Re: 33 plymouth 2 dr. sedan
[Re: 2abodymcodes]
#2264224
03/06/17 12:10 PM
03/06/17 12:10 PM
Posts: 7,506 Az
Crizila
Az
Nice work!! Just from the looks of it, you might have to go with a special off set if you want the rear tires to sit with-in the rear fenders - lots of off set to the inside. Beautiful cowl ship logo! Hard to find!
Fastest 300
[Re: 2abodymcodes]
#2276949
03/27/17 02:18 AM
03/27/17 02:18 AM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Making some progress on my 33. Mounted my tail lights. They are Mad Dad brand LED Harley Davidson tail lights. Pretty bright for the size of them. I also have my rear hubs and rotors at a machine shop getting them re-drilled to 5x4.50 They were 5x 108mm and I they don't make very many wheels that size. I had bought wheel adapters, but that set them out too far. Those taillights look pretty cool. My only concern is the angle they appear to be mounted at. Are they going to be easy to see from behind, for the person following you at a safe distance, or will they not be able to see them until they get up too close? Gene
[Re: 2abodymcodes]
#2279891
03/31/17 10:00 PM
03/31/17 10:00 PM
Posts: 2,502 Shelby, Ohio
2abodymcodes
Shelby, Ohio
The body is finally all together. Next I have to make some bumper brackets to tuck the stock front bumper in close to the body and send my stock front bumper to Tri-City for chrome. I'll have to make my rear bumper.
[Re: 2abodymcodes]
#2325481
06/22/17 11:25 PM
06/22/17 11:25 PM
2abodymcodes
Shelby, Ohio
I haven't been on here for a while. slowly making progress on my 33. Installing my Painless wire harness ,hooking up the lights and so stuff. Wife didn't like the looks of the stock bumper so I made some out of thick wall 1 3/4" tubing. Sent them to the chrome shop and just got them back this week. I also made some brackets to fit a Harley Davidson front light bar to the front bumper. Had all the brackets chromed. Everything looks good. The small round lights are my LED front turn signals and also running lights.
[Re: 2abodymcodes]
#2331106
07/04/17 12:29 AM
07/04/17 12:29 AM
poorboy
Freeport IL USA
njdevil2, I suppose you could pull off this build you want to do in 2 years, you have your work cut out for you, for sure. Realistically? I think the "a garage on the way" is going to be a problem, unless that "garage on the way" is a fully equipped shop your getting next week.... Then, I'm a bit concerned about the questions your asking, it sounds like you may not have a lot of experience. 2 years on this big of a build is going to have a pretty steep learning curve. I suggest you get started now... This is not to say it can't be done. If you start out with a modern Hemi car, pull the sheet metal, and cover the chassis with a 40s (or 50s) body (a 30s body is too small to be even close to fitting), the time frame might look more promising. Your still going to have to perform a lot of modifications to the chassis so it will mate up with an old body, and then you will have a lot of modifications to do with the body so it will look OK. On www.killbillet.com (its a rat rod site, and you may have to join to see the pictures, its free to join) in the 50s truck section there was a guy that put a 50s international pickup body on a Hemi Durango chassis. The build was pretty well documented, with pictures and descriptions of the process. The same process could be done with nearly any 40s or 50 Mopar car or truck, and the body can be finished to suit. Gene
[Re: 2abodymcodes]
#2332093
07/05/17 07:03 PM
07/05/17 07:03 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
Well, Gene, thanks for the feedback. I am NOT by any means a body man, however I am well versed in suspension, mechanical, braking and electrical. By no means am I a BODY SHOP kinda guy. That being said, there are other means than scratch built, there are 2 local "projects" that I can take on where the body is about done and I can install the powertrain of my choice and adapt what I need to. There are, of course, ways to build things and I see that this and your projects are ground up. I'm not going for that. I have friends that weld and weld very well, thank you. I have all the tools needed to complete whatever I start. I am a mechanical by trade. Thanks for the "warning".
1970 road runner Convertible 1 of 179
[Re: 2abodymcodes]
#2487921
04/25/18 07:27 PM
04/25/18 07:27 PM
Posts: 1,510 AZ
Mike P
AZ
Fantastic!!!!!
It took me 15 years before I got to test drive my 37 Dodge. I can attest to how good it feels to have them move without having to push them.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
