My Duster weighs 3400 lbs with me in it, it has gone a best of 1:43 sixty foot with 3:91 and 4:10 with a 94 inch circumference M/T street radial rear tire(10:34 ET, 128.6 MPH)
This is a street and strip car on pump gas corked up, not real powerful(518 C.I. Eddy heads and a six pak). I do use a 2:77 Mopar low gear set in the trans and a custom built 10 inch street and strip conventer, the car will push the front tires thru the staging lights at 2300 RPM foot braking
It flashes to around 4300 rpm according to the playback tach. The car ran almost the same ET and MPH with a set of 3:73 in it also
