Spark plug choice for 11-1 410 stroker. #2326722
06/26/17 01:33 AM
06/26/17 01:33 AM
Ohio
moparjoe360.4 Offline OP
Ohio
I've always run the old technology RN9YC Champion with absolutely no complaints. I'm building a new stoker small block and have been wondering is there's a better choice for a plug. I'll be running a Scat 4 in. crank and I beam rods, Icon 744 flat top pistons with open chamber 974 casting with 2.02 intake valve, .508/292 purple shaft and air gap intake wit 750 hp style double pumper, and stock re curved dizzy with chrome box and super stock style coil. Thanks for any help you can give.
Re: Spark plug choice for 11-1 410 stroker. [Re: moparjoe360.4] #2326764
06/26/17 04:06 AM
06/26/17 04:06 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would try those plugs to start with up If there to hot try the next step colder, RN7YC or if you can get them RC7YC or RN6YC or RC6YC up
Re: Spark plug choice for 11-1 410 stroker. [Re: moparjoe360.4] #2326829
06/26/17 10:25 AM
06/26/17 10:25 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
A 7 in a ngk worked good in my 408 same comp.
Re: Spark plug choice for 11-1 410 stroker. [Re: mopar dave] #2326880
06/26/17 11:45 AM
06/26/17 11:45 AM
UK
rb446 Offline
rb446  Offline
UK
^^^^^^ up
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Spark plug choice for 11-1 410 stroker. [Re: moparjoe360.4] #2327411
06/27/17 09:09 AM
06/27/17 09:09 AM
Ohio
Ohio
Thanks guys! It looks like NGK offers a lot of options in the7-9 heat range, including non resistor race plugs, but all I'm seeing in the Champion line is resistor plugs. Will I see any advantage between non resistor vs resistor plugs?
Re: Spark plug choice for 11-1 410 stroker. [Re: moparjoe360.4] #2327478
06/27/17 12:18 PM
06/27/17 12:18 PM
Washington
madscientist Offline
Washington
If you want a non resistor plug in a Champion you need a C65CX. That is the hottest of that series. If you want a colder plug than a C63CX would be 1 colder and a C61CX would be 2 steps colder.
