Page 3 of 3 1 2 3
Re: Electric Fuel Pump - 600HP [Re: gregsdart] #2330044
07/02/17 01:29 AM
07/02/17 01:29 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted By gregsdart
I just bought a Carter 4601, figure my deal will make 470 to 500 hp. It should be able to handle what you expect for power, as long as you have a good system.
I have had this same pump on my Savoy for about 10 years now and can still run strong. I feed it with -10 from the cell and 1/2" aluminum to the Quickfuel deadhead regulator.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Electric Fuel Pump - 600HP [Re: fourgearsavoy] #2330195
07/02/17 02:35 PM
07/02/17 02:35 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Last summer I installed a walbro gss340 255lph pump
in my tank. 1/2 supply 3/8 return,low amp draw,quite,not
expensive.
So far I like it.
Mike
Re: Electric Fuel Pump - 600HP [Re: mkdart] #2330226
07/02/17 04:16 PM
07/02/17 04:16 PM
Rittman Ohio
Rittman Ohio
expensive.
So far I like it.
Mike
Mike what regulator did you use?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Electric Fuel Pump - 600HP [Re: GTX MATT] #2330313
07/02/17 07:23 PM
07/02/17 07:23 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
I run a MagnaFuel 275 pump. It has done its job for some eight years, this spring I had to change out the pump shaft seal because it started to leak.. other than that no issues what so ever... Run a AN12 line from the fuelcell to the pump and an AN10 to an Aeromotive regulator...
/Tom
Re: Electric Fuel Pump - 600HP [Re: fourgearsavoy] #2330314
07/02/17 07:26 PM
07/02/17 07:26 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Hey Gus,Holley 12-841
Hope to see you at Norwalk next month
at the big Mopar bash
Buy-the-way I'm nowhere near 600hp,
But it should support close to 600hp
Mike
Page 3 of 3 1 2 3
