Re: My truck has been sitting. Opinions [Re: 71rm23] #2324134
06/20/17 12:20 PM
06/20/17 12:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
New battery
5 gallons of gas
check all fluids
You'll be good to go
Re: My truck has been sitting. Opinions [Re: 71rm23] #2325188
06/22/17 12:56 PM
06/22/17 12:56 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline
DusterJeff  Offline
I just bought a 92 W-250 that had been sitting pretty much for a year.Prior to that it hadn,t been run much at all,the guy was going to use it for a wood hauler. I put a new battery in it, gave it a couple of whiffs of either and it started. Let it idle a bit, put it gear and drove it 6 miles home.Only thing I noticed, the transmission did,nt want to shift out of low,then second gear.Afer a little delay,it up shifted and drove fine. I need to check the fluid level in the transmission.Probably change the fluid and filter.Suprising what a vehicle will do....
Do Something..Lead..Follow..or get the {Beep} out of the way..
