high idle #232443
02/22/09 09:54 AM
02/22/09 09:54 AM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
had a new gremlin this weekend. Once motor is hot [3-4passes] the engine goes to a "high idle" around 2000rpm after the burnout and will not come down even and after clearing it out numerous times etc.
any ideas what could cause this?
throttle cable appears to be fine and fully closing when off the pedal
Re: high idle [Re: MegaDart] #232444
02/22/09 10:12 AM
02/22/09 10:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
check the springs in the dist if it's not locked out.
Re: high idle [Re: Quicktree] #232445
02/22/09 10:13 AM
02/22/09 10:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
also check to see if the carb is going all the way back to idll posistion.
