Temp gauge? #2311776
05/26/17 10:29 PM
05/26/17 10:29 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Where is everyone running temp gauge sending unit from? I have been told just drill a hole but I have already ran the motor for a few minutes and don't want to have to drain it all down because of metal shavings. Any ideas? 03 5.7 hemi with aftermarket gauges
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: Temp gauge? [Re: Biggie] #2311821
05/27/17 12:21 AM
05/27/17 12:21 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Can you adjust the aftermarket gauges to different temperature sending units?
Does your water pump have a NPT air-bleed plug on the very front?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Temp gauge? [Re: Biggie] #2312698
05/29/17 12:26 AM
05/29/17 12:26 AM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
I'm not sure about adjusting the gauges. We installed them two years ago and I doubt I kept instructions. I will see if I can down load them
I don't recall seeing and not air bleed but I will check. Thanks for the ideas!
03 chrysler 300m
10 dodge charger
