Advices to Setup Double Adjustment Shocks (Updated) #2324137
06/20/17 12:21 PM
06/20/17 12:21 PM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hi Folks,
Finally I could test my new set of Viking DA Shocks that I installed in my car. These shocks already improve my 60ft from 1.58 to 1.54 but I'm still having tire bouncing on the start.
I'm using this setup on the Shocks:
Front: Compression = 12, Rebound 2.
Rear: Compression = 4, Rebound 12.
My car is an A Body, 3300lbs Small Block with 464WHP, Footbrake, 4500 Stall Converter, Hoosiers 28x10.5, 4.56 Gear, Leaf Springs with Assassin Traction Bars.
I'm sending two videos of the start... So if someone could see that and can support me to fix this issue will be great.
https://www.youtube.com/watch?v=kpsFBEn8U4A
https://www.youtube.com/watch?v=ErDPMz66wkw
Thanks,
Diego Reis
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2324345
06/20/17 07:27 PM
06/20/17 07:27 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Stiffen the extension and the compression.
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2324477
06/21/17 12:21 AM
06/21/17 12:21 AM
If compression is going down and rebound is extending the shocks I would stiffen up the front shocks on compression and loosen up the extension some more, probably the same on the rear twocents
Have you check the rear spring rear shackle angles with the suspension unloaded with the wheels off the ground and no weight on the rear tires by having jack stands under the frames yet? If no do that and see what angle you have on the rear shackles scope
If they hang straight down or are angled towards the front end you need to think about fixing that scope shruggy
Re: Advices to Setup Double Adjustment Shocks [Re: Cab_Burge] #2324573
06/21/17 09:30 AM
06/21/17 09:30 AM
Shackles looks like fine but I'm plannig change them for Sliders ASAP... smile
Suspension Loaded
Suspension Unloaded
Another thing that I'm looking is Traction Bars angle. I'm running with lower holes mounted front/rear and I understand that I'm having a very agressive rear tires hitting on the ground with this combination because front of the bar is higher them rear and when I leave the brake and car launch, loading suspension this angle change a lot hitting tires on the ground so hard as you can see on these picture that I posted above...
So, make sense or don't?
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2324636
06/21/17 12:13 PM
06/21/17 12:13 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Looking at the 1st video, the car plants the tire fine then it bounces back up in the car. To get rid of that hop, tighten the compression on the rear from a 4 to a 7. that should keep the tire planted.
Joe
Without Data, you’re just another guy with an opinion.
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325480
06/22/17 11:22 PM
06/22/17 11:22 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
It looks like the front is running out of travel and offloading the rears. I probably have 20 - 30 videos of mine doing the same. If you can, lower the front to get as much travel as possible - set the front shock rebound (extension) to full loose and start making passes. Tighten the rebound 10% each pass until the 60 foot times start to fall off.
I tried to sort out the rear first and didn't make any progress until I added travel and started tightening the front. I now have 5" of travel in the front with standard valved Dual Adjustable AFCO's and already ran out of rebound adjustment, but went from 1.48 60's to 1.41's. They are currently getting revalved with stiffer valving.
Also make sure your rear shocks are long enough by unbolting the shocks and letting the rear hang. The shocks should be an inch or two longer than the distance between the upper and bottom mounts when suspended.
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325517
06/23/17 12:23 AM
06/23/17 12:23 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Make only one change at a time.
Looks like it extends/separates way too much to me. Tighten, if you have any more adjustment, the extension. The compression could be set in whatever the middle is to start.
Personally I like to start with everything, front, and rear tight hoping it'll spin, then loosening up only what it takes to get the best 60.
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325580
06/23/17 03:14 AM
06/23/17 03:14 AM
Me thinks the rear shackles are going past center(straight up and down) when it leaves and that will make the rear unload causing the hopping shruggy
Is there any way you can video the back of the car by the rear springs, Go Pro camera maybe, to see if that is happening or not?
I've seen that same problem on more than one A body drag car work
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325731
06/23/17 02:00 PM
06/23/17 02:00 PM
Guys, I really appreciate all advices that everyone gave me. I'll make some changes based on your advices and post all improvements here.
Thanks a lot!
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325742
06/23/17 02:32 PM
06/23/17 02:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As DT pointed out start stiff and go from there. Depends on track conditions what will make it happy. Looks like it is separating to much to me as well and I would follow his way. Tighten the extension start with compression in the middle...
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2325755
06/23/17 02:56 PM
06/23/17 02:56 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Originally Posted By 360tripleblack77
Hi Folks,
Thanks,
Diego Reis
Diego
That is such a cool looking A Body. I have never seen a South American A Body before. They should have offered that style here. They would have sold a lot more A Bodies. I LIKE IT!
Old Geezer Racing
Re: Advices to Setup Double Adjustment Shocks [Re: SCATPACK 1] #2330560
07/03/17 10:15 AM
07/03/17 10:15 AM
Thanks ScatPack! I really like the body and details of Brazilian Chargers. Basically the body is the same them 68' Darts with some changes in details... smile
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2330570
07/03/17 10:46 AM
07/03/17 10:46 AM
Folks, I measured front end travel this weekend and had 4.2" of travel... So I reworked the suspension bumpers that was blocking my front end travel and lowered front of car 1/2" and now I've 5". I know that the golden rule is do not change more than one thing per time but I'm thinking in tight rear shocks extension from 12 to 18 to start.
Jully 22, 23 will have an event and I will can test my last adjustments...
Thanks Guys!
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427718
01/02/18 02:02 PM
01/02/18 02:02 PM
As I posted in another topic, my car has made his best ET so far. I could drop 60ft from 1.54 to 1.50 based on advices that I received from everyone on this topic. up
The problem with tire boucing is almost solved but the car still boucing tires on start. I'm thinking that rear separation is too much as Al Alguire told me before and you can see at picture attached. I have put extra clamps on front segment of leaf springs but I think that's not enough. Maybe time to change for Calvert Mono Leafs! wrench
I started with last configuration that I ran on the rear, 12 rebound and 4 compression and ran at 1.51. So I tighten the rebound for 14 and compression to 5 and 60ft droped to 1.50. I just could made only three passes and don't had time enough to work more on suspension. If I had time I'll tighten more rear shocks but I couldn't.
I'm sending below a video from my GoPro camera that I installed under the car. Sorry for the quality but was darken when I made the video.
Advices will be great again.. laugh
https://youtu.be/FqMf1UC3lVs
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427726
01/02/18 02:17 PM
01/02/18 02:17 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
It looks to me like.. your settings are still way too loose.. and yes the monoleaf is the way to go it also helps get rid of weight. On compression you should be. Almost full tight... and on extension somewhere in the middle.. if the track is greasy you can loosen extension up for some extra hit... the front end looks way to stiff.. do you have aftermarket a arms.. the Freer you can get the front end the better the car will work
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Advices to Setup Double Adjustment Shocks [Re: WHITEDART] #2427758
01/02/18 03:06 PM
01/02/18 03:06 PM
I'm talking with Calvert tech support right now about monoleaf. This should be my next upgrade. I agree with you about front too stiff. I'm running on Rebound 2 and Compression 12 and I lowered front of the car to have more front end travel. currently Front end travel is 5" and still looks too stiff.
About control arms I'm still using OEM arms and torsion bars too. frown
Any recomendation of wich control arms to use?
Best 1/8 mile ET
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427791
01/02/18 04:00 PM
01/02/18 04:00 PM
That looks good to me up
There is always more in it as we get brighter and hungrier for more speed and quicker ET whistling devil
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427809
01/02/18 04:20 PM
01/02/18 04:20 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I have the early qa1 upper control arms on my car they don't make that version anymore.. at least so I think.. I think Hotchkiss make some nice upper control arms kind of spendy you might take a look..
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427815
01/02/18 04:27 PM
01/02/18 04:27 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I have been eyeballing these...seem reasonable. Anybody using them?
http://www.magnumforce.com/magnumstore/shop/item.aspx?itemid=13
71 440-6 4spd & 69 Hemi 4spd
Re: Advices to Setup Double Adjustment Shocks [Re: 360tripleblack77] #2427817
01/02/18 04:30 PM
01/02/18 04:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As Shiloh pointed out to many people overlook the front end and just how tight many of them are. Not talking about the shocks them selves per se' just the suspension in general. As for the rear shock keep tightening the extension til it spins smile Soften the rebound as much as it will tolerate as well for now. Generally speaking the extension controls the hit or plant of the tire and the rebound how well or long it plants the tire..
With the numbers you are talking are you referring to how far from stiff or from soft they are?? Just to clarify
