Page 1 of 2 1 2 >
#2316472 - 06/05/17 07:57 AM My Ez efi project
sogtx Offline
Loc: upstate western ny
I looked for a couple hours a couple months ago on google
moparts , etc to get some ideas on
how to install ezefi . Didnt know where to drill
holes, where to mount ecu, or how i should plumb
lines . With anticipation of keeping things looking Stockish.
The thought of a fuel regulator on my firewall made me want to
puke.
Hopefully my ref pics help someone .
This might be the best mod ive ever done.
It is not a weekend job for most .. at least not like I
installed it .
I started the engine last night .
Cold start , warmed it up , and purred at 600 rpm.
if it ever stops raining , maybe ill test drive this week.
#2316475 - 06/05/17 08:09 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Wife always complains that the car stinks,,
She can never get it to start when hot ( i never had a problem ) .
I never installed my return line , crappy gas
I never maintain this driver like it deserves , But finally heres a great improvement for it.
It idled in the shop for 20 mins with minimal ventilation.
When i came into the house , i usually get the you stink
comment , i had to ask her if my clothes smelled.
Just a little. SO im off to a good start .
Pulled the tank and ordered a Tanks inc fuel injection
ready tank . Its real nice . Painted or anodized aluminum
color , i was impressed.
#2316531 - 06/05/17 10:20 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Installing the pump and float could be a little challenging.
my buddy from a local resto shop has a hundred of them
under his belt , he dialed them in for me. He specified
black permagasket sealant along with the cork and
rubber ..
#2316821 - 06/05/17 06:24 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Bought two 3/8 lines from fine lines and stacked them
Installed fuel filter alongside torsion bar support
There is already a stamped opening behind hole
i cut in the right side line.
#2317035 - 06/06/17 06:04 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
I purchased six feet of hydraulic line insulator and installed before
I flared the lines to run along the front frame rail, i shoulda bought 7
I used a stainless braided 6an line for the hi pressure
and used the rubber provided with the kit for the return line.
I routed the lines from the frame rail between the alternator and dizzy
like factory route.,it doesnt stick out after the air cleaner installed.
I purchased a couple 45 barbed an fitts and a couple straights
and used the kit rubber hose for the gas tank connections.
There was a couple knockouts in the hump behind the rear seat
I used a couple washers for the 5/16" gas tank vent. I used a brass barbed 90
To make sure id be clear of the exhaust
The 4 pin weatherproof connector saved me a lotta grief for not having to
solder wires under the car .
After i raised the tank into place it was a 5 minute deal to
Connect , well kind of ...
i soldered a brass 6/32 screw onto send unit wire to fit onto
original harness for fuel level wire.
I rtvd silicones the connection . Should be good for a while
#2317413 - 06/06/17 10:16 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
To clear the exhaust with vent tube - i stuck 3" of 1/4" copper tubing into 5/16 rubber fuel line and bent a parfect 90.
#2317416 - 06/06/17 10:18 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
These are connections at tank mated to steel linesc
#2317421 - 06/06/17 10:22 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
It took a week for me to decide where to put the controls
before i drilled a large hole in firewall. Behind the AC box fit perfect.
The Control box fits perfectly in the passenger pillar and the kick panel
hides it all .
#2317423 - 06/06/17 10:23 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Thats a crappy pic
#2317428 - 06/06/17 10:31 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
I rewound the harness with harness non stick tape.
I separated the black and red for direct battery connection.
You can barely tell there's extra wires in the compartment.
#2317431 - 06/06/17 10:35 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
The FAST water temp sensor would not fit in any spare threaded opening.
It took a while to find this new neck .
Cut and tapped a threaded opening in 1/4"
#2317441 - 06/06/17 10:51 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
The flash really makes things look dirty in the engine compartment and all this AC stuff always gets in the way .
#2320378 - 06/13/17 05:47 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Since i didnt want to mount the fuel p regulator on the
firewall , everything i googled for ideas showed the ideal
location is as close to carbs as possible .
How is this for close ..
#2320384 - 06/13/17 05:58 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
The hi pressure from pump goes directly into the fast throttle
body fuel log . Then its regulated on the return .
I had to rotate the diaphragm on top of the regulator
to get the vacuum nipple pointing up . 4 Allen screws , its easy.
#2320389 - 06/13/17 06:09 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Connection of the supply and return is somehow crammed
in under the coil and connected to the regulator And supply log
On Throttle body. I didnt think it mattered which log I connected to
its a loop .
#2320390 - 06/13/17 06:11 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Ill replace the rubber return line someday
probably after first engine fire .
#2320975 - 06/14/17 06:18 AM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
After tidying things up under car , i connected
The 02 sensor to sheetmetal under car.
Car ran like crap and had 3 hrs of diagnosing
and a plug change .
Factory 6 pin harness wasnt mating to 02 sensor
Im hoping the rest of the harness has integrity .
Lot of other troubleshooting horror stories on the net ..
so probably good practice to watch the crimps and
connections on the harnesses.
#2323306 - 06/18/17 08:29 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
sogtx Offline
Well, all i could think of was vapor lock and pulling
tank into vacuum.
I mounted vent in trunk thinking it would just suck air.
Im a moron , i forgot that it allows vapors to escape too
especially when filling tank .
My idea of routing into trunk might not work .
But have ideas .
To be continued .
I put 20 miles on car over weekend, great cruising
I bet i gained 20 horse by the way it launches and
when i kickdown . So far so good ,
Except for the smell from the trunk ... frown
#2329152 - 06/30/17 12:45 PM Re: My Ez efi project-69 roadrunner [Re: sogtx]
BIGGERED Offline
Internet Tough Guy
Loc: North East USA
Keep up the good work Andy.
Have fun with the convertible.
Kevin
I earned my title by questioning a members declaration that he was dating a 17 year old when he was 28. Yes he would not like the outcome of his visit to my house to pick up my 17 year old daughter!
#2332924 - 07/07/17 04:54 AM Re: My Ez efi project-69 roadrunner [Re: BIGGERED]
sogtx Offline
Well , ive logged about 150 miles between rain
So far , so good .
One of my buddies spotted a problem with a vacuum port cap
So it needs to relearn all over .
Its a decent smooth idle . Occasionally ramps up/down
The A/f 's are pretty smooth,
Cruises significantly well .
The car is NOT cold blooded anymore ,
But likes 190 degrees ,but im seeing 200 degrees a lot
Not sure if too lean , or ?
So far I would reccomend to most people .
Page 1 of 2 1 2 >
25,154 Registered Members
186,848 Topics
1968 GTX Barn Find?? not mine...
by vinnyd76
02/25/18 08:55 AM
66 B-Body Plymouth or Dodge Wagon
by 6pkRB
02/25/18 08:54 AM
Best Dyno operator ever
by WHITEDART
02/25/18 01:07 AM
So I Dislike The 2019 Rams SO Much...
by Sunroofcuda
02/24/18 10:40 PM
