Just checking. Mag swap
#2325285
06/22/17 03:47 PM
06/22/17 03:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Plan on putting a 5.9 mag in my van this weekend. I just want to make sure that the magnum flex plate will bolt up to a regular converter without issue. Im putting it in from the bottom.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Just checking. Mag swap
[Re: sixpackgut]
#2325366
06/22/17 06:48 PM
06/22/17 06:48 PM
sixpackgut
Charleston
Sorry the magnum flex plate to a regular converter??
[Re: sixpackgut]
#2325414
06/22/17 08:51 PM
06/22/17 08:51 PM
Posts: 15,548 Norwich CT USA
moparts
Norwich CT USA
Sorry the magnum flex plate to a regular converter?? Yes, the magnum weighted flex plate will bolt to the smaller wide ring gear no weight TQ bolt pattern with a little modification. The flex plate has all even spaced bolts, so the one offset bolt will need to be egged out to fit the offset TQ.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2325455
06/22/17 10:37 PM
06/22/17 10:37 PM
sixpackgut
Charleston
Sorry the magnum flex plate to a regular converter?? Yes, the magnum weighted flex plate will bolt to the smaller wide ring gear no weight TQ bolt pattern with a little modification. The flex plate has all even spaced bolts, so the one offset bolt will need to be egged out to fit the offset TQ. Thanks. I didnt know that. Glad i asked
