Re: Looking for 440 and 4-speed Trans
[Re: C_B5]
#2312464
05/28/17 04:59 PM
05/28/17 04:59 PM
Posts: 992 California
cudagee
California
Still looking for auto 727 transmission for BS23R0B146394. It may still be in Canada.
Re: Looking for 727 Automatic Hemi Transmission
[Re: GVH]
#2315748
06/03/17 11:16 PM
06/03/17 11:16 PM
cudagee
California
Re: Engine and Trans Lost & Found
[Re: Alaskan_TA]
#2319203
06/11/17 12:30 AM
06/11/17 12:30 AM
Posts: 1,882 Walla Walla, WA
Hemi_Jack
Walla Walla, WA
Found 727 Big Block 8E140687 supposed to be out of a 440 B body that was in Washington state.
[Re: MarkMcDonald]
#2322544
06/17/17 10:25 AM
06/17/17 10:25 AM
Posts: 29,648 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Found 70 Hemi E body drive train 0B216400 New number to me, but from a 1970 Cuda.
[Re: Brian Styles]
#2322824
06/17/17 11:00 PM
06/17/17 11:00 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
You should mention the plant that made each car. Edited. Figured that less is better in the world of Google searching, but edited in such a ways as to be found either way... More is better. is from BS27V0B242312 but I do not have any contact information on file for the owner.
[Re: Alaskan_TA]
#2322829
06/17/17 11:13 PM
06/17/17 11:13 PM
Posts: 24 Boca Raton, Florida, USA
Brian Styles
Well, the way I've edited it, both should now be indexed. Since I know you like to track these things, and as the VIN dictates, the car is a 1970 Cuda Convertible 440+6. SPD: Feb.03, 1970 Paint/trim: EK2, PRXW, V3X Some of the more important options from the two tags: D21, A33, A62, M91, N96 and Y91 And you can use myself or Samantha as a point of contact should you ever locate the motor of the sheet.
[Re: Alaskan_TA]
#2329174
06/30/17 03:22 PM
06/30/17 03:22 PM
Posts: 23 Millville, Pa
mkocan
Millville, Pa
Looking for Plymouth AAR Cud'a Vin # BS23JOB305120 engine block. Was in Connellsvile, Pa. Have TA block # OB291022. 570-594-0830
[Re: ztriper]
#2335080
07/11/17 12:24 AM
07/11/17 12:24 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I am looking for the t/a engine for my aar cuda or the block it is 0B292370 the car originally came from arizona then went to utah. I have a complete t/a engine 0B291258 if that helps anyone. thanks I am not aware of the original engine for your car, but I have heard of the car that matches 291258. It did have an engine it from a different AAR than yours at the time. Please email me at sixpak340(insert at symbol here)att.net & I will pass your contact information on to the owner of 291258 if it is OK with you. Thanks! Barry
