carb conversion setup question on an 81 FI 318
#2312266
05/28/17 07:16 AM
05/28/17 07:16 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I am probably buying an 81 318 fuel injected Chrysler today.
The previous owner wanted to switch to carb years ago and began taking off everything above the intake. That was some time ago, and he never finished. Ive switched a 76 Cordoba from lean burn to carb. It took a new Dizzy, new eddy intake, eddy 625 carb, coil, splug wires, plugs and a box. Plus some vacuum line re-routing/ eliminating. Worked fine.
Since this was a 76 and the 'computer' in the air filter housing only controlled limited items so removing it wasnt a hassle and didnt disrupt any gauges or other systems, and only involved minor wire modifications and only in the engine bay.
Now, I've never owned an 81 chrysler, and it has pieces missing from the intake and up. So, what do I need to convert it? Were 81's still Lean Burn technology, or did they have a more modern ECM that controlled more than just ignition system? If so, is there a ecm somewhere under the hood or in cabin? Did it use sensors on the engine, exhaust and tranny to get info? Will disabling it mess with any other systems besides ignition, and will it affect any accessories or interior gauges/switches?
Basically, if it is different and controls more than the 76 lean burn computer, what all do I need to convert to carb?
Also, if it is better than a 76 lean burn computer, would it be more cost effective, less of a hassle, or just more efficient to just restore the original FI system?
Re: carb conversion setup question on an 81 FI 318
[Re: Adam71Charger]
#2312270
05/28/17 07:40 AM
05/28/17 07:40 AM
Posts: 5,749 ohio
ruderunner
ohio
Knowing model and engine size will be a huge help here.
May have just been a lean burn setup that the owner mistakes for fi.
If it was fi, likely a stand alone system, so very similar to changing out a lean burn setup. You'll need to figure out a fuel pump or regulator in addition.
Angry white pureblood male
[Re: ruderunner]
#2312307
05/28/17 11:06 AM
05/28/17 11:06 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Knowing model and engine size will be a huge help here. There is exactly ONE OEM fuel injected 318 in 1981. Since you obviously do not know that do not offer up your uninformed opinion. The 81 EFI system is fairly primitive, your change over will be very similar to the lean b urn conversion you did on the 76.
[Re: Supercuda]
#2312357
05/28/17 12:38 PM
05/28/17 12:38 PM
RapidRobert
I'm thinking you would convert it like you would the earlier one; early t cover/mech pump/hughes cam extension/intake/carb/dist.
[Re: Adam71Charger]
#2312601
05/28/17 09:20 PM
05/28/17 09:20 PM
RapidRobert
its your lucky day bro (makes up for the bad ones). I would suggest keeping it in this same thread.
[Re: Adam71Charger]
#2312784
05/29/17 06:56 AM
05/29/17 06:56 AM
Adam71Charger
The swap is actually more involved than the typical lean burn. the old lean burn is just spark control. In the 81-83 imperials, there is a spark control compute, as well as a fuel control computer. The system is a 'constant flow' vs a typical efi where injectors are just turned on or off. There is the low pressure fuel pump in the tank, plus a high pressure pump on top of the throttle body (the big cylinder in the photo), that constantly puts fuel through the tb but varies its speed based on input from several sensors found on modern cars like 02, speed density, fuel flow meter and fuel temp sensor, among others.
This is an amateur explanation at best, but simply it is much more complex and was so troublesome it was ended after a 3 year run. The factory warranty carb conversions included replacement of the fuel tank, harness modifications and lots more.
What really adds to the trouble here is the digital display gauge cluster and all the fancy options it supported like a mpg readout. So just switching the dizzy, intake, ignition control box, and carb is not good enough if one wants to keep anything but the speedometer working on the dash cluster.
Its definitely doable, I just need to do a lot more research and read everything from the imperilclub.com., a great source of info on these early and unique efi systems. On the other hand, my efi system is complete, and there are mods I can do to eliminate some of the problems it had.. then I could have a plush cruiser. but really I think I'd prob be more happy selling these rare parts to someone else and switch over to carb, and a new cam, some headers and a non lockup converter
[Re: Adam71Charger]
#2312832
05/29/17 10:21 AM
05/29/17 10:21 AM
Posts: 4,913 new berlin wisconsin
Mr T2U
the 81 imperials are a cool car. if i had the $$$ and a really good place to work on them i would put a 3rd gen hemi in one.
before spending much money research what they are worth. new they were 20K+. now not so much.
perception is 90% of reality
[Re: Adam71Charger]
#2313703
05/30/17 06:09 PM
05/30/17 06:09 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
That looks like the system we called the hydraulic injection system. It was not used on many cars as when I went to the Dodge dealer in 1986 I got some training on it and to be honest I never saw one come in the dealer shop so I never actually worked on one. It was only on certain Chrysler cars and I think only around a year or two. But they said they were not a great EFI system and not many techs out there know much about that system. I actually still have my Mopar training book on that system. My best advise is get rid of it unless you know how to work on it or know a tech who knows alot about it to help you if you have problems. And I would guess parts are hard to find for it if you would ever need any replacement parts. Ron
[Re: 383man]
#2313791
05/30/17 08:43 PM
05/30/17 08:43 PM
Posts: 173 Milano, Italia
FK5
Milano, Italia
You won't get it started without the air cleaner on and tight. The ASD just won't let it pump fuel without it all on and tight. The changeover is fairly simple, but more involved than a simple lean burn removal. I have 2 Imperials an '83 with a Magnum 360/727 and an '82 with the stock efi. The '82 gets insane mileage, rarely under 17 combined and up to 26 straight highway. A lot of that is because of the 2.24 rear. It isn't a complete dog because of the low gearset trans. I had a ton of trouble with vapor lock in the past and haven't had it out since I moved overseas in 2006. I would try to get it running with the efi. It will hunt rpm a bit, but otherwise they are very smooth and excellent when running right. They are pretty finicky though. The imperial club A12 Mark referenced has a ton of good info including the retrofit manual. You can do it with junkyard parts, but will lose some of the features of the trip computer. http://www.imperialclub.com/Repair/Year/1981-1983/index.htm
[Re: Adam71Charger]
#2314182
05/31/17 02:39 PM
05/31/17 02:39 PM
FK5
Milano, Italia
I mentioned the imperial club in my post. I have all their info and tricks, like isolating the asdm from the fender and running it's own seperate ground wire.
Daytona turbo the car already has an electric fuel pump, 2 actually but one gets eliminated in the swap.
383 man yes it's a hydraulic injection system, and also known as a constant flow system.
If I can get it to run right I'll keep it. If not,.the mechanical swap is the easy part, keeping all of my fancy inststrument cluster working properly is the hard part I *think* most of the stuff will work correctly. The speedo and the odometer do on mine anyway. The guy that did the initial 360 swap on mine put a Mirada tank and sender. I think the gas gauge can be a minor problem if you stick with the original stuff. The trip computer probably won't work too great, but even my stock efi car gets a little squirrely with the fuel gauge and telling me I am getting 99 mpg. You can tell if you review the conversion kit what you need to try to keep it all working right, but you probably won't care about some of it. My cars are kind of a strange case because the backyard converted car was done up right, while my stock efi car was just kept running for years and got kind of cobbled. I really just bought it for the seats, but it got such good mpg and had cold a/c, so I ended up daily driving it for 3 or 4 years.
[Re: Adam71Charger]
#2314957
06/02/17 01:34 AM
06/02/17 01:34 AM
Adam71Charger
Im still amazed that as smart as chrysler engineers were, why on earth did they put the MAF in the air cleaner??? 1st of all, at that time, most FI cars were still using MAP sensors, but chrysler used some pretty advanced/efficient components for a fi engine in 1981, so with all that engineering going into it, why would they place the majority of these parts in compromising areas, like hard to seal air cleaner assemblies that sat right on top of the engine? Not to mention the ignition control computer sitting in the air cleaner as well getting shook around constantly while the engine was running. And then relying on a screw to ground the power cut of module to the fender.
I guess I really cant talk smack about it, not like Im an engineer nor have I ever designed an FI system, but some things just seem like a no brainer. maybe they were stuck with budget constraints and were forced to modify existing parts instead of building new parts like throttle bodies that would house the MAF, and feul/spark control computers relocated to engine bay or cabin
[Re: Adam71Charger]
#2315785
06/04/17 12:53 AM
06/04/17 12:53 AM
Adam71Charger
Got everything cleaned up and assembled. put about 4 gallons of premium fuel and a bottle of seafoam in the tank, The engine turns over nice and strong, and Im getting spark, but not a drop of fuel. I unplugged the asdm and jumped the contact of the large blue wire to the contact of large green wire. I dont know exatly what this does but I read about it on theimperialclub.com. When I turned the key to on I could hear a fuel pump running, couldnt tell which though, still no start. But it was late and I'd had a few beers and was done working on the car for the night.
I think the pump I heard was the control pump in the hsa assembly. I will have to have someone turn the key while I look down the throttle body to see if its even priming. I havent checked out enough of the possible problems yet to make an educated guess, but I think either the pump in the tank isnt working, the duel filters are clogged, or the control pump or entire hsa assembly isnt working right.
When I go back out Ill check everything in that order. Does anyone know if the fuel computer also controls the in tank pump or just control pump?
[Re: Adam71Charger]
#2315855
06/04/17 10:42 AM
06/04/17 10:42 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Sorry I can't be much help but I always find it interesting when people get old unusual induction setups running. Keep us updated, it sounds like you are close.
68 Barracuda Formula S 340
[Re: Adam71Charger]
#2316317
06/04/17 11:27 PM
06/04/17 11:27 PM
Adam71Charger
Success, sort of. Taking both needle and seats out floods the car almost immediately. Putting them both in , I get no fuel at all. I took out the needle and seat for the rail with the small sprayers, and left in the needle and seat for the large sprayers.
Car fires right up and runs and drives. It's not as smooth obviously as it could be because the fuel is basically just pouring out of the fuel rail instead of a nice spray pattern. But it works and now it runs and drives. That is until it finally gets flooded then it stops and I have to wait for it to dry or plug the asdm back in and fire up the car and burn up all the fuel that's in the intake then unplug the asdm and bypass it again and then the car fires right back up and drives.. until it floods lol.
This is a decent mickey mouse fix until I can find the cause of my low fuel pressure. Or gather the intake and carb I need for the conversion.
I'm going to get the conversion parts anyways actually, just in case I cant find the parts I need for repairs to the efi.
I'll probably run a switch that connects the green and blue asdm wires and run the switch to the cabin so I can turn it turn off the bypass when I flood, then burn it off, then flip the switch and bypass it again and start it up and drive! It's a temporary mickey mouse fix but it is better than nothing
[Re: Adam71Charger]
#2316430
06/05/17 04:25 AM
06/05/17 04:25 AM
Adam71Charger
MY GOD, These cars are insane.
So, I settled with the fact that I would be driving it for a little while in the condition I described above. At peace with that fact, I start doing other things like putting the door panel back on, replacing the fuse for the horn, playing with the gauge cluster fuse (the gauge is fully digital, but looks all scrambled and weird, just another issue to deal with I guess). There is this hissing noise whenever you open the door and the gauge cluster lights up, and continues after the car starts. Well, take out the 4 amp gauge cluster fuse and the hissing goes away. Not sure what the hell that is, but I did notice at least 3 vacuum pods under the dash. So I also replaced the front passenger caliper which was rusted and locked up, bled the brake line, and finally put some under dash wire harness connectors back on their mounts (they were just hanging). I finally installed the under dash cover and now Im tired and I want to enjoy my labor and go for a cruise.. well, a cruise that involves the engine flooding every ten minutes, but whatever I know I just undo my jumper on the asdm and then crank the car and burn up the flooded gas, then re-jumper the asdm. Its worth it after a day of labor.
SO, I get in the car. Apparently an exhaust leak has begun somewhere, cause I can really hear it now. I take the car out from my coltesac, and give it some gas, it hesitates and BAM backfires through intake, so I just take it slow and easy. The driving characteristics begin to change. hard to explain, but it ends up with the car dying.
So I get out and take the jumper off the asdm and plug the asdm back in its connector as usual. I get in the car, turn the key and after a couple seconds it turns on and I sit and wait for it to die. But.... it doesnt die... it keeps running! I was mystified and scared at the same time. Could it really have solved itself??? I shut the hood, and go driving. peppy acceleration, doesnt run smooth but it runs. I drove it all over. It doesnt like hills, but does great on the flat roads.
So apparently the EFI decided its going to work again. I get home and get out to investigate exhaust leak. I opened the hood and within seconds my eyes are burning and crying, I backed up.. then looked under the car.. for a few seconds until my eyes begin to burn and cry again. It was running fatty fat pig rich. Must be because I took the needle and seat out, which was necessary at the time, but now is causing it to run super rich. I also had the o2 unplugged for same reason, to help it run better back when the asdm was shutting everything down, so I plug it back in. I turned the car off and called it a night.
Looks like I now have a running driving imperial with a fuel control computer that has decided it likes all the attention Ive been giving her and will now operate correctly when I turn her on.
So tomorrow, I re-install the needle/seat in the FI unit, and take a look at the exhaust. hopefully its just leaking at the connection points so I can solve the problem with some remflex gaskets and be done with it.
[Re: Adam71Charger]
#2317054
06/06/17 10:14 AM
06/06/17 10:14 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Great read! I've heard about this early EFI system but have never seen one and have no experience with them, but I find this very interesting.
No longer taking $h!t from anyone!
[Re: Adam71Charger]
#2317766
06/07/17 06:50 PM
06/07/17 06:50 PM
Adam71Charger
Ok, back to square 1.
Looks like I need parts, and more troubleshooting. No thanks. Converting to carb and points vacuum advance distributor. Why points? Because I have one on the shelf.
Heres all the options I can think of for dealing with fuel delivery. I will be left with the stock fuel tank and in tank pump. The pump puts out max about 29psi. It was the control pump on the throttle body that changed the "low" pressure to high pressure, and the control pump is going bye bye.
So, stock tank and in tank pump with lines already in place leading right to top of intake. I need to do this as cheap as possible, Low on funds and this is going to be a daily driver so gotta get it done soon.
Option 1: rewire pump, Use a bypass regulator and regulate psi to eddy carb, sending the rest back through the existing return line.
question: Whats the cheapest regulaor I can accomplish this with? I saw a quick fuel 30-899qft but I dont know if it can handle 29psi. I also saw a tanks inc. regulator rated for 30-70psi input, does that mean it cant handle less than 30 psi? both of those are $75
Option #2 Unplug pump. Install a mechanical fuel pump (cheap!) and pull fuel through the unplugged in tank pump
Question: Some in tank pumps will allow this, in fact chevy guys with tbi camaros have done this when swapping to carb. does anyone know if mine will?
Option #3 install mechanical pump, drop tank, remove pump, extend hose to bottom of tank. I can rig up a sock at the end of hose for extra protection, although my car already has 2 fuel filters between tank and engine.
Option #4 Install exterior low pressure fuel pump and cheaper regulator and pull through tank pump
Option #5 same as #4, just extra step of removing in tank pump and extend hose to bottom of tank
Option #6 Rockauto dodge mirada gas tank $85, sending unit $55, then mechnical fuel pump $20
What do you guys think is best option 1 through 5? Or any I havent thought of? Remember, low dollar
[Re: Adam71Charger]
#2322774
06/17/17 09:32 PM
06/17/17 09:32 PM
Adam71Charger
Ok so I waited and got better parts for my conversion: Proform 66991 kit: vacuum advance 2 wire distributor, 2 prong ballast resistor and 4 pin orange box. Summit racing 750 vacuum secondary carb with throttle stud adapter and tranny kickdown extension Edelbrock Performer 2176 Intake with MR Gasket Ultra Seal intake gasket .060 NGK GR4 plugs delphi mechanical fuel pump. Got most of the wiring sorted out, and I have a question about the ballast resistor and starter relay. My current Ballast Resistor is 5 prong with 3 different resistances, and the starter relay is 6 prong. I'd like to simplify and clean up my wiring more, I dont mind the work. I have the 1981 FSM for my imperial and have followed the wiring diagram. I've already removed everything EFI, but I'd like to ditch the 5 prong ballast resistor and 6 prong Starter relay and go with a simpler setup from say a 72 Chrysler or dodge. Im already getting a new 2 prong ballast resistor with my proform kit, can I get a starter relay from a 72 318 dodge and follow the 72 wiring diagram to alter my ignition? Here's a picture of my stock S.R. and B.R.
[Re: Adam71Charger]
#2323405
06/19/17 01:36 AM
06/19/17 01:36 AM
RapidRobert
run the ign1 (run) blue wire to the upstream end of the ballast and T'd to the blue/yellow ECU pentastar connector terminal (might be solid blue). run the ign2 (crank) brown wire to the downstream end of the ballast. connect that downstream end of the ballast to the coil positive primary terminal. connect the coil negative primary terminal to the black/yellow ECU pentastar connector wire. With the blue/yellow ECU terminal held at 9 0'clock, run the 11 0'clock ECU terminal (might be tan with a black tracer) to the male metal terminal on the ECU half of the zigzag pull apart zigzag connector. the female counterpart on the pickup zigzag will be black, the other should be orange/orange. On the SR, duplicating the early stuff: I would run the ST terminal on the ign sw to the "ign" terminal & the "sol" large brown wire down to the starter solenoid & run the "grn" terminal to the NSS switch or permanently ground it as desired. EDIT we might (highly likely) be able to keep the current SR & just delete the one or two wires that wont be used when retrofitting to the earlier setup, we'd just need to find out what goes to where on the FI for a start.
[Re: Adam71Charger]
#2328126
06/28/17 04:27 PM
06/28/17 04:27 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The only question I have about the mech fuel pump swap is, does the motor actually have a fuel pump eccentric bolted to the front of the cam?
[Re: Adam71Charger]
#2328176
06/28/17 06:43 PM
06/28/17 06:43 PM
fast68plymouth
So. Burlington, Vt.
On a SB, the fuel pump eccentric is bolted to the front of the timing gear...... It's not part of the cam like a BB.
If you've bolted the pump on and it works, then it's obviously there.
[Re: fast68plymouth]
#2328290
06/28/17 10:09 PM
06/28/17 10:09 PM
Adam71Charger
If you've bolted the pump on and it works, then it's obviously there. My bad, didnt know that.
