Re: 1970 440 HP Vs HP2 ??
[Re: cyphre666]
#23227
01/26/06 01:40 PM
01/26/06 01:40 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
The 500 wedges are 4 bolt mains
but 500 wedges are built in NEW MEGABLOCKS ....
[Re: VCODE]
#23230
01/26/06 01:42 PM
01/26/06 01:42 PM
JohnRR
U.S.S.A.
Now I am more mixed up. I hear something about a 6 stamped on the block itself down below pad. Is this true
NO .... there is alot of MISINFORMATION that has been spread around over the years ...
[Re: InViolent]
#23233
01/26/06 01:46 PM
01/26/06 01:46 PM
JohnRR
U.S.S.A.
...And it must have the correct balancer and rods to boot, right?
thats a given since BOTH the 440-4 and the 6 pk have the same rods and balancer .
[Re: DPelletier]
#23235
01/26/06 01:48 PM
01/26/06 01:48 PM
JohnRR
U.S.S.A.
No it's not true. Don't be mixed up. Like John said there are NO MARKINGS to determine it's a 440-6 except if you can match the partial VIN to a V-code VIN car. You can tell by the pistons and cam, but what are the odds that it still has the original pistons and cam after 36 years?
exactly , thats why the myth is still thriving , spread by those looking to make a buck
[Re: AZ_A12_BEE]
#23237
01/26/06 02:16 PM
01/26/06 02:16 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
My 1970 U-code Cuda is stamped HP2 and is original #'s motor(partial vin on motor). Car has a harmonic balancer that resembles a cast crank. All 440-4 and 440-6 used the heavy six pack rods and in turn used a externally balanced crank....
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
[Re: JohnRR]
#23239
01/26/06 02:26 PM
01/26/06 02:26 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
........which means you can't use the rods and balancer to determine if a motor is a 6-Pack or not. All HP motors used "6-Pack" rods and balancers (which make you wonder why the heck they called them "6-Pack" rods).
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#23242
01/26/06 02:34 PM
01/26/06 02:34 PM
Posts: 2,372 White Plains, NY
VCODE
White Plains, NY
So what does the B stamped on the top of my pad mean Thanks Guys for all the help
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#23243
01/26/06 02:39 PM
01/26/06 02:39 PM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
Unless I'm mistaken, the "B" indicates the year of the engine.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#23244
01/26/06 02:42 PM
01/26/06 02:42 PM
VCODE
White Plains, NY
I am sorry, I should have said that it is a 70 stamped F440 with the HP and 11 111 and a B Thanks again
[Re: VCODE]
#23245
01/26/06 02:43 PM
01/26/06 02:43 PM
68LAR
South Park, Pa.
I don't know what that means.
[Re: AndyF]
#23246
01/26/06 02:44 PM
01/26/06 02:44 PM
Posts: 4,389 Kenmore, New York
InViolent
Kenmore, New York
Now wait a minute! I thought 70-71 only did the 440-4V HP use the same balancer as the 440+6. In 69, wasn't the 440+6 the only engine to use this configuaration? Did the Forged crank 440's in 72-74 use the same balancer?
I guess another wat to put it..."When did the 440-4 and 440+6 share the same rod/balancer part number?"
And finally...how can I identify a "Six-Pack" Rod?
