Re: Electric Fuel Pump - 600HP
[Re: GTX MATT]
#2323933
06/20/17 12:25 AM
06/20/17 12:25 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Just got back my Magna 500 I sent in for PM, it was rebuilt. They informed me that I bought it 15 years ago.Went 145 in my 3900 lb brick........
[Re: 451Mopar]
#2323979
06/20/17 01:47 AM
06/20/17 01:47 AM
Posts: 43,095 Bend,OR USA
Cab_Burge
I guess MSD bought out Mallory? Wow the prices doubled! Holley bought out MSD several years back and sold Lunati to Comp Cams, the world changes a lot in some businesses Pray for the Edlbrock company to remain independent now that Vic JR has past away
[Re: GTX MATT]
#2324023
06/20/17 07:38 AM
06/20/17 07:38 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
With some effort, you could have a far superior fuel system at a lower cost. A Walbro 255lph pump is around $130. A quick-fuel low pressure return style regulator is under $80. Add a line to the car and you're all set. These pumps are quiet, and are OEM quality made to last 100,000 miles.
Not a typical approach, but blow-through guys do this with great success.
[Re: TRENDZ]
#2324047
06/20/17 10:01 AM
06/20/17 10:01 AM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Not a typical approach, but blow-through guys do this with great success. x2 - I use an an in tank 340 lph pump with return to feed a 580 inch Hemi, so far so good.
[Re: GTX MATT]
#2324490
06/21/17 12:52 AM
06/21/17 12:52 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I love my mallory 140. Same pump since 2005. In 2012 i bought a rebuild kit for it to take to Drag Week but haven't needed it yet. Seems like prices have gone up alot on everything. I would hate to be building something from scratch right now
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: TRENDZ]
#2324631
06/21/17 12:06 PM
06/21/17 12:06 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Not a typical approach, but blow-through guys do this with great success. I had the same response typed out, but it seems like hanging a pump off the bumper is the only Moparts approved way... a 255LPH Walbro is rated at 43.5 psi, at 7 psi flow is higher and current draw is lower. My old BG pump sounded like a chainsaw was in the trunk, I can't even hear the 255. I've got mine in-tank, which is pretty easy with a fuel cell, and will just take a little creativity for a stock tank.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: GTX MATT]
#2324635
06/21/17 12:12 PM
06/21/17 12:12 PM
Posts: 570 UK
rb446
UK
Back in the day I ran 2 blue pumps, the 2nd for N20 fuel only, firstly on my 340 street/strip car, and then on the race only 440 car, dead headed on both. Never had a problem in 10yrs, never had to replace any of them. Whether the quality today is as good, who knows, (should be better?). For 600hp+ a blue or black is plenty and at under $200 if your budget minded is good, the Mallory is no doubt ok but at $306.....too many out there to choose from, most you just don't need as I see it.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: GTX MATT]
#2329235
06/30/17 06:08 PM
06/30/17 06:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have always used 2 pumps in line.. at first just a pair of Holley blues.. then I went to a pair of Mallory 140s till I went injected.. never had a pressure issue
[Re: MR_P_BODY]
#2329301
06/30/17 08:30 PM
06/30/17 08:30 PM
Cab_Burge
I have always used 2 pumps in line.. at first just a pair of Holley blues.. then I went to a pair of Mallory 140s till I went injected.. never had a pressure issue In line like in series or side by side parallel?
[Re: Cab_Burge]
#2329309
06/30/17 08:43 PM
06/30/17 08:43 PM
MR_P_BODY
I have always used 2 pumps in line.. at first just a pair of Holley blues.. then I went to a pair of Mallory 140s till I went injected.. never had a pressure issue In line like in series or side by side parallel? Parallel for volume... plenty of pressure And if one dies it still runs
[Re: MR_P_BODY]
#2329316
06/30/17 09:10 PM
06/30/17 09:10 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
So into a Y then a single feed to the regulator.............
[Re: an8sec70cuda]
#2329909
07/01/17 08:50 PM
07/01/17 08:50 PM
Posts: 5,987 Anoka County, MN
Leigh
Anoka County, MN
Another option...Aeromotive 11203 street rod pump, deadheaded, -8 line. Fed my 800+ hp hemi to run 9.50s at 140 mph at 3800 lbs w/ no trouble. Put a lot of street time on it too. I will be using one of these. I "fixed" a 1996 BG400 with Product Engineering seals, and now it leaks.
[Re: shorthorse]
#2329923
07/01/17 09:19 PM
07/01/17 09:19 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I see that Mallory fuel pumps are still available online. A look today shows 18 listings for Mallory/MSD pumps at Summit and 3 at Jegs. But, when I went to Holley's site there is no mention of Mallory even under their "Brands" section. Are the Mallory pumps still being made or is everything I'm seeing just old stock? If you look on Holleys site, MSD is not listed as one of the "Holley" brands, however the MSD Performance Group is owned by Holley. If you go to the MSD site, Mallory is listed as one of their brands, and the fuel pumps are listed there.
