Page 1 of 3 1 2 3
Roadrunner day two street racer ideas. #2323469
06/19/17 08:24 AM
06/19/17 08:24 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I'm looking at building a '69 Roadrunner post car into a day two street racer for a bit of fun, I have many period correct parts left over from other projects but need some ideas about what intake, carb, ignition & rocker covers etc to run.
The car is a 383 4-speed car but I will be updating the 383 with a 440 & the magnum 500 style wheels will probably go in favour of original Keystones, Super tricks or a combination of the two.
What are your thoughts? Thanks
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323474
06/19/17 08:47 AM
06/19/17 08:47 AM
fullmetaljacket Offline
Stahl headers and cherry bomb mufflers.
Zoom Flywheel and clutch assembly.
slapper bars on the rear leafs.
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323487
06/19/17 09:54 AM
06/19/17 09:54 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Eddy T7(?) intake maybe Holley SD intake, holley 850 , mallory ignition .MT or Holley cast covers or Moroso tin
Definately a purple cam 😂
How hard to get old stuff in nz ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323601
06/19/17 02:00 PM
06/19/17 02:00 PM
P
Porter67 Offline
Porter67  Offline
P
Tunnel Ran 2-660 holleys, big yellow,accel super coil and plug wires, red or blue anodized al. valve cover hold downs, cool can, hurst line lock, air shocks, red painted rear drums.
And dont for get the BIG black fuzzy dice, with roach clip feather attached and the rear window decal, GAS, GRASS or AZZ, NO ONE RIDES FOR FREE!
Re: Roadrunner day two street racer ideas. [Re: fullmetaljacket] #2323674
06/19/17 04:33 PM
06/19/17 04:33 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
We have some slapped bars off my wife's '69 Dart & I'll have to check the headers & clutch, Cheers
Re: Roadrunner day two street racer ideas. [Re: tex013] #2323676
06/19/17 04:37 PM
06/19/17 04:37 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Tex
I do have some of those parts & will research the others, parts here are a bit like rocking horse poo, quite hard to find so I usually import most of what I need, thanks
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323683
06/19/17 04:46 PM
06/19/17 04:46 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Not sure I want to go to tunnel ram yet but I like your other ideas, I have one of those coils & a cool can already & possibly the hold down bolts so I'll have to go hunting. The painted brake drums is a good touch & I did that back in the day myself & the period correct decal idea rocks! Cheers
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323725
06/19/17 05:53 PM
06/19/17 05:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Super Tricks did not exist in '69.
Day two mods ... Hurst T handle, mags - Cragars, Keystones or Ansen "Sprints", big 'n little tires, Grant wheel, slapper bars, headers, cherry bombs, chrome or finned aluminum valve covers, intake & carb, dual point dist, coil, cam
Re: Roadrunner day two street racer ideas. [Re: Stanton] #2323798
06/19/17 08:32 PM
06/19/17 08:32 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Cheers, I must have the super tricks confused with another similar wheel, good list of other things!
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323810
06/19/17 08:49 PM
06/19/17 08:49 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
I know this Tumblr is for "70's Street Machines" but take a look through some pages, might find some inspiration.
'70s Street Machines
'71 Duster
'17 Ram 1500
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323818
06/19/17 09:01 PM
06/19/17 09:01 PM
Your probably thinking of the steel chrome 5 spoke Cragar SST wheels, I had them on my 1970 4 speed Hemi Baracuda due to NHRA not allowing legal NGRA stockers to use lightweight aluminum wheels like the Super Tricks and Centerline wheels runaway
As far as buiding a 440 block, I wouldn't if you want to make north of 650 HP on pump gas tsk
Find a decent 400 block and build yourself a real good large C.I pump gas stroker motor devil
Tell people it is a original low deck 361 block that runs real good whistling devil grin
Especially the Furd and Cheby guys stirthepot grin
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323853
06/19/17 10:12 PM
06/19/17 10:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Does day 2 have to be what was available for that year of car or just in the era. I ran super tricks back when they came out in the early seventy's on my 68 roadrunner. Actually i'm still running them on my 67 barracuda today. Same Accel Super coil also . Just sold off my original Hurst Super shifter from the early 70's.
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2323939
06/20/17 12:43 AM
06/20/17 12:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I lived it. Still got the car !!!
Re: Roadrunner day two street racer ideas. [Re: Stanton] #2324006
06/20/17 03:32 AM
06/20/17 03:32 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
[/quote]
I lived it. Still got the car !!! [/quote]
Any chance of a photo or two?
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2324014
06/20/17 04:21 AM
06/20/17 04:21 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Hurst T handle
S&W tach, oil & water gauges
Holley 780 #3310
Edelbrock CH4B
Hooker headers
Thrush straight thru mufflers
Racer Brown cam
Mallory ignition
Cal Custom cast aluminum valve covers
AR 200S "Daisys" or Ansen slots, 15x6 front, 15x8 rear
F70-15 front, J60-15 rear
On the rear quarter windows, put all the mfg stickers that came with the hot rod parts, along with a Bud Man
Re: Roadrunner day two street racer ideas. [Re: B5 Bee] #2324022
06/20/17 07:16 AM
06/20/17 07:16 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Originally Posted By B5 Bee
Hurst T handle
Holley 780 #3310
Edelbrock CH4B
Hooker headers
Racer Brown cam
Mallory ignition
More great ideas, I'm going to have a whole bunch of fun with this build!
Re: Roadrunner day two street racer ideas. [Re: nz383man] #2324036
06/20/17 09:30 AM
06/20/17 09:30 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
Header mufflers!!
Re: Roadrunner day two street racer ideas. [Re: maxi426] #2324062
06/20/17 10:36 AM
06/20/17 10:36 AM
moparx Offline
moparx  Offline
Originally Posted By maxi426
Header mufflers!!
you mean "purple hornies" ?
beer
Re: Roadrunner day two street racer ideas. [Re: moparx] #2324064
06/20/17 10:40 AM
06/20/17 10:40 AM
Wish these tires were back in production, but if you can find a decent pair of non rotted Super/Stock Formula 1's, that would be bananas on the street.
I got an overwhelming good response from wearing these 10- years ago. Imagine now.
Re: Roadrunner day two street racer ideas. [Re: B5 Bee] #2324071
06/20/17 10:44 AM
06/20/17 10:44 AM
an8sec70cuda Offline
Might be kinda hard to see, but look at the rear 1/4 glass of my road runner. Those are vintage "Holley Equipped", "Skyjackers", and "Cragar Hot Pipes" (whatever those are?) decals from back in the day. That's my favorite part of the car, lol. They're old, cracked, faded, etc. Love it!
CHIP
'06 GMC 2500HD LBZ Duramax
Page 1 of 3 1 2 3
