Re: 1970 440 HP Vs HP2 ??
[Re: mc4406]
#23213
01/25/06 09:34 PM
01/25/06 09:34 PM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
Thats what i've heard before, But someone told me the other day, They thought HP2 went into 6 pack cars and HP where 440-4 cars
... WRONG ...
[Re: mc4406]
#23214
01/25/06 09:39 PM
01/25/06 09:39 PM
Posts: 4,995 North Pole,New York
formula_s
North Pole,New York
Is there a difference between the HP and the HP2?? Thanks
Yes ,big difference; those HP2 blocks have a high nickel content and four bolt mains!!!.
Oh never mind thats ford and gm stuff.
[Re: bschargerse]
#23218
01/26/06 12:33 AM
01/26/06 12:33 AM
JohnRR
U.S.S.A.
did they ever build a 4 bolt main block 440?
Aren't the new 440 engines in the Mopar Performance catalog cross bolted mains? They look it from the pics.
why yes they are , i have one
[Re: 05dakota]
#23220
01/26/06 12:48 PM
01/26/06 12:48 PM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
So the only difference between the HP and HP2 is the shift it was built on. How do you tell if it was a 440-4 or a 440-6pac engine. Was there a stamp or number on the block. I know the v in the Vin is for six pack engine. Also what does a B stamped on the pad mean. Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#23221
01/26/06 12:55 PM
01/26/06 12:55 PM
Wanna know what my 1970 dodge 440 SIXPACK block says on the "dist pad area".?
[Re: 05dakota]
#23223
01/26/06 01:07 PM
01/26/06 01:07 PM
I am not so sure about that dak man mine says HP then space then 2 then next line says F440 then the diamond which I believe is the pressure test stamping. Every article I have ever read by the "experts" states something new or supercedes something else.
#23224
01/26/06 01:17 PM
01/26/06 01:17 PM
Do you dudes remember the old MuscleCar Review Magazine? There was an excellent article by roger gibson on correctly detailing the 440sixpack/6bbl engine I think it was the fall 97 issue. It states all 440-4 barrel was h.p. only all sixpacks were H.P.2 only however this has been debuked countless times since then!!
#23226
01/26/06 01:38 PM
01/26/06 01:38 PM
JohnRR
U.S.S.A.
thats why many think it because, roger gibson said so .
its has been proven FALSE ...
the only way to tell an original 6pk shortblock is to find an unmolested block , it MUST have these 2 items , first is pistons with 4 valve reliefs , second is a cam that takes a 3 bolt timing gear , it MUST HAVE BOTH
