18 gauge wire enough to trip starter relay? #232547
02/22/09 01:19 PM
02/22/09 01:19 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Hey Moparts,
I am wiring my switch panel and am debating on using an 18 gauge wire for my starter relay. I am using control wire so its got 12 wires all bundled together that will be running from my shifter console to my relay panel. I would like to use one of these wires if possible but I for sure don't want to overload the wire going to the starter relay. This 18 gauge stuff is doing nothing but triggering relays for my fuel pump etc. If it matters I don't know if I will use the mopar starter relay or the ford style. Thanks
Clark
68 Barracuda Formula S 340
Re: 18 gauge wire enough to trip starter solenoid? [Re: Bad340fish] #232548
02/22/09 01:27 PM
02/22/09 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The length and load determine the size of the wire,
I would have to guess the load wouldnt be greater
than 1.5 amps at max... the load is the coil in the relay
BUT maybe one of the electrical wizards will chime in
Re: 18 gauge wire enough to trip starter solenoid? [Re: MR_P_BODY] #232549
02/22/09 01:31 PM
02/22/09 01:31 PM
Tulsa OK
Tulsa OK
The load is what I didn't know. Length will be from the shifter console(TA) to the relay at or near the stock location.
Last time I wired this car I was 17 and didn't know what I was doing. I figure 13 years later is a good time to sit back and do it correct and clean lol. Also using more than just one color of wire .
Re: 18 gauge wire enough to trip starter solenoid? [Re: Bad340fish] #232550
02/22/09 01:55 PM
02/22/09 01:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
18 Ga. will be fine.
Re: 18 gauge wire enough to trip starter solenoid? [Re: NITROUSN] #232551
02/22/09 02:02 PM
02/22/09 02:02 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I think the original 12V+ wire coming from the IGN SW is Blue 16 ga. But the yellow ground wire going through the neutral safety SW is 18 ga. I think 18 ga will be fine.
SRT DEMON ONE SEAT
Re: 18 gauge wire enough to trip starter solenoid? [Re: Ron Silva] #232552
02/22/09 02:40 PM
02/22/09 02:40 PM
Tulsa OK
Tulsa OK
Great!
Thanks for the info and replies.
