Re: dodge dakota frame swap, custom coils or air bags needed
[Re: 5280Dart]
#2304752
05/15/17 10:04 AM
05/15/17 10:04 AM
Posts: 1,506 AZ
Mike P
AZ
Oh man I can truly sympathize. I had exactly the same problem on my 57 when I put the Hemi in. The slope on the hood interfered with the front of the air cleaner for the Tri-Power. In my case it was either lose the Tri-Power for a shorter intake or use a hood scoop. I agonized over that for about a month (especially as IMO there are no scoops that really look good on these cars). In my case the Tri-Power won and I sacrificed a 61 Thunderbird hood for the scoop. .
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Mike P]
#2305246
05/16/17 12:12 AM
05/16/17 12:12 AM
Posts: 1,111 tri-cities Washington/Denver, ...
5280Dart
I agonized over that for about a month (especially as IMO there are no scoops that really look good on these cars). In my case the Tri-Power won and I sacrificed a 61 Thunderbird hood for the scoop. Well for what it is worth, it looks good. I actually was trying to figure out what you used.... Kinda leaning toward a 1969 dodge power bulge.... I am going to contact some of the supercharger manufactures and hope that they offer a unit for the 6.1 with about an inch less total height than the srt intake manifold. I briefly considered a 1" body lift, and then a corresponding 1" suspension drop. Dont really want to go that route.
[Re: 5280Dart]
#2323399
06/19/17 01:15 AM
06/19/17 01:15 AM
5280Dart
Had to cut a 2.375" hole in the firewall, behind the passenger side fuel rail for the harness to pass thru. There is a portion of the harness that has to be snaked under the intake manifold, cam sensor, water temp, a/c pump, etc. That took some doing.
[Re: 5280Dart]
#2361010
08/28/17 06:48 AM
08/28/17 06:48 AM
Posts: 1,506 AZ
Mike P
AZ
Great to see/hear it run! Did you come up with a hood clearance solution?
