Re: 1 7/8 vs 2" Headers
[Re: DusterKid]
#2326844
06/26/17 10:52 AM
06/26/17 10:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Need more info.. what will it be used for.. but with that small and that low the 1 7/8 would be fine
[Re: MR_P_BODY]
#2326864
06/26/17 11:18 AM
06/26/17 11:18 AM
Posts: 1,768 Keymar, MD
DusterKid
Keymar, MD
Car is a Duster, 440 .030 over 10.5:1, .590 solid cam, 440 source heads, Victor 440 intake, 750 carb (will be going bigger in the future), 727 w/5000 stall conv, Dana 60 4.56 gears. Has been 10.7's. I had Hooker 1 7/8 fender-well headers on the car but disliked that I was limited on front tire size. I took the inner fender-wells out, put the bar from the cage to the front of the frame to tie it all together, but in doing so the way I ran the bars I am unable to run the fender-well headers unless I customize them. So I bought a set of TTI 2" headers. Car really didn't pickup or lose anything in 60', ET or mph wise. TTI fit nicely, but are a HUGE pain to work on. I have another car that I have 1 7/8 TTI's on that I will be changing from BB to SB and thought about putting them on the car to make it easier to work on, or maybe try and modify the fender-wells headers I have to make them fit.
[Re: DusterKid]
#2326951
06/26/17 01:50 PM
06/26/17 01:50 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I'd say that if you can use the 1 7/8" go for it because the 2" can be a pain. I have always used the 2" Hedman slip fits and even those are are not fun.
Have a great day Iowan
"obsolete is neat"
[Re: DusterKid]
#2328115
06/28/17 04:03 PM
06/28/17 04:03 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For that combo, imo, if you're only turning it 6300, you're not revving it high enough for the 2" to be of any real benefit.
The 1 7/8" Hooker fenderwells make big tq numbers, in part because they're so long........so you def would have taken a little step backwards in the lower part of the power curve by using 2" TTi's instead. May not matter with 5000 stall though.
If you're primarily running 1/8 mile, then it would be even harder to exploit and possible gains from the 2" headers.
Not what you asked...... But...... The cr seems a bit low for a 270@.050 cam. Not sure it would be worthwhile to swap it, just saying it wouldn't have been my first choice, especially for the modest rpm you're turning.
What are the performance numbers out if the car?
[Re: DusterKid]
#2328407
06/29/17 01:30 AM
06/29/17 01:30 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
[Re: DusterKid]
#2328414
06/29/17 01:42 AM
06/29/17 01:42 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
My guess is its gonna like that bigger carb.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
