Re: Tire Rubbing Issues
[Re: MuuMuu101]
#2312222
05/28/17 02:16 AM
05/28/17 02:16 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looks to me like you need new tires regardless.
[Re: Pacnorthcuda]
#2312225
05/28/17 02:31 AM
05/28/17 02:31 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Looks to me like you need new tires regardless. . Fix the issue first., I agree with both. Hence why I haven't raced the car since Spring Fling.
[Re: MuuMuu101]
#2312239
05/28/17 03:06 AM
05/28/17 03:06 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Can you post a picture of where you think it is rubbing up front?
For the rear I'd start by removing the small spacers and see if that fixes the problem. If so that will give you a bunch more info to help determine the permanent fix.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: MuuMuu101]
#2312343
05/28/17 12:11 PM
05/28/17 12:11 PM
Posts: 27,451 So Cal
autoxcuda
So Cal
You can fold the front corner too. 3" x 1.5" would be plenty. 3 x 1" will work too. Cut the lip at top of fold line and drill a very hole at end of cut. That will provide a radius fillet of short to prevent ripping cracking in future. Then fold lip flat. Then whole triangle over. Link to write up: https://board.moparts.org/ubbthreads/ubbt...earanceSm27.JPG
[Re: autoxcuda]
#2312405
05/28/17 02:34 PM
05/28/17 02:34 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
For the rear I'd start by removing the small spacers and see if that fixes the problem. If so that will give you a bunch more info to help determine the permanent fix. I don't have any photos, yet. I have some pictures I took maybe a month or so ago. I had already done some massaging after those photos were taken. Kind of in a rush this morning, but I already did some fender massaging work. Originally I thought the GT trim was cutting into the tire, but I checked and even pulled the fender a little and didn't notice anything. I really maximized the tire size in the back with the 255/40/18's. If I remove the spacers, the tire will most likely rub on the leaf springs, but I can check to make sure. I wanted the offset shackles installed from the beginning, but Hotchkis didn't install it for the above reason. I would say beef up the springs a notch and get bigger swaybars.
The cuts on the front wheels are inline with the fender, so imo they happen during severe spring compression. If they would happen during hard cornering, I think you would see small bites taken out of the tire.
I would certainly start working on the fender lips to get rid of any sharp edges. Any chance you can/want to 'pull out the fender a bit, without distorting it ofcourse?
What diameter torsionbars do you have installed? How many leafs on the rearaxle?
I agree that my springs (front and back) should be beefed up a little bit and this is occurring on severe spring compression. Driving on the freeway or slow maneuvering generally doesn't cut the tire. I'm running 1.06" T-bars up front and Hotchkis leafs in back. My Sway Bars are already pretty big (Hotchkis) and set to full stiff. I was going to have a truck/leaf spring shop install the offset shackles for me when I was going to get to them and I was going to ask them if they can add another leaf to my leaf springs while maintaining the same height. Or do you think a truck helper spring would suffice? I believe TomWheels used them with his Purple Valiant when he had some rubbing issues. It's just the offset shackles I have aren't made with a 1" drop. Helper Spring Examples: https://www.summitracing.com/int/parts/hel-550/overview/https://www.summitracing.com/int/parts/hel-991/overview/You need to lip rear fender lips too.
Once you bend it a little, use a hammer with dolly or price of wood held strong right behind every hit. If metal dolly wrap in cloth to not scratch paint. My paint is 25+ years old and didn't crack hardly at all. Trick is patiance and small hits. Just work from center out repeat over and over.
Before , After, tool from harbor freight
The rears aren't rubbing on the fender lip. They're rubbing on the inner wheel well where the wheel well starts to taper towards the top. But good to know for the future.
[Re: BigBlockMopar]
#2312625
05/28/17 10:24 PM
05/28/17 10:24 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I wouldn't bother with those truck helper springs. Looks unnecessary complicated. I would just add another leaf in the springpackages.
Just look for 2 similar sized leafs that fit nicely in between the other leafs. You can grind too long extra leaf shorter on the ends so the center pin stays in the correct location.
I added leafs in the springpacks on my own Dart. I'm upto 7 leafs per side now, but I'm also carrying two propane tanks in the trunk.
QA1 adjustable shocks control the rear and adjustable Hotchkis shocks are controlling the front of the car along with a Hellwig front swaybar.
Essentially, that's what those helper springs are. They're adding a leaf to the pack without opening the pack. I already also have Hotchkis adjustables all the way around.
[Re: rustbuckett68]
#2312993
05/29/17 02:30 PM
05/29/17 02:30 PM
autoxcuda
So Cal
You could clearance the fronts (or rears) the old way. Put a wood baseball bat between tire and fender, and roll car back and forth, by hand. If more space is needed, put some hefty buddies on the hood and repeat If you do that, roll the bat and hit the outside with a rubber mallet. Or some sort of soft headed mallet. I used a leather mallet shown in the pic. That supports the hit. Same idea I stressed before, small hits. Slowly work the metal.
[Re: Supercuda]
#2313457
05/30/17 11:15 AM
05/30/17 11:15 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I have that Eastwood tool and did the wheel lips on the rear of my Cuda and worked great. I was going to suggest that he borrow mine but for $60 for all four by someone who knows what they're doing is a bargain. If you heat the paint there is almost no chance of cracking it. For my AAR Cuda, I didn't push out the quarter just rolled the lip like the front fender originally is.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: autoxcuda]
#2314647
06/01/17 03:48 PM
06/01/17 03:48 PM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
You could clearance the fronts (or rears) the old way. Put a wood baseball bat between tire and fender, and roll car back and forth, by hand. If more space is needed, put some hefty buddies on the hood and repeat If you do that, roll the bat and hit the outside with a rubber mallet. Or some sort of soft headed mallet. I used a leather mallet shown in the pic. That supports the hit. Same idea I stressed before, small hits. Slowly work the metal. Steve, are you the one with the hammer?
Abe Lincoln
[Re: dart4forte]
#2314705
06/01/17 05:37 PM
06/01/17 05:37 PM
autoxcuda
So Cal
You could clearance the fronts (or rears) the old way. Put a wood baseball bat between tire and fender, and roll car back and forth, by hand. If more space is needed, put some hefty buddies on the hood and repeat If you do that, roll the bat and hit the outside with a rubber mallet. Or some sort of soft headed mallet. I used a leather mallet shown in the pic. That supports the hit. Same idea I stressed before, small hits. Slowly work the metal. Steve, are you the one with the hammer? No, I'm taking picture. He pulls his finger away when he swung.
[Re: MuuMuu101]
#2325556
06/23/17 01:27 AM
06/23/17 01:27 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Sorry, I kind of left this thread for dead. I've been super busy. Was on vacation for about a week and a half and then I just started another session of school again. But I drove the Dart today for about 30 mins. I didn't push the car too much because there was traffic on the street. Before I created this thread, I actually used a BFH on the front fenders and the past couple times I've driven it I haven't seen swiss tires on the front. The rears are rubbing on the outer fender (although it didn't happen today). There seems to be a ledge on the inside of the quarter panel and it's catching on that. It's not rubbing the rolled lip. I took a BFH to it and hopefully that helps. It seems like my short term fix is going to helper springs. My friend has a set that he used on his '72 Charger so that should help with reducing compression. Long-term fix would be offset shackles, that way I can remove my 5mm spacers and relieve some space. Also, I remembered that the 8 3/4 favors the passenger side so there's extra rub there. The offset shackles should center the 8 3/4 in between the wheel wells. So, we'll see. I hope I can fit 275's all around some day. Gotta keep massaging. Picture 1: Driver side Quarter panel rub. Picture 2: Bad picture of potential point of rub for driver side inboard wheel well. Picture 3: Passenger side Quarter panel rub.
