fiberglass hood warping #2325675
06/23/17 11:39 AM
06/23/17 11:39 AM
pa
gregcharger72 Offline OP
pa
recently had a fiberglass hood made for my 72 charger and after a couple of days in the sun it is starting to lift in the middle and no longer flush with the fenders. is this normal? is there anything that can be done about it?
Re: fiberglass hood warping [Re: gregcharger72] #2325677
06/23/17 11:42 AM
06/23/17 11:42 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you are using stock hood hinges and springs, take the springs off and use a hood prop or use lighter tension springs. Early AAR AND T/A E-bodies with glass hoods have the same issue.
Re: fiberglass hood warping [Re: GY3] #2325684
06/23/17 11:53 AM
06/23/17 11:53 AM
pa
pa
i have light hood springs on it now i got from the hardware store and is very easy to close . would a prop rod be better? And remove the springs altogether ?
Re: fiberglass hood warping [Re: gregcharger72] #2325762
06/23/17 03:07 PM
06/23/17 03:07 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Welcome to the wonderful world of fiberglass. The factory painted these with black Organasol because they tended to look crappy with changing weather conditions. It's always going to do a little something. Get it the best you can and walk away. BTW Car looks great!
Re: fiberglass hood warping [Re: Dave Hall] #2325954
06/23/17 11:43 PM
06/23/17 11:43 PM
pa
pa
Thank you Dave. It is my first use of fiberglass,I'll leave it alone.
Re: fiberglass hood warping [Re: gregcharger72] #2325961
06/23/17 11:55 PM
06/23/17 11:55 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I bought my fiberglass hood back in 1975, it sagged right from the day I put it on. To fix it at the time I fiberglass a U shaped piece of 1/2" electrical conduit to the underside. No sag after almost 40 years.
Re: fiberglass hood warping [Re: Dave Hall] #2326131
06/24/17 03:34 PM
06/24/17 03:34 PM
crlush Offline
crlush  Offline
iagree
Re: fiberglass hood warping [Re: gregcharger72] #2326154
06/24/17 05:06 PM
06/24/17 05:06 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2..... try a lightweight race hood. Fits different as the temp changes.
Re: fiberglass hood warping [Re: J_BODY] #2326567
06/25/17 07:27 PM
06/25/17 07:27 PM
pa
pa
interesting......
Re: fiberglass hood warping [Re: gregcharger72] #2326768
06/26/17 04:18 AM
06/26/17 04:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My glass hood is a race type hood as its a light hood and its to thin on the edges to put it on hindges. It will sit up a tad in the corners when the eng is cold but after I drive a bit and the eng warms up the edges drop some and then sit a tad low. Not much I can do about it as I just figure thats one of the quirks of a glass hood. Ron
Re: fiberglass hood warping [Re: gregcharger72] #2326806
06/26/17 09:29 AM
06/26/17 09:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
So many folks complain about glass hoods being junk. From poor fitment to not taking paint...
How did corvette make entire car bodies from it for so many years? Are they still using glass or is it urethane now?
**Photobucket sucks**
Re: fiberglass hood warping [Re: 70Cuda383] #2328820
06/29/17 09:06 PM
06/29/17 09:06 PM
pa
pa
I don't think the hood is junk, I'm quited pleased with how it looks and functions just did not expect the movement with the temperature.Now that the car is in garage the hood is back to the orginal position.
Re: fiberglass hood warping [Re: 70Cuda383] #2329080
06/30/17 11:20 AM
06/30/17 11:20 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I wonder if they were just much, much thicker? Thick enough that there's no weight savings over steel....
Re: fiberglass hood warping [Re: DaytonaTurbo] #2329493
07/01/17 03:35 AM
07/01/17 03:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know many glass hoods are thicker then mine at the edges. We used to call them street or race hoods as mine is to thin near the edges to mount it on the hinges so it has to be a lift off unless a good glass worker made it thicker. But the hood itself seems thinner then the stock type that came on 6 pack cars. So I would be pretty sure the Corvette had thicker figerglass on most of the car. My back two corners only sit up mayne about 1/8 to 1/4" when cold but when I drive it and the eng warms up they end up dipping about 1/4". Just catch me when the eng is about 160 and the hood fits perfect. grin Ron
Re: fiberglass hood warping [Re: 70Cuda383] #2329527
07/01/17 10:05 AM
07/01/17 10:05 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Corvettes are engineered to be glass from day one, so they can add reinforcements and tweak the shapes to minimize the bending. Lightweight race parts aren't concerned with it. The "street" parts are usually just reinforced around the hinges and hood catches, but they can't do much for the overall shape of the hood after the fact. twocents
Re: fiberglass hood warping [Re: gregcharger72] #2329713
07/01/17 02:00 PM
07/01/17 02:00 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
gregcharger72 we need more pictures of that car! From what I can see it looks bitchen!!!
Re: fiberglass hood warping [Re: Dave Hall] #2330386
07/02/17 10:10 PM
07/02/17 10:10 PM
pa
pa
thanks!
recent picture before i put the fiberglass hood on.engine picture with scoop seal i made.
Re: fiberglass hood warping [Re: gregcharger72] #2330492
07/03/17 02:03 AM
07/03/17 02:03 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nice! I see you are running that Mancini tall throttle bracket. My Dart has that one as well. I went ahead and painted it black. Are those elastomeric bumpers or painted? I'm a blackwall out kinda person as well. Makes your rims look sharper! Nice car Greg! up
Re: fiberglass hood warping [Re: Dave Hall] #2331617
07/04/17 10:47 PM
07/04/17 10:47 PM
pa
pa
the bumpers are painted, much cheaper than re chroming . I'm a, less is more, kind of guy. needed the tall bracket when i put a one inch spacer under the carb . the hood and scoop with the spacer dropped my et almost 4 tenths and increased the mph 3.5 mph
