Re: carb conversion setup question on an 81 FI 318
[Re: Adam71Charger]
#2328126
06/28/17 04:27 PM
06/28/17 04:27 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The only question I have about the mech fuel pump swap is, does the motor actually have a fuel pump eccentric bolted to the front of the cam?
[Re: Adam71Charger]
#2328176
06/28/17 06:43 PM
06/28/17 06:43 PM
fast68plymouth
So. Burlington, Vt.
On a SB, the fuel pump eccentric is bolted to the front of the timing gear...... It's not part of the cam like a BB.
If you've bolted the pump on and it works, then it's obviously there.
[Re: fast68plymouth]
#2328290
06/28/17 10:09 PM
06/28/17 10:09 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
If you've bolted the pump on and it works, then it's obviously there. My bad, didnt know that.
