2003 1500 4.7 running hot....... #2323752
06/19/17 06:50 PM
06/19/17 06:50 PM
wheeling, west virginia
W
wvjohn Offline OP
wvjohn  Offline OP
W
2003 1500 4x4 4.7 going up long hills , temp gauge starts creeping up.replaced radiator, was original,195 thermostat,auto zone water pump, plastic impeller,it is shaped like 2 round dics with vanes in middle.still runs hot on a pull. any help is appreciated.not losing any fluid, bled system, correct anti freeze, new mopar heavy duty clutch fan bottom hose not collapsing.
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2323828
06/19/17 09:17 PM
06/19/17 09:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
probably head gaskets, a small leak might not put gasses in the coolant till its under a heavy load.
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2323899
06/19/17 11:24 PM
06/19/17 11:24 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
^^ x2
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2324028
06/20/17 08:35 AM
06/20/17 08:35 AM
places
79powerwagon Offline
places
Maybe you should explain exactly what you mean by "it's running hot" first before you go running to buy parts. smile
Re: 2003 1500 4.7 running hot....... [Re: 79powerwagon] #2324589
06/21/17 10:27 AM
06/21/17 10:27 AM
W
wvjohn Offline OP
wvjohn  Offline OP
W
when you read the problem it says temp gauge starts creeping up.rad was showing signs of age, water pump bearing had massive play in shaft,t- stat was replaced before 6 years ago. not throwing parts at it, eliminated some obvious.could be a lot of different problems, asking if anyone else experienced and solved what is and isn't normal operating temps.thanks for anyones help
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2325258
06/22/17 03:01 PM
06/22/17 03:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
We have worked on tons of them in my shop, 2 are in here right now for head gaskets and cracked heads. I don't stock much for new parts here except oil, oil filters and 4.7 head gaskets and timing chain sets. The symptoms are exactly what you describe and typically begin after overheating because of a faulty water pump or radiator. The 4.7 can not stand to be overheated at all, pretty much instant failure of a head gasket when the gauge goes over 1/2 way and 3/4 pretty much means cracked heads.
Re: 2003 1500 4.7 running hot....... [Re: HotRodDave] #2325851
06/23/17 06:39 PM
06/23/17 06:39 PM
W
wvjohn Offline OP
wvjohn  Offline OP
W
thank you for some excellent and knowledgeable info. next step was a leak down test
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2326148
06/24/17 04:43 PM
06/24/17 04:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Even easier and more concise is just do a chemical test of the coolant for exhaust gasses, napa carries the tester and it takes about 30 seconds. I buy a lot of those 4.7 rigs and never buy one without testing it and most of em are blown head gaskets or cracked heads.
Re: 2003 1500 4.7 running hot....... [Re: wvjohn] #2336522
07/13/17 03:24 PM
07/13/17 03:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
HotRodDave is the expert on here for the 4.7.
He will also tell you that it is very easy to warp the heads on the 4.7 and if you have to replace a head gasket, replace the timing chain set and adjusters.
Craig
