Re: Drop spindles; your experience?
[Re: geo.]
#2316726
06/05/17 06:20 PM
06/05/17 06:20 PM
Posts: 27,451 So Cal
autoxcuda
So Cal
One problem with dropped spindles is that they place the lower control arm closer to the ground, you'll run into things you normally wouldn't.
Yes!! With 15" wheels, No drop spindles! Maybe with 18" or larger wheels,and No headers it might be a good plan. If I was local to you, I'd want to try those wheels on an E body, but I'd put the 4.5 b.s. ones on the front and swap the tires, I think it would look great! chassis height will be adjusted with the torsion bar screws. So chassis can remain in same place. Yes, that side of the LCA will be 2" closer to the ground. But the wheel is there. Guess if you plan on driving over roadkill just to the inside of your tire you could have an issue. Or the very edge of a tall speed bump that's not very rounded. I haven't heard anyone hitting anything. But that doesn't mean much.
[Re: MRGTX]
#2317136
06/06/17 01:58 PM
06/06/17 01:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Are they "tall" ball joints?
[Re: MRGTX]
#2317578
06/07/17 11:49 AM
06/07/17 11:49 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I have seen differences on ball joint stud length on stock replacement joints especially if they are made overseas.
Carl Kessel
[Re: MRGTX]
#2317598
06/07/17 12:32 PM
06/07/17 12:32 PM
Supercuda
About to go away
About to go away
up yours
If you look at circle track stuff you can get tall upper ball joints for MoPars, some of them made by QA1, I suspect this might be it. As an example
[Re: MRGTX]
#2318557
06/09/17 05:36 PM
06/09/17 05:36 PM
Supercuda
About to go away
About to go away
up yours
QA1 does make good ball joints, but if the stock replacement type is short enough to let your rims work...
Well that's a cheap solution.
[Re: Supercuda]
#2319883
06/12/17 01:53 PM
06/12/17 01:53 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Way off here, but for reference I used 3" drop spindles on my 77 Chev truck in the pic...
Used a 4" drop kit on the rear...
