Page 1 of 3 1 2 3
Proper 2017 Oil for flat tappet classic mopar cams #2323252
06/18/17 08:21 PM
06/18/17 08:21 PM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
I just watched a youtube video saying ALL new off the shelf oil will wipe the lobes off our classic car camshafts.
Its been 12-14 yrs since Ive had mine on the road last and it said late 90's the oil companies lowered zinc/phosphorous amounts.
What is truth and what oil do I use.
Historically I've always used mobil 1.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323257
06/18/17 08:26 PM
06/18/17 08:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323263
06/18/17 08:36 PM
06/18/17 08:36 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I use Valvoline VR-1 with my .650 SFT. Pulled the valley tray to have a look and the lobes look perfect. Doesn't break the bank and its available everywhere.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323290
06/18/17 09:38 PM
06/18/17 09:38 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I also use VR-1
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323311
06/18/17 10:38 PM
06/18/17 10:38 PM
Granbury TX
Granbury TX
So i take it that it was legit?
The guy in the vid recommended Joe gibbs oil (now driven) but said had no
affiliation with them. $10 a Qt. Ouch.
Also said all the major brand oil claims were bogus and didnt have enough zinc.
Where you guys buying valvoline?
02 Mercedes C230K
19 Camry
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323320
06/18/17 10:48 PM
06/18/17 10:48 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
VR1 is on Amazon in 6 quart cases, about $6 a quart.
https://www.amazon.com/Valvoline-SAE-VR1...lvoline+vr1+30w
Re: Proper 2017 Oil for flat rappet cams [Re: formula_s] #2323326
06/18/17 10:58 PM
06/18/17 10:58 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
I believe Autozone has it but only in 50 weight. Can't imagine who has use for it.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323327
06/18/17 11:02 PM
06/18/17 11:02 PM
Missouri U.S.A.
Missouri U.S.A.
I get VR-1 at the local Oreilly's or Napa.
10.02@134
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323332
06/18/17 11:08 PM
06/18/17 11:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Really depends on the cam being run. My stock 2bbl cam in the 273 runs just fine on whatever 10w30 is on sale.
Don't be the exception.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323334
06/18/17 11:21 PM
06/18/17 11:21 PM
BDW Offline
BDW  Offline
Add 1/3 bottle of Lucas break with the cheapest oil on sale
Re: Proper 2017 Oil for flat rappet cams [Re: BDW] #2323546
06/19/17 12:10 PM
06/19/17 12:10 PM
On a side note I hear www.bobistheoilguy.com is a good read. As said I would go with one of the brands that get touted on here regularly, brad Penn/valvoline VR1 & several others. the search function would have something.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323614
06/19/17 02:31 PM
06/19/17 02:31 PM
P
Porter67 Offline
Porter67  Offline
P
I use simple oils with one container of comp cams zinc additive.
All posted will work, try to find the cam and lifers maybe off ebay that from the late 70-s to early 80-s, although ive never wiped a cam I do feel the base materials have also gotten cheaper.
Std older comp 821-16 non edm lifters are hard to hurt...
http://www.ebay.com/itm/COMP-Cams-Solid-Lifters-Flat-Tappet-Chrysler-340-360-383-400-Set-of-16-821-16-/262795933374?hash=item3d2fdbb6be:g:9I4AAOSwt5hYcBJ-&vxp=mtr
At times you can find them for $75.
Its also not hard to modify a lifter like the 821-16 for better oiling like in a few odd classes that wont allow a edm lifter.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323646
06/19/17 03:38 PM
06/19/17 03:38 PM
Missouri U.S.A.
Missouri U.S.A.
Howard's also has a direct lube EDM lifter that works well for added protection against worn lobes.
10.02@134
Re: Proper 2017 Oil for flat rappet cams [Re: Supercuda] #2323866
06/19/17 10:42 PM
06/19/17 10:42 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Exactly. It's about Spring Pressure. The anti-wear packages in many current grades are as good or better than what was normally sold in 1968 or 71. However if your running a cam with fast ramp and high spring pressures then yes you probably want to be sure the oil has the a really good package for the sliding follower action.
If you really want to know about oil selection for older engines, then check out Richard Widman's paper. He even sent out a sample of classic motor oil for analysis. smile
http://www.widman.biz/Corvair/English/Links/Oil.html
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323870
06/19/17 10:47 PM
06/19/17 10:47 PM
P
Porter67 Offline
Porter67  Offline
P
Alot of links but little hands on input here....hmmm.
Re: Proper 2017 Oil for flat rappet cams [Re: Porter67] #2323904
06/19/17 11:29 PM
06/19/17 11:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have used Brad Penn and VR1 with great results, I guess that would qualify as hands on results shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323911
06/19/17 11:45 PM
06/19/17 11:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
hands on means anecdotal. Unless you got analysis results it's useless.
At least the link has the analysis.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323936
06/20/17 12:29 AM
06/20/17 12:29 AM
P
Porter67 Offline
Porter67  Offline
P
you got analysis...
Two of the three links are pushing there product, not sure what "The Corvair Guy" might be helpful for a vw owner.
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2323953
06/20/17 01:03 AM
06/20/17 01:03 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
13 years ago my engine builder told me to use Delo LE 400 15w/40 with a bottle of Comp Cams Oil
additive. I've been running it ever since. I did notice that they came out with a new formula (Delo 400 SDE) with lower Zinc. I still can find the Delo LE formula.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Proper 2017 Oil for flat rappet cams [Re: Prochargedmopar] #2324029
06/20/17 08:43 AM
06/20/17 08:43 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The OP asked if a Video claim regarding current off the shelf motor oil was true. Specifically if all 2017 oil sold will wipe out cams of "our classic car camshafts." We gave an answer and the link has a paper (pdf) that explains why. The details are about the characteristics of lubrication in an engine. It even discusses different needs of gear driven vs. chain driven. For the purpose of understanding how and why an oil made and sold in 2017 differs from the ones made and sold in 1968 and 1971 it doesn't matter if the cam was made by GM or Chrysler or Triumph.
Page 1 of 3 1 2 3
