Power Steering Pressure Line - 1968 Charger R/T
#2325713
06/23/17 01:10 PM
06/23/17 01:10 PM
Posts: 102 Colo
PJ68RT
Colo
I'm looking for a replacement power steering pressure line/hose for a 1968 charger R/T with a/c (if that matters). It seems there are a few different P.S pumps for this year. I can't seem to find a re-pop of this style of hose. Any help would be appreciated.
Re: Power Steering Pressure Line - 1968 Charger R/T
[Re: Dave Hall]
#2325809
06/23/17 04:48 PM
06/23/17 04:48 PM
dogdays
So I went to the Autoparts Reference Library (Rockauto) and found that there are brand new hoses available for less than you would have paid to get your hose rebuilt. I hope you can use one of those. $21 at Autozone.
R.
[Re: PJ68RT]
#2325824
06/23/17 05:31 PM
06/23/17 05:31 PM
Posts: 21,346 It's a dry heat
gtx6970
It's a dry heat
I just went thru this exact scenario last week. The ONLY place I could find a line for a 1968 was Rockauto..... At almost $200
I got one locally for a 1969 Charger, and all I had to do was change the male fitting in the gear box. Best of all, it was less than $40 ( the flare fitting is larger on a 1969 and up. The threaded port in the box was the same.
edit, added pics
[Re: gtx6970]
#2325861
06/23/17 07:01 PM
06/23/17 07:01 PM
Posts: 102 Colo
PJ68RT
Colo
Thanks for the replies. I would prefer something that looks OE, but that appears to not exist...execpt for NOS $$$. I do see both Rockauto and Napa have two hoses available, one is $20 the other is $170. Both look nothing like the original.
[Re: PJ68RT]
#2325923
06/23/17 10:01 PM
06/23/17 10:01 PM
Posts: 2,138 tucson az
frank
tucson az
