Page 9 of 9 < 1 2 3 4 5 6 7 8 9
#232020 - 09/14/09 08:17 AM Re: Still running hot in traffic with the new aluminum [Re: Publicbottle]
I had a problem with a 440 in a 56 Dodge pickup. After about 20 min of driving the temp would be at 230. Tried reducing the speed of water through the system with no change at all changed the thermostat. No help. When changing the thermostat noticed a couple of inches under it in the housing there was a hole drilled into the other side (inlet). Tapped and put a 1/4 pipe plug in the hole. That cured the problem. The engine would go up to 195 (that was the thermostat) and not go any higher. Can someone tell me why they drill a hole from the inlet to the outlet side of the water pump housing? Anyway, overheating problem solved!
#232021 - 09/14/09 01:11 PM Re: Still running hot in traffic with the new aluminum rad [Re: Mopar73340]
fox Offline
super street
Loc: chatham, Ilinois
I did NOT read every post.
This is an area that seems to be over looked.
Is it running too lean?
What do the plugs look like?
Did you try ti richen it up some?
I had a car 20 years ago that did exactly as you have.
The edelbrock carb was far too lean, richened it up and all was good, even with the air conditioning runnig!!!!!
#232022 - 09/14/09 10:02 PM Re: Still running hot in traffic with the new aluminum
Prodart440 Offline
Loc: Auburn WA
I would like to know more about this solving what sounds to be my problem.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
#232023 - 09/15/09 08:58 PM Re: Still running hot in traffic with the new aluminum [Re: Prodart440]
Dusted_Ya Offline
Loc: The Dalles, OR.
I'm having an overheating problem as well and I put an infrared heat gun on my exhaust pipes just coming out of the heads and I'm getting 675ish on all but #6 is like 550 and # 5 is so hot it don't read (over 800). Now I'm wondering if maybe my stock cast iron intake manifold is warped or cracked somewhere? I'm also going to try tapping and plugging that hole in the WP housing.
#232024 - 09/15/09 10:11 PM Re: Still running hot in traffic with the new aluminum [Re: Dusted_Ya]
Prodart440 Offline
Loc: Auburn WA
I didn't put a gun to mine, but after holding the RPM's at 2500 for a couple of minuates (in park) the headers were glowing red. Could it be lean, or too much timing? Car runs cool at low speeds, but on the freeway at higher RPM it runs HOT!!
Aaron
68 Coronet 440
#232025 - 09/16/09 08:09 AM Re: Still running hot in traffic with the new aluminum [Re: Prodart440]
feets Offline
Senior Management
Loc: Irving, TX
Glowing headers sounds too lean.
#232026 - 09/16/09 01:47 PM Re: Still running hot in traffic with the new aluminum [Re: feets]
fox Offline
super street
Too lean or LATE timing can cause it.
I still bet it is way too lean.
Simple to richen it up some to try!!!!
#232027 - 09/17/09 11:04 PM Re: Still running hot in traffic with the new aluminum [Re: fox]
Prodart440 Offline
Loc: Auburn WA
I think I agree on the too lean. I took my distributor to have it checked. It is set at 15* initial and 34* all in by 2500 rpm. If this is right, my headers are now glowing even more. I will try to richen the secondaries and see how that goes. Any other suggestions??
Aaron
68 Coronet 440
#232028 - 04/24/10 07:35 PM Re: Still running hot in traffic with the new aluminum *DELETED* [Re: Prodart440]
AHall Offline
Loc: DFW Texas
Post deleted by AHall
Edited by AHall (05/04/10 10:44 AM)
#232029 - 04/24/10 08:46 PM Re: Still running hot in traffic with the new aluminum [Re: AHall]
gtx69 Offline
super gas
What does the converter have to do with running hot.
#232030 - 04/24/10 08:55 PM Re: Still running hot in traffic with the new aluminum [Re: gtx69]
HealthServices Offline
Why would you even post that?
Loc: So Cal
Produces a hell of a lot of heat esp if it is a 4k stall. It would always slip on the street. I don't know how that can really be that streetable.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
#232031 - 04/24/10 10:38 PM Re: Still running hot in traffic with the new aluminum [Re: HealthServices]
gtx69 Offline
super gas
But how does that affect the engine?Seems like only the trans would need a good trans cooler
#232032 - 04/24/10 10:51 PM Re: Still running hot in traffic with the new aluminum [Re: gtx69]
Loc: So Cal
You can run a stand alone unit but that is a lot of heat. If the lines currently go into the radiator they are basically heating up the coolant. I just caught the tail end of this thread so I'm not sure exactly what he has for a setup.
#232033 - 04/24/10 11:09 PM Re: Still running hot in traffic with the new aluminum rad [Re: AHall]
enelson Offline
mopar addict
Loc: San Clemente, ca
underdrive pulley? That's what kills my cooling system...
#232034 - 04/24/10 11:30 PM Re: Still running hot in traffic with the new aluminum rad [Re: enelson]
Loc: So Cal
Killed mine too.
#232035 - 04/24/10 11:54 PM Re: Still running hot in traffic with the new aluminum rad [Re: AHall]
terzmo Offline
Loc: Pendleton NY
My 498 stroker would NOT run cool in traffic...final fix was....alum 26 rad...cheap one...schroud and 7 blade clutch fan..fan half in...half out...this heating problem plaqued Me for 4 years...I am VERY happy with this combo now...car rarely goes over 200...not much over..in long traffic jams in very hot weather
#232036 - 05/01/10 08:13 PM Re: Still running hot in traffic with the new aluminum [Re: feets]
AHall Offline
Loc: DFW Texas
FEETS- email sent
Edited by AHall (05/04/10 10:46 AM)
#232037 - 05/01/10 08:27 PM Re: Still running hot in traffic with the new aluminum [Re: AHall]
Loc: Lincoln Nebraska
Funny thing was id pull off in stop and go and it would go to 185-190 degrees, I get back on the highway (granted doing 70 mph taching 4000 rpm) and it crept to 215-217 degrees and stayed there.
sure sounds like classic inadequate flow in the cooling system (usually the rad) but I'd pull the plugs and check the turning torque required on the front 1&1/4 bolt ASAP right when it's good and hot and maybe 215-217 is not a deal breaker but to me that is too hot.
#232038 - 05/01/10 08:32 PM Re: Still running hot in traffic with the new aluminum [Re: RapidRobert]
J5440 Offline
Loc: USA
I haven't even attempted to read every post on here,...but do you have a fan shroud?
#232039 - 05/01/10 09:36 PM Re: Still running hot in traffic with the new aluminum [Re: J5440]
bb74swngr Offline
mopar addict
Loc: Missouri
Went through all of this with by 440 Dart. My overheating problem turn out to be low fuel pressure ala too lean. It would change depending on what day it was, hot at idle one day, hot driving the next. New fuel pump and it was cool...really. Doesn't matter whether it makes sense or not, that's what fixed my overheating.
Russ:)
BigBlock 74 Swinger
25,738 Registered Members
192,835 Topics
1971 HEMICUDA HISTORY SEARCHING.. BS23R1B CAR
by 71redcuda
02/16/19 03:46 AM
6.4 BGE block
by HOTMOPR
02/16/19 12:11 AM
Couple Pertronix questions....
by gss
02/15/19 11:00 PM
Adopt a pet
by Superfreak
02/15/19 10:43 PM
