Bell housing to Crankshaft Concentricity Question.
#2321509
06/15/17 08:47 AM
06/15/17 08:47 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Still working on the shake at launch issue I have with my stock 69 Barracuda Formula S 383 4 speed car. Just a question concerning the bell housing. If the Parallelism of the tranny mounting surface or the concentricity to the crankshaft were out of spec. would that cause an intermittent hard shake at standstill take off? Once the car is rolling it's fine. No shifting issues. Just take off shake.
I've done lots of work on this car the past 2 years and still trying to pinpoint this issue. All the obvious stuff and then some. Thinking more out of the box at this point.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Bell housing to Crankshaft Concentricity Question.
[Re: TimS]
#2321556
06/15/17 11:38 AM
06/15/17 11:38 AM
TimS
Walton, Indiana
Here is what I've done so far:
New Mcleod clutch/pressure plate set & throw out bearing from Brewer's. New super stock springs and bushings. New pilot bushing. New tranny front bearing/seal. Ensured tranny shaft didn't have burrs or imperfections. Resurfaced/ measured pressure plate twice during the removal and re-inspection of the new clutch components. New rear tranny/motor mount. Adjustable pinion snubber. Measured pinion angle. 2.5 degrees negative. Also played around with 2 and 4 degree shims to make more negative. Ensured correct drive shaft length. Thoroughly inspected the linkage, 3 times. Checked the motor mounts. They appear like new. Motor does not move a bunch during hard launch. Also looked at them with the emergency brake set and clutch release to load the motor.
I'm probably missing something but this is most of it. Car does not vibrate at all going down the road. At a rolling start does not shake. Standing still however during light or hard launch you get some degree of shake. I can actually get a violent shake at light launch. Shake that is way more than any clutch chatter I've ran into over the years.
I have added traction bars to it and set the snubbers against the springs. You can drive it with very little to no shake at launch that way. I don't like doing that but it at least allows me to drive the car.
[Re: TimS]
#2321599
06/15/17 12:56 PM
06/15/17 12:56 PM
TimS
Walton, Indiana
I was referring to the flywheel concerning the resurface. The PP is new. Can the hard spot areas be identified prior to resurfacing?
[Re: TimS]
#2321623
06/15/17 01:35 PM
06/15/17 01:35 PM
Jamey
[Re: TimS]
#2321633
06/15/17 01:55 PM
06/15/17 01:55 PM
TimS
Walton, Indiana
I replaced the shocks all round and have the longer units in the rear to accommodate the super stock springs.
shake feels all over but mostly in the middle. I've got 15" Mastercraft 50's on it now but it also shook with 14" BF Goodrich TA's. Both street radials.
[Re: TimS]
#2321649
06/15/17 02:21 PM
06/15/17 02:21 PM
Posts: 15,304 Omaha Ne
TJP
Omaha Ne
I was referring to the flywheel concerning the resurface. The PP is new. Can the hard spot areas be identified prior to resurfacing? To my knowledge without testing, No. Before the surfacing they visually appear as blued or other color irregularly shaped spots and sometimes cracks. After surfacing the surface may appear fresh and normal but can be very irregular to a friction surface (clutch material). Most clutch manufacturers typically recommend a new flywheel for the above reason.
[Re: TJP]
#2321726
06/15/17 05:42 PM
06/15/17 05:42 PM
TimS
Walton, Indiana
I was referring to the flywheel concerning the resurface. The PP is new. Can the hard spot areas be identified prior to resurfacing? To my knowledge without testing No, before surfacing they visually appear as blued or other color irregularly shaped spots and sometimes cracks. After surfacing the surface may appear fresh and normal but can be very irregular to a friction surface (clutch material). Most clutch manufacturers typically recommend a new flywheel for the above reason. So to be clear, the flywheel could have hard spots due to overheating that resurfacing can hide. I guess I should pull that back apart and look at the flywheel now after driving the car around for almost a year this way. It may tell me something now where it wouldn't before. The car had been sitting for quite some time and may have been shaking on the previous owner.
[Re: TimS]
#2321729
06/15/17 06:02 PM
06/15/17 06:02 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Launch issue, what do you mean by launch? Are you talking about a shudder if you feather the clutch from a standstill or a shudder if you "dump" it from a standstill?
[Re: TimS]
#2321772
06/15/17 08:01 PM
06/15/17 08:01 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
Sounds like clutch related vibration, chatter Did you possibly get some oil or other oil based liquids on either the clutch disc, pressure plate or flywheel? If so that may be part of the problem
[Re: TimS]
#2321778
06/15/17 08:17 PM
06/15/17 08:17 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
What type of material is the disc face have on it? Certain High Performance materials will grab causing your shutter condition. If it's a stock type rag facing look for broken or weak mounts ,sing bushings or bad shocks
[Re: 6PakBee]
#2321851
06/15/17 10:43 PM
06/15/17 10:43 PM
TimS
Walton, Indiana
Launch issue, what do you mean by launch? Are you talking about a shudder if you feather the clutch from a standstill or a shudder if you "dump" it from a standstill? Both.
[Re: Cab_Burge]
#2321852
06/15/17 10:45 PM
06/15/17 10:45 PM
TimS
Walton, Indiana
Sounds like clutch related vibration, chatter Did you possibly get some oil or other oil based liquids on either the clutch disc, pressure plate or flywheel? If so that may be part of the problem I've had the Assy. apart twice looking for those things. Non found.
[Re: TJP]
#2321864
06/15/17 10:55 PM
06/15/17 10:55 PM
TimS
Walton, Indiana
keep us posted on what you find. Myself, I might just put an entire new assembly and flywheel in. FYI We have had very good luck with the Centerforce dual friction clutches in our own as well as customers cars The Hays setup I took out really didn't look all that bad considering all the shake. I put in this McLeod setup based on Wayne Brewers recommendation. This same setup worked great in my 68 Bee a few years ago. Shake the same before and after. I am considering a new flywheel. I got to get it back apart anyhow but hate to just keep throwing money at it.
[Re: TimS]
#2321873
06/15/17 11:09 PM
06/15/17 11:09 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
You can try this to eliminate some of the components as contributing to the problem.
Replace the driver's side engine mount with a solid mount, or drill a hole through it and bolt a nut with washers through it and or chain the motor down so it can't lift up any more than 1/2".
This will hold the engine from being able to lift from the torque. I've had issues in the past like this. using a solid mount eliminated the changing geometry of my linkage when the engine moved and pointed me in the direction of the aforementioned missing Marcel spring that cushions the grabbing force of the clutch.
Rigid puck style clutches don't typically have Marcel springs and they tend to chatter unless they are essentially dumped at the starting line or the engine trans is solidly mounted. I still have some of those old solid puck clutches laying around.
It wasn't until the Mcloed Street Twin's came out that I was able to have a clutch live on the street with a high output engine with no chatter.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: TimS]
#2321886
06/15/17 11:22 PM
06/15/17 11:22 PM
TJP
Omaha Ne
keep us posted on what you find. Myself, I might just put an entire new assembly and flywheel in. FYI We have had very good luck with the Centerforce dual friction clutches in our own as well as customers cars The Hays setup I took out really didn't look all that bad considering all the shake. I put in this McLeod setup based on Wayne Brewers recommendation. This same setup worked great in my 68 Bee a few years ago. Shake the same before and after. I am considering a new flywheel. I got to get it back apart anyhow but hate to just keep throwing money at it. Reading through your struggles and BELIEVE me I've BTDT, I'm wondering if the flywheel has not been the culprit all along Especially if it has not been replaced. Other than replacing everything, The only other option I can think of is to send the entire assembly into the current supplier (McLeod) for analysis. just my Silly though just occurred, So one other stupid question ?? any chance the crank has too much end play?? please keep us posted
