMoPaRGuY
Canada
It'll handle the weight fine and it's not hard to toss a big block in if wanted......
CrAzYMoPaRGuY
Re: 1960 Desoto
[Re: Twostick]
#2334500
07/10/17 02:32 AM
07/10/17 02:32 AM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
Does beg the question why...
Kevin 15 years ago, the FMJ subframe was the easiest option if you wanted to upgrade the front end brakes and suspension and keep it all Mopar. The 60 Desoto would have had a torsion bar front suspension, but the original power steering unit left room for a lot of improvement. There was no easy way to accomplish that improvement. If the car was a non-power steering car, given the original power steering units draw backs, clipping the front end was about the only option back then, which brings us back to my first statement: 15 years ago, the FMJ crossmember was the easiest option. Gene
Re: 1960 Desoto
[Re: wannadrag]
#2334977
07/10/17 10:17 PM
07/10/17 10:17 PM
poorboy
Freeport IL USA
So would the inner fenders be part of the front structure on these early cars? Do I need to maybe add a support from the front of the rail to the firewall? Car will have a 440 in it My son has a 57 Dodge, and we had a 62 Chrysler here for a short time, both have pretty substantial front frame rails, I doubt the inner fenders add much support. On my son's car, the inner fenders are basically curved tin that fills the gap between the outer fender and the frame rail. The passenger side holds the battery, and the passenger side holds the air cleaner assembly.
Re: 1960 Desoto
[Re: wannadrag]
#2334986
07/10/17 10:25 PM
07/10/17 10:25 PM
poorboy
Freeport IL USA
It does need a windshield. Bobs classic auto glass from Oregon has them,any other options? As far as a rear bumper,what years are the same? Does the Chrysler,Dodge or Plymouth from that year share any parts? Can't help on the windshield, but from what I've seen most of the brands have their own version of bumpers, and some are more narrow then others. Others may bolt up, but won't match the surrounding sheet metal. The sort of good news for you is that the Desoto line was nearing the end of its production (I believe 62 was the last production year), that would mean that the bumpers may have carried on for a couple of years unchanged, or slightly changed. A lot of Chrysler stuff was nearly the same from 1960 through 1962 model years. Gene
Re: 1960 Desoto
[Re: wannadrag]
#2335125
07/11/17 01:39 AM
07/11/17 01:39 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
1961 was the last year of Desoto.
The inner fender wells are not structural. But they mount the battery box, starter relay, and voltage regulator on the left fender well. The wire harness has wires that go to ground at the voltage regulator bolt.
The rear bumper shape is the same on 1960 Chrysler but they had different or deleted bumper guards, not that big bumper guard in the center like that desoto picture. I have a 69 Chrysler I can measure or take photos of the brackets underneath to see if it will fit your car.
