#2312373 - 05/28/17 11:15 AM Improved ride, 66' Coronet convertable
Hemi ragtop Offline
Loc: Tennessee
I have driven 5,700 miles in my HEMI convertible. Now I want to improve the ride. It is harsh, especially in the rear. I am thinking about better shocks. Here is what I have:
Rear, Cal Track mono springs (Rubber bushings vs. Aluminum) and bars. Super Stock gas shocks from Mancini and a .900" rear sway bar.
Front, .970" T bars, 1.25" Firm Feel sway bar and parts store gas shocks. All mounts are urethane.
Weights:
LF 1,151 lb.
RF 1,104 lb.LR 1,057 lb.
RR 862 lb.
What do you guys suggest?
Edited by Hemi ragtop (05/28/17 11:16 AM)
Edit Reason: no photo
#2312430 - 05/28/17 01:38 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
autoxcuda Offline
Loc: So Cal
Maybe.
Have you tried removing/disconnecting the cal track bars and see if there is a change?
What about putting the stock rear springs back in and see how it rides?
Spring Fling 33
April 13 & 14, 2019
Woodley Park, Van Nuys CA
www.cpwclub.com
500+ show cars, 200+ swap, manf. midways
Malibu Cruise, Cruise-In
Free Spectator Admission!
#2312433 - 05/28/17 01:52 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Supercuda Offline
I want my mommy!!
Loc: up yours
That's a pretty damned big rear bar
Don't be the exception.
#2312479 - 05/28/17 03:25 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
BigBlockMopar Offline
Loc: The Netherlands
IMO harshness comes from shocks.
I think a better shock will change a lot for the car.
BigBlockMopar.com
#2312489 - 05/28/17 03:44 PM Re: Improved ride, 66' Coronet convertable [Re: BigBlockMopar]
Hemi ragtop Offline
Loc: Tennessee
The ride IMPROVED with the Cal Trac springs. I am wondering about the shocks and possibly rear sway bar.
I'm looking for some one who KNOWS shocks. 4 corner weight should help. This car will NOT see a dragstrip (I would have chosen a much lighter, cheaper car/engine for that! I just love to drive it!
#2312490 - 05/28/17 03:45 PM Re: Improved ride, 66' Coronet convertable [Re: BigBlockMopar]
Hemi ragtop Offline
Loc: Tennessee
Who would you recommend I go to for good shocks?
#2312514 - 05/28/17 04:31 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
I think 'autoxcuda' thinks you're running CalTrack traction bars.
My '73 Dart became a much more 'evolved'/upgraded handling car when it went from KYB gas shocks upfront and Monroe Sensatrac shocks in the rear, to adjustable Hotchkis upfront and QA1 adjustable shocks at the rear.
I also improved/upgraded the springs.
Before all that it rode kinda rough as well but I didn't really know it because I was kinda used it.
Even though my C-bodies drove much nicer.
The Dart is a pure daily driver, but it can hang in the corners with most modern cars on the roads these days.
It's a 3200 lbs car without driver.
I also always had to slow down before (smooth) speedbumps to prevent being bounched around like a toy car.
After the upgrade I can even pick up speed and the speedbumps get delt with in an almost professional way.
BigBlockMopar.com
#2312515 - 05/28/17 04:32 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
autoxcuda Offline
Loc: So Cal
Disconnect the rear sway bar on one end. If ride doesn't change, not the issue.
You are asking for the ride and harshness to improve. High end performance shocks probably aren't going to help. They help control really stiff springs (which you don't have) and control weight transfer. You are trying to make it a little more Cadillac, not make it more Viper.
You are looking to dampen and soften the high speed shock acceleration for noise, vibration, and harshness (NVH). That quick movement comes from bumps, cracks, roughness in the road.
Low speed dampening is the vehicle weight transfer/transition side to side, front to rear, or both (corner to corner)
I'd look at Bilstien RCD. Maybe an adjustable, But it would be just set on the soft settings.
Edited by autoxcuda (05/28/17 04:39 PM)
Spring Fling 33
April 13 & 14, 2019
www.cpwclub.com
#2312522 - 05/28/17 04:45 PM Re: Improved ride, 66' Coronet convertable [Re: BigBlockMopar]
autoxcuda Offline
Loc: So Cal
Yes. He said Cal Trac and bars.
Spring Fling 33
April 13 & 14, 2019
www.cpwclub.com
#2312549 - 05/28/17 05:26 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Ah, somehow missed that the first 2 times I read it.
BigBlockMopar.com
#2312907 - 05/29/17 10:34 AM Re: Improved ride, 66' Coronet convertable [Re: BigBlockMopar]
Hemi ragtop Offline
Loc: Tennessee
Thanks for the ideas, so Bilstein adjustable set on the softest setting? Front and back?
#2318316 - 06/08/17 11:20 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
67SATisfaction Offline
Loc: Albany, NY
Good place to start softening the ride - and I'll throw in my $.02 and suggest you use rubber bushings (which you mention in your OP)... rubber bushings at the shocks will help relieve the harshness.
Best,
- Art
Edited by 67SATisfaction (06/08/17 11:22 PM)
1965 Satellite hardtop 361/2bbl, auto, pegleg 2.76
1967 Satellite convert 383/4bbl, auto, pegleg 3.23
1975 Maserati Bora, 4.9L DOHC hemi V8, 5-spd ZF
1982 Alfa Romeo GTV6, 2.5L SOHC hemi V6, 5-spd transaxle
1994 Alfa Romeo 164LS, 3.0L SOHC 24v hemi V6, 4spd auto ZF
2007 Aston Martin DB9, 6.0L DOHC V12, 6spd full manual transaxle
#2319881 - 06/12/17 11:50 AM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
minivan Offline
Loc: Eugene, Oregon
I know people who have had great success with some plain jane Monroe shocks you can buy at the parts store..
I have KYB on my car and they are somewhat harsh and I might try the Monroe shocks if I keep my car longer....
#2320180 - 06/12/17 07:34 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Hemi ragtop Offline
Loc: Tennessee
OK, thanks for all the imput. I called several "respected" names in the business. Then I thought, "why not Firm Feel"? They provided my steering box, front sway bar and even built the Federal power steering pump for me.
I called, unlike the others, when I mentioned that I had the 4 wheel weights, they said, "let me guess them"!. They were within 100#!
They sold me Bilstiens that were modified to fit the car. After installing them, I just got to say, WHAT A RIDE!.
#2320183 - 06/12/17 07:39 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
Yeah, the Bilsteins are great shocks.
#2320184 - 06/12/17 07:41 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Hemi ragtop Offline
Loc: Tennessee
The harshness is gone, the ride is smooth. The car takes the 15 mph curves with no lean and confidence at 30 mph. I love it!
Don't forget our Mopar sponsors, they specialize in our cars and KNOW our cars!
#2320254 - 06/12/17 09:34 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
autoxcuda Offline
Loc: So Cal
So were they bilstien RCD non adjustables?
Were they off the shelf or did he have them custom made for you?
Spring Fling 33
April 13 & 14, 2019
www.cpwclub.com
#2320262 - 06/12/17 09:40 PM Re: Improved ride, 66' Coronet convertable [Re: Hemi ragtop]
Loc: Granite Bay CA
KYBs should be called:
Kill
Your
Buttocks.
#2320397 - 06/13/17 06:44 AM Re: Improved ride, 66' Coronet convertable [Re: autoxcuda]
Hemi ragtop Offline
Loc: Tennessee
Bilstein doesn't make a shock for the car. Firm Feel uses a shock made for the WEIGHT of the car and modifies them.
25,640 Registered Members
195,768 Topics
1969 Plymouth 4 door Satelite --North Texas $3500
by bigdad
22 minutes 29 seconds ago
Taking A Look At The Dodge B-Bodies Of Mecum Kissimmee 2019
by Rustymuscle
Today at 09:49 AM
Original 15X7 “450” Steelie Value?
by floyd
Today at 09:42 AM
1968 GTX Project
by 65pacecar
Today at 09:38 AM
