Re: I need intake help
[Re: moparcyco]
#2326176
06/24/17 06:26 PM
06/24/17 06:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I am a little sceptical of the lower levels sharp bends where it turns to go into the head, the port is nearly verticle in the head and the port is horizontal making a hard turn down into the port. I wouldn't buy one till I saw some hard evidence from a reputable builder that it was comparable to other ones like the arrow racing single plane.
[Re: moparcyco]
#2326272
06/25/17 12:33 AM
06/25/17 12:33 AM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
Cbusters, when did you call? I don't remember getting a call and if I didn't call you back I do apologize. There are lots of ways to contact me but i can't always answer the phone. I do not recomend my intake for forced induction. Boost does not like to turn corners. I have 2 customers that have used them anyway. One in a twin turbo application and one in a supercharged application. If you did use one I wouldn't go over 8 psi or so.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
[Re: moparcyco]
#2326273
06/25/17 12:39 AM
06/25/17 12:39 AM
Posts: 784 Florida
cbusters
How do you like the intake? performance? Are you running mpi? happy with it?. Also are you running a car or truck front cover? hows the fit. Thanks I am still building. I have the 4150 model and my findings to date are: It is a dry intake being used wet which means it has o-ring style gaskets that don't like modern fuel. The fix is Edelbrock solid gaskets and sealant filling the grooves on the bottom of the intake. Truck front because I wanted the PS, A/C and Alt all in the classic locations. Intake is about 2 1/2 taller than the stock RB is. I am going with a throttle body EFI and MSD Hemi Ignition controller. The vision is a very retro, classic and production looking install. I have the major top parts bolted on and now working on the exhaust system while the car is gutted and on the lift. We scanned a 69 Hemi H-pipe and bent a regular exhaust tube copy Friday. Next week we will cut off the front section and tack on a new splice to the 5.7 manifolds and then re-scan. Then we bend the final Stainless one piece front pipes and weld in the crossover. Once we scan the rear end sections and copy them everything will be SS and look original 69 RR. Except smaller diameter and never any rust! We started mocking up the Classic Air A/C system so I can pick a spot for the MSD unit inside. Mainly getting body holes put in before it goes to paint. So far the issues are little pita ones that no one can answer for me.
[Re: moparcyco]
#2326280
06/25/17 01:13 AM
06/25/17 01:13 AM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
Cbusters, I couldn't help you with an intake and I am sorry but you are doing stuff that I did 10 years ago. If I can answer a question, I would be happy to.
I'm sorry OP, I didn't mean to Hyjack your thread.
[Re: moparcyco]
#2328189
06/28/17 07:09 PM
06/28/17 07:09 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Well, it's a little more complex than finding the right circular dimension and material. Good thought, though. It'd probably be thousands for prototype tools to mold these in the material of your choice. But yes by all means, send them out for a quote and see if interested in going into business. MP had regular gaskets for this purpose but not sure if they still make them. It's odd Edelbrock doesn't know about the compatability issue as shown here http://www.edelbrock.com/automotive/misc/tech-center/install/7000/7528.pdf...or maybe they know and aren't doing anything about it. The factory rubber ring type will work wet----for a little while. If you drive everyday, they will swell up in a matter of weeks or months.
Rich H.
Esse Quam Videri
[Re: Hemijoejr]
#2328270
06/28/17 09:24 PM
06/28/17 09:24 PM
Posts: 784 Florida
cbusters
Cbusters, when did you call? I don't remember getting a call and if I didn't call you back I do apologize. There are lots of ways to contact me but i can't always answer the phone. I do not recomend my intake for forced induction. Boost does not like to turn corners. I have 2 customers that have used them anyway. One in a twin turbo application and one in a supercharged application. If you did use one I wouldn't go over 8 psi or so. No big deal on the reply thing. Don't remember what days I called or when I left the message, but I gave it a few days and went a different direction. Being active here is great and makes you a bit easier to reach and I will keep your offer for help in mind. Questions never seem to end on my project so I may take you up on it. In hind sight your intake would not have been the best choice for my build anyway, so neither of us lost anything. It is good to have options!
[Re: cbusters]
#2328798
06/29/17 07:53 PM
06/29/17 07:53 PM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
I'm on Instagram and Facebook. I also am a member of this page and forabodiesonly. I also take emails through info@oc-performance.com. I am a one man band and I still have a full time job in conjunction with my engine building, testing, and intake business so I usually can't get to the phone. My Cuda has been featured in Mopar Muscle and Mopar Action magazines. I have made my own coil relocation setup with Indy valve covers, Had an Edelbrock dual quad, Sheet metal cross ram, and my intake on my car. I also have the old round back alternator on it with heater hoses that comes from the top of the water pump. Like I said if you have questions please let me know.
