6.1 intake question #2317132
06/06/17 01:34 PM
06/06/17 01:34 PM
Jamey Offline OP
Jamey  Offline OP
I'm building a 67 satellite and putting a 6.1 in it. The car will be a street car but I would like to make it run better than a stock 6.1. I'm gonna run a little bit bigger cam and headers of course. My question comes to the intake side. I am staying fuel injected and wonder if there is any advantage to leaving the stock intake or running an intake like the arrow racing intake? The biggest advantage I see with the arrow is I can run a 4150 style throttle body and a standard style intake. Do you think there would be a performance advantage? Thanks
Re: 6.1 intake question [Re: Jamey] #2317147
06/06/17 02:20 PM
06/06/17 02:20 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The stock intake needs a gasket match but will provide gobs more torque thru the rpm range making it feel much better on a street car.
The arrow intake will make more peak power and look much better
